Question about Inverter TB Woods Etrac AC Inverter
TB woods Etrac inverter that quit working and getting "f05" then I get "LO-U" before it shut off. Any sugestions
Panasonic 1250w genius senor inverter less then a year old. Control panel lights up, works.microwave itself does not, control panel shuts off in a few seconds
When a Panasonic Inverter Microwave shuts off after a feew seconds, it is either a bad inverter which is the quite expensive circuit board that powers the magnetron that puts out the microwave energy, or a bad magnetron, Or BOTH typically this would be a costly repair, But since it is still under warranty. You need to find a Panasonic warranty service provider in your area. If it is a counter top unit, you may have to take it to them for repair.
Jul 05, 2017 | Panasonic Microwave Ovens
What causes a red light on an TB Wood Etrac XFC 1001 inverter and the motor will not start Is there an internal fuse Do I need 3 phase for the input
Is that red light flashing or continous lighting? You do not need 3 phase input for that model. Do you have the input wiring diagram? If the red light is flashing maybe the emergency stop input is active. If the red light is on continously then it maybe in stop mode or torque limit, ask electrician to check the wiring.
Dec 31, 2016 | Inverter Electronics - Others
I have an F16 fault on a TB Woods Etrac drive. Can u plz suggest me what should do.
If it is readable copy the data off immediately, if not you need to take it to a data recovery service such as ERS Data Recovery at 1.888.248.3148 What yo depends on how important the data is.
Dec 08, 2016 | Computers & Internet
My inverter seems to be producing too high a voltage when solar input increases, causing the system to shut down and re-cycle many times during the day. I do not see fluctuations in the grid voltage wwhen...
hi
yes there is a voltage regulator of an electronic kind .
I suggest the inverter is well ventilated( if not) and not positioned in direct sun light and shaded as inverters do get quite hot their function better when kept cooler
Dec 11, 2017 | Xantrex XW-4548 Inverter, 4500W, GT,...
How can I fix Toughbook
If you screen was dimming on your Toughbook, then try to
attach an external VGA monitor when the Toughbook is
turned off, then power on the external monitor,
then power-on the external screen.
If the external screen works, then you may have a bad
inverter if you TB is 2007 or before.
If the TB is 2008 or 2009 or later, then probably your screen
is NOT LCD with an inverter but instead LED. Which means
that you have to replace the entire LED screen.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Apr 16, 2014 | Panasonic Toughbook Tablets & eReaders
Blower motor intermittent failure
Change your blower motor resistor, common problem, where certain speeds will work intermittently and eventually complete failure. Located under the dash behind the glovebox. My #5 just quit working, I will be doing this tomorrow. My last TB, same thing happened. My neighbors TB same problem, only her female connector was melted that plugs into the resistor. My current TB is melted too, so I need to replace the connector and the resistor. This problem is so common in TB's and Envoys, it should be a recall.
Jan 03, 2014 | 2004 Chevrolet TrailBlazer
Samsung 2233RZ going black after 1-2sec
First if you can, try the monitor with other PC first to make sure it is not the PC problem.
If it behaves in the same fashion, then most probably has dying power supply due to bad DC filter caps, just see the top side of the caps to ensure it has not bulged up distorted.See the images bellow
12_24_2012_5_33_15_pm.jpg OR
Then there is the logic board. Plug the monitor in but do not activate the power switch so the backlight inverter circuits will be off. Check the 5vdc and the 12~24vdc to make sure they are OK. They should be tested with the load, you can use 6V 1A (6watts) lamp for the 5vdc, and car lamps such as 1157 (12v 8watts lo/26watts high) turn signal brake lamp using high filament connection for testing the 12~18vdc (or use two 1157 in series for 19~24vdc) for the backlight inverter circuits.
If the power supplies are working, the output voltages should be steady at the rated voltages. The power supply will go into shut down if it detects too much current draw due to false in the power supply or short circuits in the backlight inverter or in the logic board.
The backlight inverter circuits:
It takes the 12~24vdc and converts it to high frequency AC to drive the inverter transformers CCFL (Cold Cathode Fluorescent Lamp) assemblies. The transformers will drive the CCFL by applying the start up voltage (around 1500~2000v), when the CCFL start conducting, the voltage will drop down to about 500~800v.
The inverter has detection circuits to detect open circuit if the lamp is not attached or does not fire up after the start up voltage is applied, it will go into shut down. It will also shut down if the lamps draw too much current due to ages (when lamp gets old it will draw more current).
The inverter gets two signals from the logic board, one is the backlight ON/OFF signal, the other one is the Dimming signal for the lamps.
Common problems:
Bad filter caps, resonant caps (in the inverter output circuits), blown transistors/IC, shorted or open transformer winding.
If you are confident with your skill then go ahead else go to an authorized outlet for repairing
Do write back if you face any difficulty while working on the monitor
Dec 22, 2012 | Computers & Internet
HP PAVILION 1000
If you put the old inverter back on and the system works, I'd suspect the inverter is bad. If the system is still a no post after putting on the old inverter, then you may have a motherboard problem now.
Apr 30, 2008 | Dell Inspiron 1501 Notebook
Inverter TB Woods Etrac AC Inverter Logo
180 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
Clint Millett
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
