Question about Raypak 130,000 BTU Natural Gas Pool H...
THERMOSTAT NOT WORKING - HIGHER TEMPERATURE SHOWING AND POOL NOT ACTUALLY AT THAT TEMPERATURE
Destinova
  • 46 Answers
SOURCE: problem with Honeywell RTH230B Thermostat
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
Posted on May 27, 2008
john224
  • 1378 Answers
SOURCE: Raypak RP2100 not showing even close to correct pool water temp.
Bad thermistor probably. It is not a very expensive part.
Posted on Jun 14, 2009
heatman101
  • 43501 Answers
SOURCE: Incorrect ambient temperature on Honeywell Model RTH221B
Check in your manual for the thermostat. By pushing a combination of buttons you can get into the advanced installer menu. From there you can make an adjustment to correct the temperature.
Posted on Nov 12, 2009
  • 587 Answers
SOURCE: I have a cm921 thermostat with the correct
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Posted on Mar 16, 2010
jharwell668
  • 640 Answers
SOURCE: Pool heater temperature is higher then the actual
With these particular pool heaters, troubleshooting without specifics is very difficult to do. The users manual actually has a flow chart that walks you through, step by step, questions that you will need to answer to determine the problem. That is going to be your best shot at finding a solution. Here is a link to a pdf version of the users manual.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
Posted on Aug 16, 2010
Heater set on 100 display shows 126
Obviously one (or both) is/are wrong. The easiest way to figure out which is to use a thermometer to take the water temperature to determine to actual temperature. Then you can decide whether or not to spend money to repair indicators or thermostats.
Sep 07, 2016 | Pool & Spa
My thermostat showing on screen 76F when really room temperature is 70F and I HAVE MEASURED PROPER room sensor resistance OHMS to real room temperature. Why thermostat showing higher temperature and n
Where is the thermostat in relation to the return? Is there air flow or is the air stagnant in the area of the thermostat. Have you placed a thermometer in varios locations where the thermostat is located? Try these locations and see if the thermostat needs to be placed in a location better able to reflect room temperature. Also how long have you lived in the house? If it is a newer home I suggest that you contact the builder or the air conditioner/heater installer to see if they have a schematic of the placement of the thermostats.
Nov 25, 2014 | Honeywell TH8110U1003 VisionPRO 1H/1C...
Thermostat reset trips continually
Here's an article detailing electric water heater repair, that will be helpful to you.
Generally, when the reset button must be activated repeatedly, it indicates that one of the thermostats is not working properly. It is failing to sense the the actual temperature of the water in the tank.
This may be caused by a number of different things with the more likely being a defective thermostat, water damaged thermostat, poor contact of the thermostat with the tank itself (this can be due to rust build up between the two or insufficient spring pressure holding the thermostat against the tank).
You should do a visual inspection of the thermostats (with the power off!) to rule out the poor spring pressure, presence of rust or water and water damage to the thermostat. Repair sources of leaks if possible, remove thermostat(s) to clean the mating surfaces behind it and replace thermostats / parts that are weak or bent (in the case of the spring clip); wet or show evidence of earlier water damage.
Once the thermostat(s) can properly detect the rising temperature of the water being heated by the heating element again, it will shut off power to the heating element when the water matches the temperature you have selected. When the thermostat is unable to accurately determine the water temperature due to poor contact with the tank, the thermostat will continue too allow power to flow to the heating element - causing the water temperature to rise significantly higher than the level selected. This is when the high temperature switch operates to prevent the water from being heated any more. Needless to say, scalding is a very real threat any time the heaters continue to heat the water to a temperature higher than 140 degrees.
I hope this helps & good luck!
Jan 16, 2013 | General Electric GE SmartWater Household...
I have a cm921 thermostat with the correct batteries showing full charge. Yet the battery light is flashing and says battery low. Also displayed room temperature is a lot higher than the actual room...
HONEYWELL WEBSITE:
Go to honeywell.com
Feb 28, 2010 | Honeywell Programmable Thermostat Heater
Nov 11, 2009 | Honeywell Programmable Thermostat Heater
We have a hayward H100IDP1 pool heater,,we can hear fan come on,,but does not ignite...Was working fine beginning of season,,,notwont ignite..Pool filter is fine andrunning well,,could it be a pilot ...
Make sure the pipes are full of water. Check the thermostat to see if it is calling for heat. Make sure the thermostat is set to a temperature higher than the current temp of the water. If all those things are Ok then the unit may have gone off on high limit the last time you used it or the gas valve coils may have to be replaced. If there is a reset button for high limit press it. If not then the safety sensor for high limit may have to be replaced. If the unit fires up but does not stay on then the gas valve coils may need to be replaced.
Jul 18, 2009 | Hayward 100kbtu Pool Or Spa Propane Gas...
Problem with Honeywell RTH230B Thermostat
May 27, 2008 | Honeywell Programmable Thermostat Heater
Raypak 130,000 BTU    Natural Gas Pool H... Logo
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
