Question about Meade Optics
The hinge on one side won't tighten down on my etx so it doesn;t remain stationary. The other side works fine.
  • 3,186 Answers
Tnis is the altitude clutch- it's either broken or has grease or oil on it.
See this-
http://www.weasner.com/etx/techtips/etxtu.htm
Posted on Sep 01, 2010
Kitchen aid mixer set ***** on hinge pin doesn't make contact with the pin. What can I do?
If there is a set screw in the hole then tighten the screw up. The hole is threaded all the way through to the one running side to side that takes the hinge pin. If you tighten the set screw up there is no way it cannot reach the hinge pin.
Feb 28, 2016 | KitchenAid Food Mixers
Toro self propelled mower. blade won't stay tight
Use a block of wood to hold blade stationary while tightening bolt. Ensure threads are cleaned with a wire brush before tightening. Is there a spacer or washer missing?
Jun 26, 2012 | Toro Power Lawn Mower
When trying to set up my telescope, in home position and when its looking for its first object the telescope does not move upwards or just using the keypad it wont move up. it makes noise as if it wants...
I assume you have tightened the DEC knob on the side of the fork.
Then the gears are not engaging properly inside the forkarm. The scope will need to be disassembled to fix it. Go to the "Mighty ETX" web site and start reading the posts on the ETX80.
http://www.weasner.com/etx/menu.html
Apr 14, 2011 | Meade ETX-80AT (240 x 80mm) Telescope
Hi, Original focus knob fell off my atx 70 and now the 'focus rod' goes inside the telescope instead of moving front part. Is there any way to fix it?
The knob had a tiny set screw on the side of it-- that tightened down on the shaft.
See if you can tighten it back up. If it is missing take it to a well stocked hard ware store and see if you can find a replacement Allen style set-screw.
Apr 06, 2011 | Meade ETX-70 (240 x 70mm) Telescope
ETX 60 altitude doesn´t work, but motor works
You need to tighten the friction lock - it acts as a slip clutch.
Apr 08, 2010 | Meade ETX-60 AT Telescope
PETROL ENGINE WORKS FINE BUT SAW CHAIN DOES NOT FU DOES NOT DRIVE
It is possible that the clutch has froze, could try taking the side pannel of and seeing if it spins freely with out the chain bar on. If it does, it could be a problem with the chain, make sure its not tightened up too tight and that the chain can move freely over the bar.
Jan 10, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Really Up Sh/t Creek With Fridge Door Hinge (broken bolt)
Put 2 lock washers under the remaining 2 screws and dont over tighten.
This should hold the door fine just do not over load the door.
Go to the hardware store and get 2 new hardened screws if you think you damaged the remaining 2 screws.
If they dont have any that will fit try an auto parts store.
Jan 05, 2010 | LG LBC22518 Bottom Freezer Refrigerator
I have a Meade ETX-90EC. I cannot tighten the vertical lock to engage the motor. Motor works fine (I think, I can hear it turning) but the knobbed dial just keeps turning (clockwise) and never seems to...
It's a simple solution!
Take the knob off, and use a simple washer, will will hold up in between the plastic and metal surfaces.
This should be your solution!
Aug 07, 2009 | Optics
MY ETX-60 DOES NOT MOVE UP AND DOWN !!!!
Go to the Mighty ETX web site for disassemble instructions--
Apr 21, 2009 | Meade ETX90AT Maksutov Telescope with UHTC...
Optics Logo
44 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
