Question about Kenmore 50522 / 50524 Side by Side Refrigerator
I have a kenmore refrigerator model 59592992. I am replacing the housing unit of the water filer as it is leaking. How do I free the two pieces of tubing from the old housing unit? Can i just cut the tubing as there appears to be plenty of slack to reinsert the tubing in the new housing. If I should not cut it how do i get the tubing to release from the old housing unit?
  • dbixby Sep 01, 2010
    When can I expect to get feedback?
    Awesome... Installed and working like a charm. You the Man!!!!
    Thank you
  • 11,800 Answers
The tubing is pressed in there, it should just pop out when you pull with sufficient power. If it doesn't then the material of the tube has hardened in time and has locked itself on there. Just cut it, even if you will eventually succeed in extracting it , it will just not seal properly again, the material has been stretched beyond its recovery possibilities.
Posted on Sep 01, 2010
  • Azrael SRL Sep 01, 2010
    Glad i could help, i think.
My 2004 Kenmore leaks water at the water filter housing. I put a new filter in but when I wish to get water it overflows at thde top.
Fist issue, plumbers putty should not be used on any water connection for potable (drinking) water, use Teflon tale if you need to. If the leak is at the housing most likely the housing is bad, replace it.
Feb 05, 2015 | Kenmore Refrigerators
Repairman made service call and checked out the frigidaire. Said everything was ok except there was a leak in the inside water filter housing unit, so he went ahead and bypassed the filter since we have...
The filter under the sink should have nothing to do with the water supply to the icemaker. The "repairman" probably cut off the icemaker water supply by "bypassing" the filter.
Jan 08, 2014 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
What is the cubic feet of 2000 kenmore coldspot refrigerator model #59592992?
I believe that the full model number is 106.59592992. Since the fourth digit after the prefix is a 9, I suspect it is a 29 cu. ft. capacity side-by-side refrigerator.
I hope this helps.
Jan 07, 2013 | Kenmore Refrigerators
How do I replace the water dispenser tube for a Kenmore Coldspot model # 106.53769201. The end of the line disintegrated at the spot where you put your glass under the dispenser.
Ice makers and water dispensers are convenient to have on your refrigerator, but can also cause a lot of aggravation if they are not functioning properly.
If your water valves are not defective and you are still experiencing water or ice delays, you may have a clog in your refrigerator hose line.
Instructions and material needed to fix it up.
  • Towel,Flathead screwdriver,New water hose
  1. Turn off the water supply to the refrigerator and place a towel under the line to soak up any residual water that leaks from the hose when you remove it. Unplug the refrigerator.
  2. Disconnect the hose from the back of the refrigerator by pushing in on the collar while pulling the water tube out. If you have a model with an ice and water dispenser, you will need to disassemble the dispenser on the front of the freezer in order to completely remove the water hose.
  3. Remove the water drip tray from beneath the ice/water dispenser and locate the screws at the bottom of the cover (if any). Remove screws and pop off the panel that houses the dispenser. If the unit does not have screws, you will need to pry the cover off with a flat-nosed screwdriver.
  4. Once the cover is removed, you should be able to see the screws that hold the dispenser unit in place. Remove these screws and reposition the unit so you can free the water hose, by pulling it through the dispenser.
  5. Thread the new water line through the freezer door and reassemble dispenser unit. Push the new water hose into the fitting on the back panel, making sure it is properly seated. Turn on water supply and check for any leaks before moving the refrigerator unit back against the wall.
Good Luck and thanks for using fixya.
Jan 16, 2011 | Kenmore 57029 Side by Side Refrigerator
My freezer is working great but my refrigerator is warm on my kenmore side by side refrigerator model # 59592992
Look for frost on the backside of the freezer. You might have a bad defrost heater. It could also be a bad evaporator fan motor.
May 06, 2010 | Kenmore 52632 / 52634 / 52639 Side by Side...
Leak at filter
Nope. You can't bypass the tube style filter... it's the housing that cracked. That has to be removed and replaced. Sorry to give ya bad news, Mariner.
SG
May 30, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Trouble with ice-maker
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Sep 30, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Water line broken for Kenmore refrigerator near compressor
Cut off a piece of line and go to a good hardware store, they can show you how to fix it. Need a coupling, and a nut and ferrel. House water line goes on one end of coupling, nut and ferrel on the broken water line on fridge. A good hardware store will be able to show you how to fix.
Jul 26, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
115 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
