Need device codes for motorola remote model RC1475501/00MB
Model 463450-H-C-A. What are codes for Motorola?
You an use the code search (or equivalent) feature of your Philips remote to find something that will handle some or all functions of your Motorola device. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Mar 18, 2016 | Philips Televison & Video
Need code for Motorola cable box DCT2244-1661-ACDEFGK Remote is Suddenlink 1057B01
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Sep 20, 2015 | Motorola Televison & Video
I have the Sony Rm-Av2100. I need the code for the motorola U-verse cable box...
Unfortunately your Sony remote doesn't have any codes for Motorola cable boxes. Click on the link below to check which devices your remote will operate:
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMAV2100
Try using the code search function as detailed in your user manual. If you can't find your user manual, it can also be downloaded from the link I provided. Occasionally codes for a different brand will work - not often, but it's worth a try.
Hope this helps
Nov 02, 2010 | Sony RM-AV2100 LCD Touchscreen Remote...
Through Amazon a Brookstone's "Jumbo Universal Remote" was delivered - there is no identification of who manufactures this remote. We need to have it control an AT&T-California cable box which was...
I happen to be a Jumbo Universal remote Expert here at Fixya, so I hope I can help. It is possible that this remote just won't run your Motorola cable box, but I wouldn't give up until I had tried the codes from the list in the manual, as well as run through the auto-setup feature of the remote for CBL and for SAT, where it just tries all the cable box codes one at a time.
I was able to find a working motorola codes for an Innovage Jumbo Remote, a three digit code remote you might as well try: 051.
You have probably tried the codes for Motorola (031) and GI (000, 032) from the manual using these steps:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device. (000, 031 & 032 for example)
3. Press and hold the corresponding button on the remote control
(CBL) for approximately three seconds. The POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press the ON /OFF button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code located on the Code List.
If those are still a bust, try the GI SAT codes 018 & 019.
Have you tried the following steps with both CBL and then SAT to search it's database?
2. Press and hold the corresponding button on the remote control
(SAT or CBL) until the POWER INDICATOR on the remote control illuminates. The remote control is in programming mode.
3. Press and release ON /OFF. The POWER INDICATOR on the remote control flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns off.
5. When the device turns off, press any key to store the code.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
I hope that helps.
Oct 26, 2009 | Televison & Video
How to program a jumbo touch screen universal remote control
I just found my booklet for the Jumbo Touch Screen Remote Control
item no: NV-00268
if this is your remote; list the device and model name for the codes you need and i'll do my best to help
Jul 09, 2009 | Televison & Video
I need codes for my cable box its a moterola cable box from shaw in winnipeg manitoba my name is justin ledoux could you send me some codes pleaz
Sorry it took so long to respond to your request for assistance.[Motorola... 5000, 5002, 5003, 5028] These are the listed codes for your remote control to use with a Motorola cable box. I hope this information solves your problem, of needing the codes to use with the remote control and you Motorola cable box. Thank you for using FixYa and have a nice day!
Feb 10, 2009 | RCA 3-Device Universal Remote with...
Remote control
I was able to get my Motorola DVR Cable Box to work with my Universal Remote using the following instructions:
The Instruction Manual for Manual Code Search seems incorrect. (Page 5).
A) Manually turn on the device to be controlled. (O.K.)
B) Press and hold the code search button until the red indicator stays on, then release the code search button. (O.K.)
C) Press and quickly release the desired mode button (TV, VCR). The red indicator blinks off once. (O.K.)
D) Face the remote control directly to the device you want to control. (O.K.)
E.) Press the ON/OFF Button (this should read CHANNEL UP button) repeatedly until the device to be controlled changes channel. The red button blinks off with each button press.
F) Press and release enter to install the code. (O.K.)
-Note, the remote is able to change the channel, however, it does not control the volume.
Jan 03, 2008 | Televison & Video
Durabrand dvd code
hi go here for the complete usermanual, and try this following.
If none of the codes listed under
“Device Codes”on the back of this
guide match your device, you can
search for a set of commands that will
work. Your remote will sample all the
codes in its system for that device
mode to find one that will allow you to
control your device.
1. Press and hold a device mode
key (AUDIO, DVD/VCR, or TV) for
at least six seconds. The LED for
each device key lights up, then
the key for the device you
selected remains on.
2. Press a function key (such as
Power or Mute). The following
function keys are valid for
Searching (Power is
recommended):
• Power
• Mute
• Play
• CH +
• Stop
The device key’s LED blinks
three times, then turns off.
3. Press !. The remote will send
the IR command for the function
you pressed in Step 2.
4. If the device performed the
function you pressed, press OK.
The remote will now control the
device you selected in Step 1.
If the device did not perform the
function you pressed, repeat step
3. Press " to retry the previous code
I hope this helps
Please rate accordingly
Thank You
sserpentio
Dec 25, 2007 | Motorola Mobility DRC800 Universal Remote...
Televison & Video Logo
208 people viewed this question
Top Televison & Video Experts
