Question about Holmes Products Holmes HAOF951T-U Blizzard 1 Touch Power Fan Wall Mount
Fan does not osculate all the way. The fan sticks then there is the clicking sound.
  • 10,319 Answers
The worm hear or drive gear that are mainly made of plastic has stripped out. Just don't use the revolving ossulator option any longer
Posted on Sep 01, 2010
Gnev120w Made a noise, now not freezing.
the fan only controls air circulation. not the function of the motor. sounds like ur fridge is stuck in the defrost mode? check ur cold control thermostat with a multi meter for continuity. the fan does not run while in defrost mode, u can manually check ur defrost timer in the fridge by sticking a small screwdriver into the hole underneath it, and turn clockwise till u hear a click u should hear the fan and compressor come on if not turn 1 more click?
Mar 19, 2015 | Beko Refrigerators
Dometic roof air compressor comes on but fan will not replaced both capacitors and thermostat
Sounde as if there is an open winding in the fan motor. There are two sets of windings in a fan motor. The start winding and the run winding.
Here is how you can tell if it is the start winding. Put the unit on and then take a stick and try turning the fan swiftly. If it does start and it could be in either direction, since you have already replaced the capacitors then if the start winding is open then you will need to replace the fan motor. Same goes if the run winding is open.
Apr 14, 2014 | Dometic Rooftop RV Air Conditioner
Overheating with grating sound and vibration
Sounds like you have a cooling fan going out. Open the case a listen closely to see if you can find what fan is making the noise. Verify this by carfully sticking a pen in the fan to stop it for a moment. Replace the offending fan with a new one.
Jan 26, 2012 | Computers & Internet
95 buick regal two fans in front , one make clicking noise after vehicle turned off. Its continues to spin and makes a clicking noise after turning off engine
It is normal for the fan to stay on after the engine is off. The clicking is not. Once the negine is cooled down and the fan is not running. check the fan by spinning it and try to locate the clicking noise. Make sure the fan doesn't wobble. If it does then the bearings are going out, replace the fan. The clicking could be something lodged in the shroud, clicking against the fan blade. Like a stick.
Jul 01, 2011 | Buick Regal Cars & Trucks
I turn on the fan in the bathroom and as the fan gains speed, I hear a clicking sound as it the fan blades were hitting something, and it sounded like it was solid. So I took off the grille and the light...
Are you tightening the grill to the point that it is pulling itself up to touch the fan or is it pulling something down to touch the fan? I would take the grill off and with the fan running, pull and push on the points that hold the grill in place and see if that action causes the fan to click. If it does, you need to trouble shoot from there. If not, an exorcisim might be in order.
Sep 12, 2010 | Home
During a three hour drive back home, our AC stopped blowing cold air. If you stick your hand in front of the vent, you can feel cold air, but it doesn't blow. If you turn the fan up all the way, you can...
Have your a/c pressure tested, the clicking could be the a/c compr coming on and off due to low freon, it will do that so it don't damage your compr when there is none or low freon.
Jun 14, 2010 | 2005 Mitsubishi Endeavor
Hampton Bay Ceiling fan will not come on
greetings home electrition
it's most likely the switch has failed
but on rare ocation the switch comes un wired
also somtimes the switches stick they stick in the on or off position
try pulling the chain and listen for the usual click if it aint there then the switch is pooch if click is there start look at the wires failing that replace the switch
there cheep 2-5.00
Jul 29, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
Fan clicks
Upon the first sentence, that sounded somewhat like a wiring fault, due to the intermittent clicking sounds. However, if you can duplicate the sound by shifting the blades, it could potentially be a motor fault. Try shutting off the breaker to that fan, and seeing if the sound continues when you move the blades. If it does not, then you're looking at a wiring problem, probably on the pivot joint at the base. If it does, you may just have a slightly creaky fan unit, at which point there's not much to suggest, as lubricating the pivot joint could cause the fan to spin at odd angles, or lose control if the fan becomes unbalanced. Also, try reversing the blade direction by toggling the switch on the motor unit, or just below. If the problem persists, please post again with the additional details.
Nov 29, 2006 | Hampton Bay 52 In. Huntington III with...
Holmes Products Holmes HAOF951T-U Blizzard 1 Touch Power Fan Wall Mount Logo
323 people viewed this question
Top Holmes Products Dryers Experts
Jay Finke
Jay Finke
James Coghill
ray gallant
Are you a Holmes Products Dryer Expert? Answer questions, earn points and help others
