Question about Jwin JCAM100 Webcam
I cannot instal my web cam i already follow every step and is not working
  • 503 Answers
You can visit the below mentioned link......
go to: http://www.mingjong.net/index.php/en/web…
click on your camera model, then click on "download driver".
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Sep 01, 2010
My web cam not workeng
May be your web cam driver is corrupted. Follow these steps:- 1.Remove the webcam. 2.Restart the computer and connect the webcam. 3.Insert the web cam driver CD and install the driver. 4.Now your webcam will be connected.
Regards, polysandy
May 07, 2011 | Computers & Internet
Tip
When installing a Web-Cam make sure your old cam has been uninsulated.
When you set up a new Web-Cam for your computer go under to the computers Start up Key, click the "Computer" button, and you will see a option to pick from. Click "Control Panel" and a list of installed programs, and accessories installed in your computers memory will come up. Find your old Web-Cam under the installed "Device Manager" icon.
Uninstall your old cam, and make sure the New one IS NOT plugged in at this point. After you uninstall the old one, you can then PLUG in the new cam, go back to "Device Manager" and click on "View Hardware and Devices" and your computer should recognize you have new hardware plugged into one of your USB ports, and a balloon should pop up, and Click that ballon, your computer SHOULD read and install the Cam, if not use your "Device Manager" and IF a disk came with your Cam, put it into your computer at this point if you already havent. Your PC should recognize what you are tring to do, and install the Cam. Hope this helps, if not type Web Cam into the search engine in your computers search tab, while under the Device Manager, and it will tell you step by step on how to do lots of things.
on Feb 09, 2010 | Cameras
How do I set up my web cam
hi momo, i am happy to help you just follow below steps
Step 1 - plug in web cam to your PC or laptop
step 2 - on the time you buy your came they will provide one Driver CD for this cam take it out
Step 3- put in on your CD or DVD player and install that driver
Step 4 - restart your system
Now your cam will be installed in your system, you can use it
Good luck
Jan 12, 2011 | Microsoft Life Cam Vx-700 Webcam
I have a Dell 530 S Dell Inspiron. Its Webcam has stopped working. Any solutions
The very first step is of course to check your web cam connection. Most web cams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in web cams this steps does of course not apply. Many new laptops have a build-in web cam. Also try connecting your web cam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
Other devices in Windows XP device manager
If the device is not recognized in Windows XP, Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer.
After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.If your problem is not fixed then you have to buy a new one.
Hope the above information will be helpful to you.
Thanks.
Oct 08, 2010 | Dell Inspiron 530 Desktop Computer
How do you set up web cam
Please just follow the below steps and fix your problem
1.Connect your Web camera to the computer.
2.Install the Web cam software.
3.Follow the instructions in the Web cam software to begin
Thanks.
Have a great day.
Aug 29, 2010 | MSI Computers & Internet
Installation
Hi! don't worry with the driver..you can choose it from here..
just click the file...and click " save " to start downloading....using winrar (and or winzip), extract the file and install driver for your web cam
1. a4tech PK-635 web cam (rar) file
2. a4tech PK-635 web cam (zip) file
But first connect your web cam via usb slot on your computer... wait till a message on the taskbar appear: found new hardware..once ask for a driver.. choose one from the driver and install it.
Just follow this step and your web cam will work again.
Please rate this solution if you successfully installed your web cam....thanks..
May 30, 2010 | A4tech Viewcam PK335 Webcam
Web cam do not turn on for pavilion dv6910
There are two files needed for the webcam to work. Go to the HP support driver page and look for the driver for the Cyberlink Youcam. You'll have to put the exact model number in a special search box in order to download the youcam software from HP
Sep 18, 2009 | HP Pavilion DV6910US Laptop
My dells webcam wont work on msn,
If the web cam is working normally with other web cam applications but MSN then it's required to configure MSN to use the web cam. Please follow the steps given below to configure MSN to use the web cam.
(i) Please ensure that the web cam is turned ON.
(ii) Then, double click the MSN icon and log on.
(iii) Click on the Tools menu, then click on the audio/video tuning wizard. Then, click Next to start the wizard.
(iv) On the first wizard page, under Camera, click the web cam then click Next.
Performing all the above steps will configure MSN to use with the web cam.
In order to start a video conversation, follow the steps given below after signing in MSN:
(a) Click Action, then point to audio/video.
(b) Then, click start a video conversation.
(c) Select a contact from "My contacts" page then OK.
Sep 01, 2009 | Dell Inspiron 1501 Notebook
How do i install my web camra?
  1. step 1 Place the product installation CD in the CD drive of your computer. The installation wizard will start automatically. Follow the installation wizard prompts.
  2. Step 2 Plug the USB connector at the end of the LifeCam connection cable into an available USB port on your computer when prompted.
  3. Step 3 Place the LifeCam on a flat, level surface, or hang it from your computer's monitor. Continue following the wizard prompts until the installation wizard finishes.
  4. Step 4 Click the "Start" button, then click "All Programs" on the Start menu.
  5. Step 5 Click the "Microsoft LifeCam" folder icon in the list of programs on the Start menu, then click the "LifeCam" icon. That opens the LifeCam software and completes the installation process.
Aug 23, 2009 | Microsoft LifeCam VX-3000 Web Camera
How do you get the 1.3 megapixel web cam to work
If you bought a new 1.3 mega web cam with that a driver cd is available. If you have the driver cd install it first. here is install steps.
  1. unplug the web cam if you connected to the system
  2. Put the web cam driver cd into the cd drive and install the driver software.
  3. In the installation it will ask you to connect the web cam to the system and connect it (Only it ask to connect)
  4. After that you can see the image on the web cam software.
  5. Adjust the lens which is comfortable to see.
These are intial steps to work the web cam just try it and inform me if you get any other thing
Apr 28, 2008 | Computers & Internet
Jwin JCAM100 Webcam Logo
108 people viewed this question
Top Jwin Computers & Internet Experts
Shawn DuRee
Avishek Samaddar
Avishek Samaddar
Pramod Kumar
Pramod Kumar
Are you a Jwin Computer and Internet Expert? Answer questions, earn points and help others
