The first step that should be taken is to shut down the laptop. This can most likely be done by holding the power butting down for 10-15 seconds. The next step is to restart the PC and see what happens. If it boots up correctly than this have have been just a one time issue. If after restarting the laptop it will not boot than some trouble shooting steps should be taken. When
starting the PC your getting power? If not than there is an issue with the
power supply or battery. If you are getting power to the PC than you should listen
for the beep code on start up. 1 beep after starting the computer
signifys that the power on self test (Also known as the POST) has
completed with out issue. When getting any other type of beep code you
should research the meaning of the code. Beep codes differ from company
to company. The best way to identify the meaning of a beep code is to
type the manufacture, model and number of beeps into Google. Another
possible issue is that your hard drive is corrupt. If this is the case
than your computer will pass the power on self test(POST) but will have a
message like MBR not found or one of many other errors. If you are
getting an error than it is also a good idea to research the error to
determine the proper fix. If the PC seems to boot correctly but there is
no image on the screen than the issue may be a result of a bad video
card. In that case the video card will need to be replaced.
I hope that information above has helped is some way.
If possible please rate this solution.
