The screen on my gateway m-6307 laptop is cracked, can it be repaired? and where would I take it? thanx
    Novelist:
  • 142 Answers
The screen on this laptop can be replaced. Your best be is to bring it into any local computer shop. You can find your local shops by going to Google and typing in computer repair plus your local zipcode.
Posted on Sep 01, 2010
Tiene bluetooth la gateway 6307
You will find out if you try the following. To turn the Bluetooth radio on: 1 Enable the Bluetooth radio by sliding the wireless network switch to the ON position. If the Bluetooth radio does not turn on automatically, press FN + F6.
Jun 18, 2014 | Gateway M6307 Notebook
Como activo el bluetooth de la gateway 6307
Juan Manuel,
I have to apologize that I can only post this in English. I was able to understand your question though.
You want to know how to turn on the Bluetooth Features of your Gateway 6307.
Try the instructions below:
1. Enable Bluetooth on the mobile phone or other Bluetooth enabled device. This procedure is dependent on the make and model of the phone or the device. You need to see the user manual accompanying your mobile phone or device to see how to enable Bluetooth.
2. Turn on your Gateway laptop. Check the area next to the clock in the System Tray. There should be an icon with a stylized "B" on a blue background. This is the Bluetooth icon. Double-click on this icon and select "Enable."
3. Go to Control Panel. Locate "Bluetooth Configuration" and double-click on it. A window should pop up.
4. Select the Accessibility tab. Check the option "Let other Bluetooth devices discover this computer." A check mark should appear against this entry 5. Select the Local Services tab. Startup type for all services should be set to "Auto."
6. Select "OK" and click. Wait for a few seconds. Your laptop should have Bluetooth enabled by now.
I hope this helps.
My Gateway M-6307 has a backlighting issue. The computer works but the screen is really dim. External output works, but dim on the LCD. I have switched LCDs from another Gateway laptop...same results. I've...
Have u tried replacing or trying a different power supply? Sometimes when a power supply is going bad will not put out the right voltage for the internal switch to kick up the brighter setting. Therefore it still thinks its on battery mode. Test the voltage from the supply and compare it to the recommended voltage gateway suggest for that laptop.
Jun 24, 2010 | Gateway M-6307 Notebook PC
The motherboard in my gateway m - 6307 **** the bed. Is it better to just replace a laptop that is like new otherwise?
um, well if it would be fixable, (it depends on the problem with it) you could maybe find a new mother, cheap on ebay, unless you would just like to go ahead and get a new laptop anyway
Apr 01, 2010 | Gateway M6307 Notebook
How do I take apart my gateway laptop model 6307
Here's a link to the component replacement guide for this laptop model:
http://support.gateway.com/s/Manuals/Mobile/8512949.pdf
You can make use of this document to know how to take apart your laptop.
Dec 20, 2009 | Gateway M-6307 Notebook PC
I bought a gateway laptop last friday and The screen is now cracked. what should I do
when you say cracked, what do you mean? is the display scrambled or is there any pixelized line? since you've just bought it, it would be best to bring it to the shop where you bought it to be repaired or to be replaced.
Nov 08, 2009 | Gateway MT3705 Notebook
My Gateway M-6307 Notebook wont turn on
Ezra, It could be: 1. Dead battery due to faulty Charger. Check the voltage of the charger output. Replace if dead. 2. Dead battery NOT because of charger. You can check it by plugging into the wall socket. Replace if found dead. 3. Faulty power jack on the laptop. Replace it if battery is fine. 4. Faulty power on switch. Needs a replacement. 5. Fault ahead of the switch, then need a professional job.
Nov 08, 2009 | Gateway M6307 Notebook
Gateway M-6307 power dies on boot up (reaches widow screen dies)
Make sure that it must be charged. If you are sure, there might be a problem of overheating.
If you check, there is a CPU fan. Overheating might cause thie.
Use a vacuum to cool on the fan to make it spin manually, hmmm it actually started to work after that.
If not, let me know.
Thanks for using "Fixya".
Jun 18, 2009 | Gateway M6307 Notebook
My computer monitor will not display properly
this is the first way. use external monitor. if you get clear view then you have a problem with LCD INVERTOR (you say bulb).
i hope it works.
May 27, 2009 | Gateway M-6307 Notebook PC
M6307 Gateway Laptops overheats and shuts down
Have you called Gateway? This is definitely a mother board or CPU problem, both probably caused by a slow acting fan. Gateway should replace these.
Jan 05, 2009 | Gateway M-6307 Notebook PC
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
