Question about Mintek DVD-3610 Multi-disc DVD Player
I have an Mintek DVD-3610 player. The standby light is on but the player will not respond to any button that is pushed or to any function on the remote, which includes power and eject.
5 Suggested Answers
  • 4 Answers
SOURCE: mintek 263
I understand your problem. Please try my solution and even though it is the same manufacturer but a different model number
but I think it will work. I have posted my solution in this site
and also other fix-it sites but I will post it here for you.
Late last year, my friend had the same problem. She and her friends tried for two months but it was impossible to physically pulled the stuck DVD out from the unit. I was happened to be in the area and she asked me if I can help her retrieved her movie
DVD disc which was stuck inside the MinTek DTV-265-D.
GOOD NEWS! I was successful in getting the
stuck DVD disc out of the unit and back into her hands.
Here is what I did to fix the stuck DVD problem:
I. Requirements
a. Tools:
Phillips Screwdriver (magnetic head will be the best)
Tweezers - Only if you don't have a magnetic Phillips screwdriver
Flashlight
b. Surface:
Large flat padded table because you will need it to lay the TV - flat.
c. People:
I did it by myself but having an extra hands is a plus.
II. Instructions
1. Disconnect power cord, power switch button "off" position, unplug cables and video cables from the unit.
2. Place the TV unit flat on the surface - screen on the bottom - Back cover side facing up
3. Back Stand: Remove the TV bracket stand in the back by unscrewing the 8 screws.
4. Back Cover: Unsecured the back cover panel side of the unit - 9 screws (After unscrewing the screws you might need to use the tweezers to lift and remove the screws.)
5. Back Cover: Carefully lift (unlock) the back cover panel slightly away from the screen unit slowly because it is wired to the circuit board. In other words, you can't remove it completely which it is OK and it is not necessary. This back cover panel removal sounds easy but the cable coaxial connector block it and making it difficulty.
Therefore, you will have to wiggle the cover until it is free and away from the coaxial connector because you will need some clearance space to access the DVD unit.
6. DVD Unit: Unlock the DVD unit by unscrewing 4 (silver) screws.
7. Now you are set and ready to release your stuck DVD.
An extra hands will be nice to have but two hands is a requirements to do the next couple of steps.
8. DVD Unit:
On the front side, locate the two (black triangle-shape or arrow shape) slot holders.
They are in a locked position.
Using your fingers lift and hold both sloth holders in the up position.
(You might have to raise these holders (up and down) several times.)
As you are holding up these slot holders please perform the next step (#9).
9. Power:
Push power button on the unit switch "on"
Plug back the power cord into the unit AC inlet
Unit Ready Light: "red" standby light is on
Remote Control: Press the power/DVD button - st the remote to DVD Unit Ready Light: "Green"
** Important: Step No. 8 and Step No. 9 must be done simultaneously **
10. VIOLA! The DVD disc will automatically slide out of slot from the DVD unit.
Good Luck.
William
Posted on Feb 15, 2008
clark_styx
  • 282 Answers
SOURCE: Mintek Passwords
I believe the password code is 88888. This is factory set this way and can be changed
Posted on Oct 20, 2008
SOURCE: won't eject disc
I use a produce bag twist tie or a very thin pearing knife. After you push the eject button slide the twist tie in the bottom of the disc slot and the dvd should pop out.
Posted on Jul 15, 2009
SOURCE: Device code for mintek dvd. No code for mintek dvd
Hi my nameis Mike Houston of DISH Network and I see where you want the code for theMintek DVD-1600 to program to the DISH Network remote. We currently do not have any codes for theMintek DVD player; I will send a link to help with a Power Scan, http://www.dishnetwork.com/SupportSection/power-scan-instructions.
Posted on May 03, 2011
Tip
Known Mintek DVD Code Hacks
window.google_render_ad(); Mintek MDP-1010 / MDP-1020 / MDP-1030 / MDP-1070
  1. Press SETUP
  2. Go to "Preferences"
  3. Press 255 135 (or 225422)
  4. Press LEFT and DOWN quickly
  5. Current RC should be displayed
  6. Press the button for the desired RC (0 = codefree)
  7. Press SETUP
Mintek MDP-1060
  1. Press SETUP
  3. Press 253 135
  4. Press LEFT, DOWN, ENTER, SETUP quickly
  7. Press ENTER, SETUP
Mintek MDP-1720
  1. Press SETUP
  3. Press 215 345 (or 251251)
  7. Press (PLAY,) SETUP
Mintek MPD-1730 / MDP-1770
  1. Press SETUP
  3. Press 251 131
  7. Press SETUP
Mintek MDP-1750 / MDP-1810
  1. Press SETUP
  3. Press 251 345 (or 252315, 251251, 255135, 253135, 251251, 251422 / 212425)
  7. Press SETUP
Mintek MPD-1760 / MDP-1815
  1. Press SETUP
  3. Press 224 455
  7. Press SETUP
Mintek MDP-5860 / MDP-5861
  1. Press SETUP
  3. Press 222 443 (or 222443, 242112, 221441 [->MDP-5861], 224441, 245512)
  7. Press SETUP
Mintek MP 1710
  1. Open & close the disc tray
  2. Push SETUP on the remote control
  3. Push 1, 3, 6, 9
  4. Push the left menu arrow button 3 times -- NOT the |<< or << button
  5. Push the right menu arrow button 1 time -- NOT the >>| or >> button
  6. If you see a new menu item named "VERSION", enter that menu
  7. Change "REGION CODE" to 0
  8. Press SETUP
Mintek DTV-233 / DVA-8700 / DVD-1500 / DVD-1600 / DVD-1710 / DVD-2110 / DVD-2580 / DVD-3610 / DVD-5830 / DVD-8350 no known hacks
on May 29, 2009 | Mintek MDP-1770 Portable DVD Player
Device code for mintek dvd. No code for mintek dvd in my user guide for dish network to control power for dvd on my dish remote.
