Question about Sony Handycam CCD-TRV108 Camcorder
Repair LCD screen not working when opened up view is not there. Rotate to mirror position and it works but not in the 90 degree position.
  • 37 Answers
That is your lcd door switch inside the cassing its have to be replaced ..
its not a big job but have to be made by a tech
regards Allan.
Posted on Sep 01, 2010
Testimonial: "Thank you for your answer. Very helpful"
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
Rotate screen back to normal
Feb 23, 2013 | Gateway Computers & Internet
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Feb 15, 2013 | Samsung N120-12GW Netbook
My son has rotated the screen on my fujitsu lifebook s series so now it is upside down! How do i rotate it back? Please help!
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
Jan 21, 2013 | Intel S6240 Notebook
Acer tablet troubleshooting
b>
Jan 14, 2013 | Computers & Internet
Change screen orientation
b>
Dec 14, 2012 | Dell Computers & Internet
Acer aspire d255 the view is like an amblulance or mirror view how can i fix it???
Try pressing Ctrl + Alt + UP (0 degree) or DOWN (180 degree) or LEFT (90 degree) or RIGHT (270 degree) to rotate the screen.
Apr 07, 2011 | Computers & Internet
I have somehomw switched the screen view from ladnscape to portrait byt touching a key on the keyboard when trying to do control alt delete. How can I switch the desktop back to a landscape view
You dont get worry.The problem will be solve.
  • Go to Control Panel.
  • Open the VGA Card Properties (for example if you motherboard is intel then open the Intel Extreme Graphic.
  • After this Click on Rotation Tab.
  • And then You change from here.
Short Keys of Intel Motherboard for rotation.
  • Rotate Normal (<Ctrl> <Alt> Up)
  • Rotate 90 Degree (<Ctrl> <Alt> Left)
  • Rotate 180 Degree (<Ctrl> <Alt> Down)
  • Rotate 270 Degree (<Ctrl> <Alt> Right)
Mar 17, 2010 | Computers & Internet
LCD screen working only if turn counterclockwise
make sure you open the lens 90 degrees to the camcorder.normal operation of the cam will allow you to rotate the lcd to a maximum of 180 degrees and can eve close it with the lcd screen side facing out. you can try pressing the reset button.if it still won't work try removing the battery and unplugging it from the ac adaptor for at least a minute.if still doesn't work properly,issue could be with a bad ribbon inside the lcd that loses contact when you turn it clockwise.that of course would need replacement or repair.
Dec 06, 2009 | Sony Handycam DCR-SR80 HD Camcorder
My screen has rotated how do i switch it back?
You didn't mention by what degree has it rotated, Is it a 90 degree rotation or a complete 180 degree rotation. Anyways here's the solution to your problem.
Hold down Ctrl+ Alt and then press the Up or the Down arrow key to rotate it by 180 degrees.
OR
Hold down Ctrl+ Alt and then press the left or the right arrow key to rotate it by 90 degrees.
Nov 16, 2009 | Samsung NC10-14GW Notebook
Sony Handycam CCD-TRV108 Camcorder Logo
130 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
