Question about Sharp FO 3150 Plain Paper Laser Fax
Sharp fax machine: help!
Machine will sent the fax but, can not receive them. HELP!
Look to see if it is in tel,fax,or a.m. mode you need to have it in fax mode.tel=telephone,a.m.=ansering machine
Posted on Jun 30, 2008
Sharp FO-4700 Fax Not Received Even Though OK Fax Confirm Given
It's gone forever, once your machine received a EOT (end of transmission signal), your fax machine thinks it was received OK and clears it from memory.
Oct 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
I have a sharp UX P100 fax machine. my problem is
Scanner LED array, or lamp is blown. No light - No image.
Cheaper to replace than repair
Aug 21, 2009 | Office Equipment & Supplies
Sharp Fax Machine UX-485 recipiant receives black page
If you receive clear copies. Make a test copy. If it come out all black. Yes replace your fax . you have a bad scanner . cheaper to buy a new fax.
May 21, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
Send and receive
Most likely has a problem with the fax PCB board inside it. Its not worth repair.
Jan 07, 2009 | Sharp UX P100 Plain Paper Thermal transfer...
Sharp fax ux b700
you have to select Auto mode of reception for fax machine with the help of receive mode button of fax machine. this setting will set machine for automatic fax reception and you get fax within 2 or 3 rings as set to your machine.
May 05, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Receiving fax
your fax machine set to auto mode with the help of receive mode button of machine, this setting will give you automatic faxes.
Apr 21, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Sharp UXB700 fax machine
Sounds like a job that sent which requires differnt size paper or just froze up the machine.
What you will most likely have to do is, search your menus and setups, and find memory clear. And run a memory clear process.
There some corruption in the fax machines software that needs reset, That will do it.
You will have to then reset date and time, etc. But that should do it.
Feb 22, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Fax Machine Problem
the glass strip is bad, this is what reads the fax.
look in the manual under Maintenance for the location
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=6e9b3b779afac7942ef639a6224550b2&q=Sharp+UX-P100
Jan 30, 2008 | Sharp UX P100 Plain Paper Thermal transfer...
Can't receive fax but can send
Call your cell phone from the fax machine and check the caller ID to make sure that it is the correct number for your fax machine. Next, call the fax machine from you cell phone, and make sure the fax machine rings. Problems like these are almost always a phone line issue, not the machine.
Don't forget to rate your solutions please.
Dec 03, 2007 | Sharp UX P200 Plain Paper Thermal transfer...
Sharp FO 3150 Plain Paper Laser Fax Logo
171 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
