Question about Dell InspironTM 1501 Notebook
Won't boot up - Dell InspironTM 1501 Notebook
    Novelist:
  • 142 Answers
There are a few different issues that can cause this type of problem. If when starting the PC your getting no power than there is an issue with the power supply. If you are getting power to the PC than you should listen for the beep code on start up. 1 beep after starting the computer signifys that the power on self test (Also known as the POST) has completed with out issue. When getting any other type of beep code you should research the meaning of the code. Beep codes differ from company to company. The best way to identify the meaning of a beep code is to type the manufacture, model and number of beeps into Google. Another possible issue is that your hard drive is corrupt. If this is the case than your computer will pass the power on self test(POST) but will have a message like MBR not found or one of many other errors. If you are getting an error than it is also a good idea to research the error to determine the proper fix. If the PC seems to boot correctly but there is no image on the screen than the issue may be a result of a bad video card. In that case the video card will need to be replaced.
I hope that information above has helped is some way.
If possible please rate this solution.
Posted on Sep 01, 2010
Dell inspiron 1300 won't boot
If you want to keep your important data, use some softwares can solve thewindows won't startproblem most quickly, and no data will lose. Besides, it is very easy, even the people who lack of computer knowledge can deal with windows won't boot issue.
Sep 21, 2012 | Dell Computers & Internet
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
Pro-book 4520 won't boot. I switched on this morning. The windows (7) logo appeared, then blue/black screen and cursor only. Would not boot up. Ran diagnostics which said all OK. Still won'
The windows files are corrupted or the hard drive has issues, load cd installation disc if available, if that fails have the hardware checked for possible replacement.
Aug 13, 2012 | HEWLETT-PACKARD ProBook 4520s Notebook PC
My computer won't turn on properly. It keeps saying disk error press control alt delete. When I do it just says it again and again. It won't load and turn on.
First you should check if there is any disk on your cd room, if there is any disk you should remove the disk from the cd room, if there is no disk the possibility is your hard drive getting error
Press f2 or delete to enter your bios set up system
Look for boot menu
Set the first boot as a HDD and the second boot as cd room and disable the third boot
Save and Exit the setting
if your computer still won't load you need to reinstall your windows
insert windows cd and go to set up again by pressing f2 or delete button
Set the first boot as cd room then the second boot as HDD
Save and exit the setting again
When the message press any key to boot from cd appears you should press the space bar or another key
Then just follow the instruction of formatting
Jun 03, 2011 | Acer Computers & Internet
Won't boot from dvd or hard drive, changed hard drives and still won't boot
Depends on what you mean by won't boot from DVD or Hard Drive,
it sounds like your boot order is what you're looking for help for.
To do this you need to get into your computers BIOS (or "Setup")
You can do this by rebooting the computer and the very very very first screen you see tells you how,
usually by pressing DEL or F2 or F10.
Without knowing the specific computer you're looking for help on I can only point you in the right direction however keep in mind the BIOS is for advanced users only and you can damage your computer by randomly changing settings.
What you're looking for though is usually called the Boot Order or Boot Sequence
You'll need to set whatever device you want to boot from higher on the list (usually with the up arrow or PgUp)
If you don't see your device on the boot list then it may not be detected due to failure.
May 31, 2011 | Computers & Internet
Passenger door won;t unlock
CV boot, requires axle disassembly, or you could use an aftermarket, split boot. You MUST replace the lube....
It is often much better to exchange the shaft with a new or rebuilt one. Many vibrations are caused if there is even a minor imperfection in the CV joint.
Jun 30, 2010 | 2004 Saturn VUE
Dell InspironTM 1501 Notebook Logo
75 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
