Spin switch is broken have part how do I take the back off model #20852
  • 117 Answers
Complete model???
Posted on May 10, 2008
My washer drains but doesn't spin. It makes the draining sound but the motor does not turn. The motor operates during agitation.
Could be the lid switch is broken, It is a safty feature not spin because they lid switch is broken
Dec 30, 2013 | GE Washing Machines
Dryer machine whirlpool does not spin
Be sure the child lock switch is working. If the door is not closed,it won't spin. If the switch is broken, it will not spin.
My door switch broke way back when.I bypassed it.Not a good Idea if you have children.
Feb 21, 2013 | Whirlpool Dryers
Is there a spin ony program?
Broken washing machine Will only offer spin option Try turning off at the main switch and wait for 5 minutes then turn it back on and try again - sometimes they seem to have a mental block
Apr 30, 2011 | Washing Machines
It fills with water, but won't spin to wash the clothes
Without knowing what brand of washer, I would bet that it has a broken lid switch
These can fail and still look good from above but will not allow the machine to
spin out if they are broken. The model and serial number should be under the back
edge of the lid. Make sure to unplug before servicing. Hope this was helpful.
Mar 15, 2011 | Washing Machines
My washer functions on all cycles but will not spin
Generally if a washer will not spin it is due to a broken door (lid) switch. The lid switch
can appear good but may be cracked. You can find the model number under the lid
and google parts for that particular model. Many parts sites have expanded
diagrams to help figure out how it comes apart.
(Generally the two screws on the control panel are removed
and the panel hinges back to access the plug to remove the switch)
Hope this helps.
Mar 06, 2011 | Roper Washing Machines
I have a Kenmore Model number 20852 washing machine. The motor runs and the water drains but it will not spin. Any suggestions?
You may have a damaged or broken motor coupling. Whirlpool manufactured top loading washers (such as your Kenmore) use a motor coupling between the drive motor and gearcase (transmission) in place of a drive belt. This configuration is known as "direct-drive". The coupling can break through normal wear and tear. Washing frequent loads of heavy items and reduce the life span of the coupler. The following link explains how to replace one:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number for a replacement motor coupling is inlcuded in the link I provided. Replacements can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I have listed also included helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate along the wash tub rim under the lid) and let me know. I hope this helps you.
Oct 07, 2010 | Washing Machines
I filled my washing machine with clothes tonight and it got to the end of the short cold wash cycle and had stopped running so I pushed in the knob then pulled it back out and then pushed it back in and...
It sounds as if the machine doesn't spin during the spin cycle. Normally the agitator stops spinning, fairly quickly, if the lid is opened during the spin cycle.That safety circuit includes a switch mounted under the opening and is set by a tab on the lid that protrudes thru a small hole in the top of the washer. The most likely failure on most Kenmore models is that switch, broken or loose, the tab on the lid broken, or the two misaligned. I would need the model number of your washer, located on a tag on the bottom of the lid to be more specific
Jan 07, 2010 | Kenmore Washing Machines
Kenmore Series 80 Washer, Model 20852 - Agitator not turning well, making noise
Hi, If the washer spins properly but the agitator does not work, it could be the dog kit needs replaced. If the washer does not agitate or spin, it is probably the coupler.
Put the washer in wash cycle with no laundry in it and see if the lower prt of the agitator moves. If the agitator moves, try and hold the upper half of the agitator and see if it will only move one direction.The agitaor dog kit is designed to only let the top part of the agiator to grab one way. When they go bad, they can make some noise.
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16” bolt and lift the agitator out of the washer. Separate the 2 halfs of the agitator and replace the dog kit inside the upper part of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | Washing Machines
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
