Question about MSI K7N2 (MS-6570) Motherboard
How do properly connect the h.d.d led cables to the motherboard?
  • Esteban Samaniego Sep 01, 2010
    thanks but i dont have the manual to the motherboard. is there another way to doing this with out the manual?
    YES finally than you this is exactly what i needed.
  • 1,472 Answers
Esteban_s_88
You can download the manual for your motherboard from this link.
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=519
Also here is an over view on connecting hard drives to your computer.
http://www.fixya.com/support/r5826174-connect_hard_drive_motherboard
Let me know if you have any problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Sep 01, 2010
  • 503 Answers
  • Locate the cables for the power button, reset switch and hard drive LED. The cables are connected to the interior of the front plate of the pc case. Untie and separate the cables if needed.
  • 2 Flip the cables over to read the names labeled on the connectors. For example, the label for the hard drive cable typically reads "HDD LED."
  • 3 Refer to the motherboard manual for the locations of the PN1 and PN2 connector groups. Connect the cables to the designated connectors to ensure proper installation.
  • 4 Find the corresponding set of pins for the power, reset switch and hard drive LED on the motherboard. The pins are typically labeled "PWSW," "RESW" and "LED."
  • 5 Connect the cables to the corresponding set of pins by lining up the black wire of each cable to the pin labeled "GND," meaning ground.
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    3 Suggested Answers
    SOURCE: compaq 252608-001 motherboard
    Its not written on the board...
    All that's written on it is the P codes, which are damn hard to read as it is, never mind trying to read anything on it...
    Spkr and HDLED, and PWRLED are all marked, but the pwr and reset arent... or if they are, i cant find them
    Posted on Jun 07, 2008
    • 34 Answers
    SOURCE: How to connect power led ,HDD,Reset,power SW cables in hp motherboard s/n 383620-001
    check your motherboard manual if you do not have it go to www.support.hp.com and look for manuals based on the model. this should give you detailed instructions as to which pins you plug those cables into. usually they are located towards the bottom of the motherboard to the right of your PCI Expansion slots
    Posted on Aug 20, 2008
    How to conect front panel
    For this you need the motherboard manual.
    If you do nor have it, download it.
    The setup procedure will be at the beginning, after the specifications. The two cables from the front panel that are important are the (power on , LED reset) cable, and the USB cable.
    Both these cables are built to the Intel developed, case standard, on most PCs.
    The problems start when you are building a PC with an old case. The wires from the front panel will be all separate.
    The motherboard manual will have the location of the pins, and the "pin out" for the motherboard.
    The color lead is positive, and the white is negative.
    The speaker wires are red and black, and the polarity does not matter.
    Do them one at a time. Start with power on, when you have found the proper pins and hooked up the leads, then reset, then power LED, then HDD LED, and last the speaker.
    Then find the USB pins and connect the USB cable to the motherboard.
    The PC should boot, assuming the other components are installed.
    Sep 02, 2015 | Computers & Internet
    LED lights on GA-Z77-D3H motherboard will not turn on the LAN port plugin after plugging in cable from modem. Can't get internet access. Thanks
    First check the cables in proper condition and connection. If everything ok and LED do not glow, then we have a bad news in hand. Last step u can try is reinstalling the OS ( so that any other drivers may not conflict with LAN drivers). But still 99% i think it is a motherboard problem. Ask ur company to change the motherboard
    Jul 20, 2014 | Computers & Internet
    Sir, I have connected all cables. but when i power on. green led light on board is present. but nothing else is working including fan.
    maybe the cables are not inserted properly.
    try re-inserting all those. and make sure you don't forget anything else to attached.
    check this.
    1.power cables.
    2. ide cables
    3. sata.'s
    4. memory's
    5. video card.
    even your vga cable for your monitor check if it's properly inserted.
    hoe this helps..
    Jan 29, 2011 | ASUS A7V400-MX Motherboard
    LAN not working,i mean that LAN led not blinking.and i fail to connect internet connection.Plz give me suggestion....
    try unplugging the cable and insert again ...
    check if any lose connection ............... install your lan s/w properly ........
    Feb 09, 2010 | Intel Motherboard
    No video flashing, green power led
    power red flash and not operating system
    Aug 26, 2009 | Computers & Internet
    When conputer is turn on but system is neither display nor booting and 10 times amber leds are blinking.
    1. check whether the bus connected with the hard disc is connected properly
    2. check whether your ram is ok
    3. check whether all the cables connected properly
    4. it might be also due to damage of your vga
    5. also see whether our processor is working properly
    Jun 15, 2009 | Computers & Internet
    Lookig for a manual for an fic au13 motherboard
    Front Panel Block Cable Connections
    f_Panel
    1 3 5 7 9
    2 4 6 8
    1] HDD-LED (+)
    2] Dual Power-LED* (+)
    3] HDD-LED (+)
    4] Dual Power-LED* (-)
    5] Reset Switch
    6] Power Switch
    7] Reset Switch
    8] Power Switch
    9] Dual Power-LED* (**)
    * Single Color Power-LED 2 or 3 pins:
    1 2 3
    1]Power-LED (+)
    2] GND
    3] GND
    ** Dual Power-LED:
    if useing dual power LED,
    Green: pin2
    Yellow: pin4
    otherwise, Pin2 is positive (+) Pin4 is negative (-
    For future Reference you can download your manual directly from the manufacturer's website HERE
    Or directly from HERE
    May 30, 2009 | FIC AU13 Chameleon Motherboard
    Ga-8sr533 hdd led not working
    May be , you didn't connect the connector of ur LED on motherboard.
    or it's not connected properly.Please refer motherboard manual for the same.
    Thanks,
    Mukund
    May 15, 2009 | Gigabyte GA-8SR533 Motherboard
    ASUS P5RD2-VM MOTHER BOARD - lan port is not working not showing led on lan port jpshah j5p10shah65@yahoo.com
    You have to install lan card driver to show your lan connection.
    Check the cable is connected both end properly and other end pc is connected modem or switch is turned on.
    Aug 26, 2008 | ASUS P5RD2-VM Motherboard
    Front Panel Connector
    There should be a Front panel block on the motherboard
    you should connect to it like this
    Nov 14, 2007 | Foxconn 661FXME Motherboard
    MSI K7N2 (MS-6570) Motherboard Logo
    383 people viewed this question
    Top MSI Computers & Internet Experts
    vsri9
    Alun Cox
    David
    David
    Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
