Tip & How-To about Office Equipment & Supplies
Most machines have this problem.I have solution for it.
first, machine turn on and remove batteries one by one.
then machine display no battery.
replace battery one by one again machine display ***MRS***
press CL Key. error is didnt apper again.
but your data is lost your company name,tel number like.
programme data again.
The way to tell if your NordicTrack digital console is bad is to troubleshoot it first. If nothing works, you've got a bad console. The digital console is an important part of exercising. A manual machine will still work even if the console doesn't, but an automated machine needs the console to work so you can adjust things like speed, resistance and incline. You also can't use programs or see your time, distance or estimated calories burned without a working console. The two most common reasons that a console will be dim, display bad results, or won't turn on are bad batteries and a problem with the reed switch.
