Question about Cobra 148 GTL 120-Channels Base CB Radio
Old cobra 148gtldx
Went to fire up the rig after it not being used for a while, and it will not work,the fuses are ok.anybody know any good rig doctors in warrington,cheshire uk
  • 27 Answers
This is not uncommon if it has been stored in damp conditions. In fact it is common in electronics. It can be "dried out" using a
household electric fan heater and spraying all the control pots with pot wiper cleaner....WORTH A TRY. I know these radios,
they can be a real beast (polite way of saying (*******)
Cheers flyingfox@people.net.au
PS> Don't place it to close to the heater, at least 30 cm <
Posted on Jun 22, 2008
The cobra esd 737 came on when I started the car than went blank, I checked the power card and connection, they all seem to be ok. I need to know if the detector has a fuse in it that could have possibly...
If it turns on and goes off each time you turn the car on, it is not the fuse. If the fuse were blown, it would not turn on at all. Based on what you have told me it sounds like a capacitor in the power control circuit has gone bad.
Nov 27, 2017 | Cobra Vehicle Parts & Accessories
I have a cobra 135 base radio. It powers up and
It is possible the audio amp has failed. If I remember this radio it uses two push pull transistors for the audio amp. Check the mic connector as it may have a broken wire and that can cause a disconnection both ways. Lastly the radio uses a relay to switch from receive to transmit and the contacts can get dirty with age and this rig is getting old! This relay can be cleaned but use the striking surface from a book of matches as the points are silver or an alloy a palladium and can be damaged if cleaned improperly.
Feb 08, 2010 | Uniden Radio Communications
Not sure how to use the swr meter on my cobra nw
The SWR meter connect between your antenna and your rig,
So the Out of the rig, goes into the SWR meter, and the antenna plugs into the SWR meter.
Jan 19, 2010 | Cobra 29 LTD CB Radio
I have a cobra 29 nw ltd classic i cannot hear or be heared
Start with the antenna that you have hooked to it, is it grounded, is the coax in good shape, is the connector in good shape. stuff like that.
Jun 14, 2009 | Cobra 29 LTD CB Radio
My panasonic has new final and driver but still does not transmit
thankyou for assistance but rand to dollar is to much to come by/greetings Henry
Jun 13, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Remote kcontrol don't work
refer to the manual, it will be using the module under bonnet and the fob / button.... usually the products online site will also have this info, dependant on the brand, I know cobra do...?
Ok good luck, Chas
Jun 04, 2009 | 2002 Volkswagen Jetta TDI
Cobra 148gtldx low vol squelch on fm
Hi Mate, the problem you are having in not uncommon in the
COBERA 148 GTL. I suspect that the problem lies in low value uF electro caps drying out (electrolite) causing power down and frequency drift. The capacitors are in two forms..tiny blue tantalum, and standard radial base caps that are grey aluminium
cans with a black stripe,it would be a job for a skilled person in electronics to replace all of them. The square metal cans with a screw ferrite slug are what you use to tune the radio, and as there are lot of them ,and you don't have a circuit diagram ,it would be pot luck finding the right one/s. What you realy need to know is all electronic devices age and hence, no longer do their job.
it would cost more than the set is worth to rebuild it,but if you have the skills ,it can be done. am cb with usb / lsb are a thing of the past now and you would be better off buying a used set that is still in top working order. The uhf sets are useless as was the am sets depending on what you want the sets to do, in convoy.... great....in remote country....useless. Having said that the am/usb/lsb sets are the best of the three because on ssb they tx on about 12 watts rms so you have a better chance of making contact, but don't count on it as hf cb is no longer in
common use.
GOOD LUCK flyingfox@people.net.au
Jun 22, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra CB Radio 148 NW ST
The first thing to do is to check if your power wire actually has power to it. Do this with a test light or a multimeter. Given that the wire is powered, check to make sure your ground is good. Modern cars have so much plastic in them that grounds may be hard to find. The next step is to check the rig's fuse. Make sure the microphone is plugged in, too. If none of this helps, your radio needs repair or replacement.
Feb 17, 2008 | Cobra 18 WX ST 40-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
87 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
