Question about Proscan Televison & Video
Our Proscan 42 inch LED TV (only one month old) just started going fuzzy. There are green horizontal lines going across the entire screen. If I reset the TV (turn off and unplug) for a minute or so, then turn it back on, it works fine for a few minutes, but then goes fuzzy again. It does this whether the signal is coming from TV or DVD player.
  • Proscan Master
  • 17,130 Answers
Possible fault in the convergence circuit, failure of the IC. I advice that you must not tamper on the TV but ask for the warranty replacement without even opening the set. You are entitled to this service and must not throw it off. So call up the dealership and register your complaint .
Posted on Sep 01, 2010
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
Horizontal lines on SONY TV
the ribbon flat connection tapes that connect the led panel driver to the panel have prob delaminated
this cant be repaired easily and you would need to replace the panel
Dec 05, 2014 | Sony KDL40EX520 Bravia KDL-40EX520 40 Inch...
Samsung 53" LED TV ....4 yrs. old. ....has thin horizontal lines (1 pixel wide) across entire screen
are the lines going left to right or up or down? if up or down probaly a bad panel,iff left or right either the upper or lower buffer board is bad
Nov 28, 2014 | Samsung Televison & Video
VIZIO 42 CLASS RAZOR LED SMART TV M420KD picture has lots of green ghosting and thin white vertical line through left side of screen also
Hi Charlene,
please try with video input from any device,and i think you are using local antenna and it has gain problem or your tuner section of the tv is not working correctly.
if distroted pictures comes with video input signal it is video amp and processing unit problem.
you have to go for repair shop for fix that.
regards,
nuwan
Jan 24, 2014 | Vizio Televison & Video
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
Single green line spanning across the screen horizontally
I was just watching TV and all of a sudden the screen minimized down to a single green line spanning across the screen horizontally. The label in the back says it was made in 1996 so it is an old tv. Can anyone help?
Apr 08, 2009 | Mitsubishi CS-27205 TV
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Nov 25, 2008 | Vizio GV42L 42 in. LCD Television
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Toshiba 42 inch rear projection TV
You likely have a bad hyper board.  As time goes on the lenght of time it takes to get a clear picture will increase and eventually the picture will never clear up untill the part is either repaired or replaced.
Oct 23, 2007 | Toshiba 42H83 42" Rear Projection...
Televison & Video Logo
252 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
