FixYa.com
Tags:
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
How did you remove the top cover to get at the arm... (by 2 users)
posted by ZZeasy on May 09, 2008
How did you remove the top cover to get at the arm for the cable drive? (I don't want to break anything else!)
Comment by ZZeasy, posted on May 09, 2008
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Spring2008, posted on May 16, 2008
I am trying to asseble the top part of the hoover windtunne bagless vacuum cleaner..But its not easy to get in and I don't want to break it.
Please advise,
Thank you,
Ingrid Justice
Best Solution
posted on May 13, 2008
FixYa! (100)
reddevil6
Rank:Guru Guru
Rating: 87%, 974 votes
Turn it over, remove the plate over the brush roll, remove the cover over the intake hose, then there are 2 screws, one on each site, remove them, then using a flat blade, there is a slot on each side, from the bottom, push it in to release it and then the top will come off.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Vacuums problems?
Vacuums
where is the repair center
where is the repair center for... Answer This...
Vacuums
how to install front wheels
how to install front wheels on... Answer This...
Hoover U6437-900 / U6439-900 Windtunnel...
bag lid assembly wind tunnel...
I need this bag lid assembley.... Answer This...
Belt Stretched on my Hoover...
Roller brush was turning... Answer This...
Brush Roll belt won't engage on...
I replaced both the flat belt... Answer This...
Repair Service
Find Vacuum Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
