Water building up in drain pan. - Heating & Cooling
  • 674 Answers
Is this a split unit? The drain line is probably clogged. If you have a shop vac you can use it on the drain line outside and clear the clog or maybe use something like drano. A little Clorox added to the drain pan every now and then will help keep the drain line from getting clogged. (Just a couple tablespoons)
Posted on Sep 01, 2010
How to keep water from building up in my air conditioning drain pan
this indicates that the drain is blocked by gunk either in the drain tray outlet or in the drain pipe outside
it can be washed out or blown out
it could be the outside hose because things like mud wasps find it a good place to build nests
Sep 01, 2015 | Heating & Cooling
Whee is water pan located?
This unit features the patented AutoDrain NanoMist Technology that Vaporizes excess fluid build up, eliminating the need to drain the unit. Most of this water is used to cool the unit and make it run more efficiently. This unit has a built-in water tank (non removable) with a drain outlet for end of season draining and storage purposes
Jul 14, 2012 | Amcor PLM 10000EH Portable Air Conditioner
Water freezing on bottom of freezer
The defrost drain pan is plugged and not allowing the water to drain into the pan under the refrig. Remove the cover on the back wall of the freezer and clear the drain by flushing with hot water.
Mar 25, 2010 | Jenn-Air JSD2789GES Side by Side...
The water builds up on the bottom of my fridge under the bins. It is dripping down the inside back wall from the top area
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Oct 02, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
We are getting water build up under the crisper drawers --a large amount
Sep 25, 2009 | Roper Refrigerators
Water seeps out of freezer side of fridg onto the floor, I have totally remover the water line going to the ice maker and it still has water seeping out. It builds up Ice on the bottom of the freezer and...
Sep 25, 2009 | Magic Chef Refrigerators
My refrigerator has water coming out of freezer & ice build up on bottom of inside freezer
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 12, 2009 | Maytag MSD2756G Side by Side Refrigerator
My freezers interior cooling fins are frosting, then thawing and causing water to build up and leak out the door seal. what to do?
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Refrigerators
Water build up and spew into the room out ofvent
No. It should not spew water into the room. The drain pan is choked up. clean the drain pan and the problem will be solved.
Aug 15, 2009 | Haier Heating & Cooling
The ice builds up on the inside floor of the freezer
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Jul 24, 2009 | Kenmore Refrigerators
Heating & Cooling Logo
109 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
