Question about Refrigerators
Icemaker in frig will not make ice. the green light is flashing.
  • tkpfister May 09, 2008
    the model number is: HTS17GBSERWW
    Genius:
  • 1,073 Answers
What is the model number of the fridge repost with it
Posted on May 09, 2008
Bought house with frig in it not used for a while fridge works fine turned on water for ice maker water works does't make ice
Is icemaker switch and light on? If so check for plugged fill tube. If not, the water valve or icemaker will need replacing.
Sep 25, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
For some unknown reason the ice maker stopped making ice yesterday. The water line is functioning properly because water is still available from the frig. There is no leak from the water line to the frig....
On all refrigerators with water and ice, they have what they call a duel water valve. One side of the valve will supply water to the door while the other side will supply water to the ice maker. First thing to check is to see if the fill tube is frozen full of water and preventing water from going to the ice maker itself. Next thing to check is if you have a style where there is a laser sensor which is located in the freezer that has one part on the left side and one on the right. You'll notice it because it will have an on off switch and a red light there. If the light is blinking then the laser sensor is bad and you'll need to replace it. If none of this is occuring then check your icer maker. The way to do this is to pull the cover off the front of it. you will then see a white circular gear and holes will letters located around it. Find the holes that say "M" and "N". Get a jumper wire and connect the two and see if the ice maker will manually start turning. If it does, letter it run and listen for a few minutes to see if you hear the water valve kick on to supply water to the icemaker. From my experiance,though, the water valve on the icemaker side doesn't usually go bad and the ice maker or the sensor, if you have one, has gone bad. If there is no sensor or it isn't flashing, change the ice maker. Your part number wll be 1129313 and can be ordered at apdepot.com.
Dec 03, 2010 | KitchenAid Refrigerators
Will not dispense ice or water, beeps when lever is pushed, no interior light in frig part. both frig and freezer work, freezer light works
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Maytag MFI2569VE Bottom Freezer French...
GE Frig has water at door but no ice is made
Pour about 1/2 cup of water into the icemaker . If it dumps , replace the water valve . If not , replace the icemaker . Make sure the coils are clean of dust , etc... at bottom of fridge .
Aug 09, 2009 | GE CleanSteel GSL25JFTBS
I have a PSS26 ge profile fridge and it quit making ice
The icemaker is bad . You have an electronic icemaker and the internal boards cannot take the freezing and the heat (freezing moisture) . Just replace the icemaker .
Jul 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker output very low volume
Hi!!! check your filling tube line going into the icemaker its a white tube that gives water to the icemaker.It might be plugg of ice..get a hai dryer and aim it for 30 minutes good luck..
Jan 05, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
We have a ge frig one year old. the model # is GSH25JFTE BB. I have noticed that there is blinking green light in the back of the ice maker. I have read the owner's manual cannot find a reference for...
A 1/2 second on, 1/2 second off blinking indicates a fault condition with the icemaker. It could be an open or shorted thermistor, or a harvest cycle taking longer than 30 minutes. Check for a stuck ejector - caused by a cube that was not cleared or a mechanical problem. Other causes can be bad icemaker heater, control board, thermal cut out, or bad motor. Essentially, if you don't have a physical blockage, you will have to replace the icemaker.
Sep 09, 2008 | Refrigerators
11 year old amana frig icemaker
you most likely have a short in the ice maker ..the ice should be ejected before the water is call for... you need a new ice make or if you can change the ice maker head let me know and I can help
Jun 27, 2008 | Amana SXD524VW Side by Side Refrigerator
Ice maker has ice in it but will not dump in bin!
before i would worry about the lights flashing lets pull the front cover off of the icemaker and verify that the drive gear is not broken.
on the bottom of the icemaker is 1 screw. remove that screw then just slide the entire icemaker out of the refrig so that you can access the front cover. if the gear is broken just replace the front motor module pt# 8201515
if the gear is fine then located in the toe grille of your refrig is a tech sheet that will help you troubleshoot red light blinking.
Dec 17, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
126 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
