Watch this videos tips:
http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
http://www.fixya.com/support/r10786838-test_procedure_dc_motor
http://www.youtube.com/watch?v=23ZgWaVEQjA
Follow this step, and it guide you if the controller motor OR MOTOR or Sensor speed is faulty.
The
Steps for Newer Style Console Calibration
Locate the calibration area on the
rear or underside of the console (a hole, near the console's center,
that goes through to the electronics board. (This hole should not
have a screw in it.)
Insert a pencil (eraser end),
into the hole and feel around for the cal button (will click
when pressed).
Press the button 2 times
(with the pencil eraser). The first click should show CL11
in the console, the second click should show CL21.
If the process was done correctly,
and CL21 appears in the console, you are in "calibration
mode." The next few steps consists of pressing buttons
on the console and observing settings. This will not require
any other tools.
Press ENTER. CL22 should display
in the TIME window and (??) in the SPEED window.
Press ENTER. CL23 should display
Press ENTER. CL24 should display
Press ENTER. CL25 should
display in the TIME window and (??) in the SPEED window.
Press ENTER. CL26 should
display in the TIME window. You should then see the
letter "E."
Press ENTER. You should see "SS"
or "55" in the console.
Push the STOP/START button. For
safety, at this point, you should step off, or be off, the
treadmill.
Push the ENTER button. The walking
belt should start to move, accelerate to maximum speed, then stop on
its own.
When the belt stops, the
incline should self test by raising to its highest
incline position, then lowering back down to its lowest
position.
Once the incline test is complete,
push the POWER button 2 times. The unit should shut off and the
console should go completely blank. If this happens, the
treadmill is done calibrating and is ready for use.
ERROR
CODE # 7
E7-
1) Alternative Elevation Motor
1)Cause:
Elevation Motor not moving Solution:Check
Elevation Motor connection
2)Cause:
Elevation Elevation Motor screw binding Solution:
Clean screw and lubricate
3)Cause:
Elevation Motor Motor out of Range Solution:
Check motor out of elevation
4)Cause:
E-Motor Potentiometer: Solution:
Replace Elevation Motor
2)Alternative:
Display
Doesn't Light Up:
a)Cause:
On/Off switch Solution:
Test unit is turned on b)Cause:
Insufficient Power Source Solution:
Plug
dedicated120V, 20Amp Outlet
c)
Cause:
Line
Cord Damaged Solution:
Replace Line Cord
d)Cause:
Fuse Solution:
Check Fuse on MCB
Version:1.0
StartHTML:0000000168
EndHTML:0000003648
StartFragment:0000000468
EndFragment:0000003631
The
when pressed).
any other tools.
letter "E."
treadmill.
its own.
position.
The
Calibration sequence can generally be used to accomplish the
following: 1) To reset the treadmill's speed software, if
the running belt seems to be moving faster or slower than the
speed indicated on the console. 2) To reset the
treadmill's incline software, if the walking
deck seems to be elevated higher or lower than
the height indicated on the console. 3) To synchronize the
treadmill's electronic package ANY
TIME a replacement part
(anything electrical) has been installed and is being prepared for
use. 4) This should be the first step performed when
attempting to diagnose or troubleshoot the unit.Calibration often
helps in correcting minor "bugs" in the
software (by "resetting"), before actually having to
replace components.
Before
You Begin:
You
must first determine the model number and style of
unit of the unit being worked on. Do
this by:
Powering
up the treadmill and removing the emergency stop key (usually a
magnetic plastic piece that attaches to the top, center of the
console). If
you
see "10" in the console, it is an old style
console and the "Older
Style" Calibration should
be referenced. If an "SI-1"
appears in the console, it is a newer console. The
following calibration sequence can be performed.
Note:
To change any of the current codes (if incorrect or out
of sync), use the SPEED +
or SPEED
-(minus) button(s).
Refer
to the Calibration
Chart (or the
unit's owner's manual if not on the chart) to verify that the
calibration codes on the unit (represented as "??"
below) are correct.
The
the rear or underside of the console (a hole, near the console's
center, that goes through to the electronics board. (This hole
should not have a screw in it.)
end), into the hole and feel around for the cal button (will
click when pressed).
Press the button 2
times (with the pencil eraser). The first click should show
CL11 in the console, the second click should show CL21.
correctly, and CL21 appears in the console, you are in
"calibration mode." The next few steps consists
of pressing buttons on the console and observing
settings. This will not require any other tools.
window.
the letter "E."
"SS" or "55" in the console.
treadmill.
walking belt should start to move, accelerate to maximum speed,
then stop on its own.
position.
complete, push the POWER button 2 times. The unit should shut off
and the console should go completely blank. If this
happens, the treadmill is done calibrating and is
ready for use.
The
when pressed).
any other tools.
letter "E."
treadmill.
its own.
position.
"F" appeared
in). Troubleshooting the failure would be the next step.
The
when pressed).
any other tools.
letter "E."
treadmill.
its own.
position.
God bless you
There is no noise and doesn't appear to be any attempt for the motor to kick in.
