Question about Hoover Vacuums
Hoover turbopower 4900 bagless model U5296-900 - the canister will not seal. Dirt and air leak out where the dirtcup latch mates with the dirt cup canister. how does one fix this kind of issue?
  • 298 Answers
SOURCE: Hoover - Red Light Dirt Sensor
Try cleaning the dirt sensor and clean the inside of the tube that goes into the bag with a damp cloth.It wont hurt anything it will continue to work
Posted on Nov 20, 2007
reddevil6
  • 1673 Answers
SOURCE: dirt finder
The sensor may be bad, or it may be coated over with dirt. Re,ove the hose at the back of the vacuum, the head of the sensor is down inside that opening, reach in there and clean it off and see it that corrects the problem, if not replace the sensor.
Posted on Jan 06, 2008
  • 8404 Answers
SOURCE: how do I clean the lifetime hepa filter
Check with the manufacturer. I have always had good response from Hoover.
Posted on Sep 23, 2009
SOURCE: My Hoover Dirt Finder red light stays on. All
Inspection of the circuit board found that the 470uF capacitor looked damaged. I replaced it and I now have the Green and Red lights are working correctly.
Posted on Jan 20, 2010
  • 73 Answers
SOURCE: Capture bagless not sucking!
Both ends of the hose will unscrew, allowing you to push out hair and fiber clogs with a broomhandle. There is a coarse filter above the dustcup which will release with a 1/4 turn counterclockwise, allowing you to remove the hair and fiber bundles trapped in the inlet. The filter below the dustcup also tends to clog. Anything more and you have to start getting out the hand tools. bgovan445@live.com
Posted on Feb 28, 2010
Top filter keeps clogging up??
Just make sure the rubber gasket is secure at the bottom of the dirt cup if it rides up the dirt will go straight up to the filters
here is the hepa that should be change when it is dirty
Hepa Filter Hoover U5780 WindTunnel Bagless 93002360
Dec 07, 2015 | Hoover U5780900 Bagless Upright Cyclonic...
Lid of filter section stucked in Hoover Vaccum Cleaner Model UH70115
Hi Bharat! In the front of the dirt cup near the top there is a red Hoover emblem that is also a latch to open the dirt cup lid. Pull on dirt cup latch to open lid. Hope this helps!
Sep 17, 2014 | Hoover UH70015 Bagless Upright Cyclonic...
How to open to clean
Hello! The dirt cup, filter and brushes need to be cleaned to ensure continued cleaning effectiveness. Below are steps for cleaning your Hoover Slider.
Turn switch to OFF position.
1. Press button and slide latch towards outside of cleaner. Rotate dirt cup toward back of cleaner.
2. While holding dirt cup, grasp filter frame and lift out filter. Empty dirt cup after every use. Dirt cup can be cleaned with a damp cloth. Allow to dry thoroughly.
3. Pull middle section of filter out of filter frame. To remove debris from filter, tap it on a hard surface or brush it with a soft brush.
4. Remove lint, strings, etc. from the brush roll located on the underneath side of the nozzle.
5. Replace the brush roll when the brushes do not touch the edge of a card as it is moved across the opening on the bottom of the nozzle.
Further disassembly of the cleaner is not recommended. Hope this helps!
F
Aug 13, 2014 | Hoover S2105 Slider Bagless Stick Vacuum
Hoover troubleshooting
Hello! The umbrella tube is a stationary part, it does not rotate. The dirt that enters in the dirt cup spins around the umbrella tube. If no dirt is entering into the dirt cup this can mean there is a blockage either in your hoses and/or your filters. Try these quick trouble shooting steps below.
1. Remove the dirt cup canister from the vacuum. Twist off the dirt cup lid.
2. Remove the primary foam filter. Hold filter under running water until water runs clear. Allow 24 hours to air dry. If the filter is really dirty it may need to be replaced.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash)
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose. Hope this helps!
Aug 09, 2014 | Hoover Nano Cyclonic Compact Bagless...
How do i clean canister of dirt devil featherlight bagless caniter vacuum
Hi there! To clean the canister or dirt cup, first remove the dirt cup from the vacuum. Twist off the dirt cup lid. Remove the pleated filter and empty the dirt cup. Tap the filter against the trash can until the dirt stops falling. If the filter is really dirty it may need to be replaced. The filter should be replaced every 6 months. I have included a link where you may go to purchase a replacement filter if needed.
Thanks! Hope this helps!
F1 HEPA Filter
May 18, 2014 | Dirt Devil Featherlite Bagless Vacuum...
How do i fix cup latch on dirt devil bagless. the latch spring came out but i haave it, just not sure how to insert it.
Sorry, but the part number for the item you wish to reassemble to the machine doesn't help me find a schematic to see how to re-insert it. I will need the model number of the vac itself. Thanks.
Dec 11, 2013 | Dirt Devil 1881255000 Dirt Cup Latch...
Runs hot, does not pick up
http://www.ereplacementparts.com/cartridge-filterdirt-cup-p-548175.html?osCsid=f6mmc96dkoihh0qjfts9rd9id6
Not familiar with your vacuum, but there are at least TWO filters and two seals in it, according to the illustrated parts breakdown above. Assuming the HEPA filter is number A23 (final filter) in the above url, it sounds like you've got a full cartridge filter/dirt cup A29, blocking airflow through the vacuum. There is also a prefilter, A55 that could be clogged. The suction fan is usually directly attached to the motor, such that if the motor turns on, the fan should be working. Of course a plastic fan that has been used to chew up wood chips might be in tatters, but the fan should be in serviceable condition. Look at the IPB shown above and locate ALL filters, dirt cups, etc. and ensure that they are not clogged with dirt. If you can, remove the filters, close up the unit and turn the unit on to check the airflow, which not only moves the dirt into the dirtcup, but also cools the motor. Anything that obstructs airflow will generally raise the motor temperature and the exhausted air. I believe you'll find a full A29 filter.Good Luck
MB
http://in4m8ion.com
Nov 25, 2011 | Hoover U6630-900 WindTunnel Bagless...
Dirt is being trapped in the filter area instead of canister.
The canister has a filter as well. It needs to be replaced or cleaned. A damaged canister filter will feed dirt into the HEPA filter. (and the motor)
An improperly installed filter can allow dirt to bypass the canister filter and collect in the HEPA filter.
I suggest a new canister filter and then clean it carefully every week.
Here is a list of the filters for your vacuum.
Apr 16, 2010 | Eureka 5893AVZ Bagless Upright Cyclonic...
Hoover Mach 3 (Fusion): Dirt Will not enter dirt cup
The dirt in my vacuum keeps getting stuck into the hose and dosent reach the chamber, its a constant problem even if i clean out the clog!!
Jul 31, 2009 | Hoover Elite Rewind Bagless Upright...
Vacuums Logo
565 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
