Question about Haier ESA3067 Air Conditioner
First day using the esa3067 and when the a/c is on the unit shuts off after about 5 minutes. It keeps doing this, it wont run the a/c for longer than 5 min...
  • Haier Master
  • 17,130 Answers
Is the temperrature setting set to a level that is lower than the room temperature. If not set the thermostat to a still lower level and check. If the fault is still persisting then the thermostat can be faulty. If your AC is a new one it will be better to get the warranty on the machine than to do any work on it.
The controller unit can also be an area of suspect.
Posted on Sep 01, 2010
Turned ac off while running well turned back on to soon
shut unit off and wait at least 5-10 minutes before re-starting. do not want compressor to struggle to start. good luck!
Jul 08, 2015 | Dometic Rooftop RV Air Conditioner
I have a FDL70S1 Frigidaire 70 pint dehumiifer that runs for 3 minutes then shuts off. I have tried to set the timer for it to run longer but it wont. Do you know what is wrong with it?
Hello lynn crisp, thank you for your post!
From what you have explained regarding your Frigidaire dehumidifier it sounds like the sensor or control panel has become faulty. I would recommend resetting your dehumidifier and you can do that by unplugging the power cord for ten minutes. Is your dehumidifier under warranty? If so, you may want to reach out to the manufacturer for a resolution to the problem. I hope this information is helpful. -Matt
Oct 20, 2014 | Frigidaire Dehumidifiers
Natural gas generator shuts down after about 5 minutes and won't keep running.
How big a unit? Model number? Alarm codes? If it runs for 5 mins check the obvious, coolant level, oil pressure and sensor,
Nov 07, 2012 | Caterpillar Electrical Supplies
My haier a/c model esa3067 wont turn whit out the remote but i have lost the remote how can iturn i tryed pressing the power botten on the ac but didnt work
It have the same one, but pushing thr power button does work. Are you sure there isn't a blown circuit? Double check your outlet with another device...like a lamp. Sorry I can't help more.
May 26, 2011 | Haier ESA3067 Air Conditioner
I have a Goldstar GHD30 dehumidifer that I bought used last week. It's pulling 20-30 pints of water each day out of my basement so it appears to be working. The compressor only runs for 1-2 minutes at a...
yes cycles should be longer either that or the unit is keeping close to desired humidity. Also the unit is under sized 30 pint is for 400sqft. or 20 by 20 room. humidity should be 30/50 percent check your level desired room temp is 70 degrees but its a basemnt 60 works.
Jul 28, 2009 | Goldstar DH504EL Dehumidifier
Patio heater keeps shutting off
Returned it to Home Depot, paid $50 for upgrade to "better" unit.
Sep 28, 2008 | Coleman (5040B750) Patio Heater
Haier ESA3067 Air Conditioner Logo
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
