Question about Panasonic KX-TG1033S Cordless Phone
My Panasonic DECT 6.0 telephone shows a "line in use" message although no phones are plugged in other than the base unit. I have verified that the telephone line is working adequately. I reviewed the troubleshooting in the manual and reset the line from B to A and back again. The message still shows. Can you help?
SOURCE: Almost constantly gives "no link to base" message
I had this problem too. I popped the battery out, waited 1 minute then put it back in. Unfortunately this clears the memory of all recent calls, etc. but it immediately started working again. So far its only happened once...
Posted on Mar 31, 2007
Noggin
  • 944 Answers
SOURCE: Hard reset of KX-TCD580 Base
Go to this link; http://panasonic.co.uk/customer-Support/download-centre.asp and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
Posted on Apr 01, 2007
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Posted on Jan 16, 2008
SOURCE: Panasonic base unit went dead
THROW IT AWAY.  I HAVE THE SAME PROBLEM AND PANASONIC AFTER SALES "SERVICE" PEOPLE  HAVE BEEN COMPLETELY USELESS!
Posted on Mar 23, 2009
SOURCE: Static on Telephone Base Unit
Try powercycling the basephone and remove the battery from the cordless phone, wait for 10 sec and then reconnect the battery, after that connect the power to base phone,probably it will fix the issue.if your phone have the option to change the channel,try changing the channel to 11 or 6.try and get it fixed.
Posted on Apr 02, 2009
Why doesn't phone work?
Disconnect the base and try the telephone link with standard /regular telephone to verify the line.
then reconnect to Panasonic and verify
Apr 08, 2016 | Panasonic DECT 6.0 Expandable Cordless...
Just got a new kx-tg7643m system. all handsets and base show message. new voice mail. there are no messages in the answering machine. ? how to erase the message. thanks.
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when people call while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Aug 01, 2012 | Panasonic Kx-tg7643m Cordless Phone - 1.90...
Panasonic phone handset display not working
Hi Nergeshb,
First try relocating the base unit for testing purposes, to ensure that the unit is plugged into a working telephone jack and that the adapter is plugged into a working electrical outlet. Verify that the in-use charge light is lit.
Additionally, there may be interference if the base unit is located near any appliances, or if it is plugged into an outlet with other devices. Try plugging the base unit into an outlet of its own.
If you are still experiencing a problem after these preliminary tests, you should reset the phone. To do this, remove the battery from the handset, and disconnect the adapter and phone line. Leave the unit disconnected for 1 minute. Put the battery back into the handset and then place the handset on the base unit. Reconnect the adapter and phone line. Then test the unit.
Thanks for using Fixya.
Please rate the this solution for your problem.
Nov 02, 2010 | Panasonic Lands Phones
Trying to find out how to get my messages have a panasonic dect 6.0 plus telephone
http://service.us.panasonic.com/OPERMANPDF/KXTG9391T.PDF
In page 36,37,38
Gives you clear idea about how to get your messages about how to Listen using base unit and Listen from handset...
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 30, 2010 | Cell Phones
Searching and out of range message keep appearing. Can't dial out or receive calls Uniden Dect 6.0 (both phones) Tried to register base but unsuccessful.
This is because of the following reasons
1.The handset is far away from the base unit.Try to bring the hand set near the base unit and try.
2.The base unit is not plugged in to the power supply.Please check it.
Thanx
Jul 27, 2010 | Uniden DECT 6.0 Cordless Telephone...
Handset out of range
I'll give it a shot. Have you tried re-regestering the handset? Press and hold down the "end" key (on most models it looks like a red handset) while holding that key down, press and hold the # key, after a few seconds the unit should beep and show:
(SYSTEM RESET)
Deregister HS
BaseUnavailible
Useing the four-way key select "Base unavailable" and press the menu key The LCD display should then show :
"Which Base?"
Base #1
Select base one and then the display will show
"Base Unavailible
Yes
No
Select "Yes."
Your handset is now unregistered. To re-Register the phone to the base do the following. If the base unit has a charging cradle, just set the handset in it and it should register on its own, if you have a cordeed base, or the unit will not register when you set it in the cradle on the base go to menu and select register handset, then press and hold the # key on the handset for 2 - 3 seconds, it should beep and then start the registration process. If you have 6 handsets registered to your base, you will need to de-register teh non-working unit from the bases memrey before you will be able to re-register the handset.
Jun 14, 2010 | Uniden DECT 6.0 Cordless Phone ID
I have a Uniden DECT 6.0. How do I delete the
This probably applies to your model:-
From the expansion handpiece - while the message is playing - hit the 4 button - or 4:delete button.
From the base unit - while the message is playing - hit "delete".
You can only delete all messages at once from the base unit.
Mar 29, 2010 | Uniden DECT 6.0 Cordless Telephone...
Message reads: "Check tel line"
You can remove your telephone line from the base unit and fix it to stranded telephone unit and hear the dial tone.If it heard then some inductor or else part may be broken inside the base unit due high current surge.If the dial tone didn't heard from the other phone also check for the corroded line cord or modular box fault with the tel line.There should be 30 Volt-50Volt D.C.Voltage at your wire ends.
Rana.rishanranatunga@gmail.com
May 18, 2009 | Panasonic KX-TG1033S Cordless Phone
Let our Experts solve your "Panasonic tga101cs base will not play back messages The message is recoverable from the 3 hand sets" Problem
I've just got a 2nd system of 3 handsets (KX-TG1033, DECT 6.0). I have also the same sytem in my house. Is it possible to expand 3 new hansets (number 4,5 and 6) to my existing base unit?
Mar 23, 2009 | Panasonic KX-TG1033S Cordless Phone
Panasonic KX-TG1033S Cordless Phone Logo
689 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
