Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
I replaced the color wheel in my HLN5065W DLP tv now I dont even get a picture. After 3 times of it restarting itself I get 3 flashing lights on the front of the TV.
  • exile1113 Sep 03, 2010
    Got it. Your reply prompted me to tear apart my TV again and upon doing so I noticed that the color wheel I replaced was not sunk properly into the frame it goes in. I was afraid because the instructions warned me NOT TO OVER TIGHTEN it. So I tightened it up and now she works perfectly. Thanks again for your help SD TECH!
    Top Expert:
  • Samsung Master
  • 14,553 Answers
THIS IS JUST A SUGGESTION, IF I am right give me a very helpful vote here and a note, check the ribbon cable----color wheel has two cables--one regular and one orange--look at contacts on orange one--they should face the back of the light engine--it is very possible to put the cable in backwards--common issue.
SD TECH
Posted on Sep 01, 2010
I have Samsung HLN5065. It used to have a problem of shutting down on its own but now it does not turn on at all either by remote or manual button. I checked power and it is good other appliances are working.
Posted on Nov 07, 2010
After watching tv for a while I loose the color??
This tv have a colors wheel.The colors wheel effects is dying or dead are make loud squiling noises,motors noises and loose colors and flashes or flashes black&white with the picture.The colors wheel,must be replaced to solved this problems.The colors wheel is pretty hard to replace,because u require take many machanical parts out.Before u can even replaced the colors wheel itself.So hire the tv Tech. to replaced the colors wheel.
Nov 24, 2010 | Samsung DLP HL-P5663W 56" TV
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
My HLN5065WX will turn on, play for about 1 minute, flash funky colors then go black. Once this happens you can not shut down the TV. You must unplug to turn off.
Bad Color Wheel, its located behind the Lamp Pull Lamp out and use a Flash Light You should be able to see it.
Encompass Parts Distribution 1-800-638-3328
Samsung Parts.com 1-800-627-4368
You can also go to Encompass website and look up your Model#
Oct 27, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung DLP HLN5065W tv Black & White Picture
Yes,the problem is the colors wheel it dead.That one of the cause by the colors wheel,other are alots of squiling noises and making very loud buzzing sound.The cooling fan that u think is overheating,does it stop sometimes,when the tv is still on?Yes,than replaced it also,no than it still ok.Just hire the tv repairman,the parts he'll take care of it,don't order the parts,u might get the wrong parts or different sizes,that will not fit in ur tv.
May 23, 2010 | Samsung DLP HL-P5663W 56" TV
I have a Samsung 50 inch DLP - I heard a pop and the picture immediately disappeared. The 3 lights were flashing on the front which according to the book said it needed a new lamp installed. I ordered it,...
Sounds like the color wheel may have also gone bad. I recently saw a 56" Samsung where the bulb and color wheel went at the same time. The color wheel could produce a crying noise while trying to spin up.
May 05, 2009 | Samsung DLP HL-P5663W 56" TV
HLN5065W picture turns black and white and shuts down
Sounds like your color wheel may be at fault. Do you ever hear any unusual noises coming from the rear of the TV? Color Wheels usually make a humming sound as they go bad. This is because the tiny bearings in the color wheel motor have begun to misshape from use and heat. This is a known issue in this TV! Expect to spend $300-500 to have this serviced by a service company. If you have the right stuff, you can do it yourself. If you search the web, you'll find a color wheel for this TV for under $100, but installation can be tricky.
michtech
Feb 16, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung HLP 4663W DLP TV 3 lights blinking
Color wheel is the biggest failure part in Samsung DLP...
A little technical to replace...............T.
Jan 22, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
DLP TV starts to loose picture after 1 - 1/2 hours of use
This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. see which inputs have the problem to narrow it down. if only some inputs, suspect analog board. if everything flickers(all inputs and menu), suspect the dmd or engine. you can see the lamp shine out the back. if the lamp is flickering, suspect lamp or ballast.
Nov 22, 2008 | Samsung HLN5065W 50" Rear Projection...
Noise from Samsung rear projection DLP HD TV.
this noise is an indication of a bad color wheel. aa dlp uses a mechanical motor to spin a coloered segment disk. this turn the white light of the lamp into your colors of pictures. Now anything that moves will eventally break. the flickering is also an indication of a color wheel going bad. eventally this will cause the set to shut down. Color wheels can be replaced. i dont know your model so i am not sure of the exact replacement procedure. at my shop we charge average 250 for such a repair
Oct 31, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
670 people viewed this question
Jerry Greenberg
Jerry Greenberg