You may want to search for the code by performing a Power Scan, I will include the steps below. If this doesn't resolve this there is most likely a compatibility issue.
Power Scan:
1.) Press and hold the correct VCR button (about six seconds) until all mode button backlights come on, then release.
2.) Press 500 pound (#)
3.) With the desired equipment on, press and hold the VCR/DVD button until all mode button backlights illuminate (about 3 seconds), then release.
4.) Press and release the Power button.
5.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
6.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
To verify the code works try several different functions for that equipment.
Daniel Busa
DISH Network
Customer Service
May 01, 2011 | Mintek DVD-1600 DVD Player
The red light is on, but with the remote, and by pressing the power button on the box, nothing happens.
it could be that the DVD Player is on Standby and need to do Hard reset <br /> If you want to fix the DVD Player write to me , <a href="mailto:doron_c21@yahoo.com">doron_c21@yahoo.com</a>
Aug 26, 2010 | Mintek DVD-1600 DVD Player
Can't get my CyberHome CH-DVD 300 working
Check for bad capacitors on the alimentation fead target
Sep 01, 2009 | Cyberhome CH-DVD 300 DVD Player
Won't eject disc
May 10, 2009 | Mintek LCD TV Progressive Scan DVD Player
Mintek dvd player, model mdp-1030
Mintek MDP-1030 DVD Player Description:Mintek is one the largest suppliers of DVD players in the global marketplace today. Mintek has taken the next natural step in the evolution of the company's product line combining leading DVD technology with state-of-the-art LCD technology.PRODUCT FEATURES:
Versatile playback formats;
Anti-shock function - mobile or pedestrian;
Built-in stereo speakers;
Auto power off for saving energy;
Quick connect to TV;
Digital Coaxial Output;
AV input/output;
Brightness/Color/Display mode adjustment;
High capacity rechargeable Lithium-ion battery pack;
Full function remote control.
Product Specification: DVD Player DVD Type DVD player Media Supported Kodak Picture CD, CD Portable Yes Form Factor Portable Remote Control Remote control Additional Features Auto power off Audio Features Audio Output Stereo MP3 Support Yes Connectors Composite Video Outputs 2 x headphones ( mini-phone stereo 3.5 mm ) 1 x digital audio output (coaxial) 1 x composite video/audio input 1 x composite video/audio output Power Battery Type 1 x DVD player battery - rechargeable - lithium ion General Product Info Weight 4.6 lbs Also known as Mintek MDP-1030, Mintek Manufacturer Part No. MDP-1030 Company Info Mintek Dimension 1.6 in x 10.1 in x 6.6 in (HxWxD) Model DBMDP-1030
Aug 17, 2008 | Compaq Presario Notebook
How to make mintek MPD 1760 code free
1. POWER ON
2. PRESS ‘SET-UP’ BUTTON
3. SELECT THE ‘PREFERENCES’ MENU (PRESS CENTER ARROW BUTTON THIS IS THE ENTER BUTTON)
4. INPUT THE PASSWORD CODE 224455
5. PRESS ‘LEFT’ AND ‘DOWN’ BUTTON (NOW THE SCREEN WILL SHOW ‘REGION CODE 1’)
6. PRESS NUMBER BUTTON (2 TO 6) TO CHANGE ZONE. (TRY 10/0 BUTTON FIRST, IF ACCEPTED THEN PRESS SETUP, YOUR PLAYER IS NOW REGION FREE)
7. PRESS ‘SETUP’ BUTTON TO EXIT.
May 05, 2008 | Mintek MDP-1760 Portable DVD Player
Standby
Hello, This unit has a standby button, could that be selected  -IF not, I am not sure what is causing the problem you describe however you can find the product manual here - http://www.memcorpinc.com/html/product_detail.php?PID=43&FID=9&SID=2&opento=1008#
Good Luck - Dr. Know
Dec 21, 2007 | Memorex MVD2042 DVD Player
Mintek DVD-3610 Multi-disc DVD Player Logo
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
