Question about Sony Televison & Video
My tv flickers picture in and out when i first turn it on,but the sound works fine. then after awile it works fine. model # kv-27hsr10 trinitron.
  • Sony Master
  • 17,129 Answers
If you are hearing a click and the shut off and on during the time of the set coming to start up, then is possible that the Line output transformer is having a leak and then clearing up later to steady.
Open the back cover and clean up the dirt in the LOT. Now with the back panel taken off - with precaution not to touch any parts- put the set on and listen to any ticking noise.
If so shut off and solder the section from where you re hearing the noise. If the fault still is persistent, the check on the capacitors in the Power, Horizontal vertical and HT.
If you suspect that the set stabilises on heat , use a hair dryer to heat up the circuit in suspicion, then centre on to the component.
Posted on Sep 01, 2010
  • Sony Master
  • 1,210 Answers
You definitely have a bad capacitor and there are bad grounds that need resoldered. You will have to replace the capacitor or two or three. I would certainly look for those in the 200 volt range to 1Mf to 4.7Mfs as most likely to replace. Also you should resolder the vertical IC chip. This is a most common problem here! Thanks for asking!
SONY KV-32xbr50 intermittent
The fault is with some loose contacts. Check and rectify this. There is no more components to replace. Look for any loose solder terminals. That is all. But it will be a difficult task to reach to the exact point of fault.
Oct 01, 2012 | Sony KV-32XBR450 32" TV
I have a tv sony trinitron model KV-32FX68E 32''.
try to plug the tv to other socket that is working before suspecting the tv set
Jul 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Screen flickers upon power up
Looks like your picture tube is dying, or there is a bust capacitor(s) inside...I'd recommend taking it to a service shop to get it repaired.
Cheers!
IrishDruid
Jan 08, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Picture and sound go away after 2 minutes
Protection circuit fault kicks in. No vertical Deflection (V STOP),B+ over voltage protection (OVP), This is about a $150 -$200 to fix.
Nov 04, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
Aug 29, 2006 | Sony KV-32S35 32" TV
Flickering
When you say flickers?? does the sound stay on or does the whole set go on then off or is it just the picture that flickers on and off and sound does flicker too? need more info please.
May 06, 2006 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Televison & Video Logo
69 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
