Question about Moen & Villeta Two Handle Lavatory Faucet
HAVE MOEN MODEL INS792A WIDESPREAD 2 HANDLE BATHROOM FAUCET - LOOSE HANDLE ON LEFT SIDE - KEPT INSTRUCTIONS (PICS ONLY) - CAN'T FIGURE OUT HOW TO TIGHTEN LOOSE HANDLE - HELP??? THNX!
  • 28 Answers
There is a cap on the top of the handle which can be removed by popping it out with a knife or a small flat tip screw driver. Inside you will see a screw which holds the handle to the faucet. Tighten this and replace handle cap.
Posted on Sep 01, 2010
Testimonial: "Thnx for the info/help BUT screw is gone - don't know where it is - finally got back to working on the handle and the handle just lifted off - HELP!"
How do I tighten the hot water handle on a moen 4720 bathroom faucet?
many two handle faucets have either a cover button on top or on the side, top button types generally can be tightened with a screw driver while the side button style typically requires an allen wrench (hex key)
Oct 19, 2014 | Plumbing
How to remove thet trim on a t6520 bathroom faucet handle?
Most moen handles and trim are secured by an allen set screw located right under the handle by looking at the picture you supplied. Once the set screw is loosened the handle can be removed and then the deck escheon usually screws off. Most of the time you do not need to remove the deck cover to get to the valve cartridge.
Sep 08, 2014 | Moen T6520 Icon Two-Handle Widespread...
I need replacement part for bath sink cartridge 4570
The Moen 1225 or 1200 cartridges are the same except the 1200 is brass in stead of plastic. They will fit most Moen single handle faucets. If it is a two-handle faucet, the 1224 cartridge will fit most two-handle models unless it is a fancy widespread faucet more than about 15 years old. I don't know the model numbers for those cartridges. All of these cartridges require a removal tool if you can't get them out with a pair of pliers.
Dec 09, 2011 | Moen Soap & Lotion Dispenser 3910S
Moen 2 handle bathroom faucet is leaking out of base of the left handle
There is a plastic retainer not with two tabs used for removal. You will need a removal tool to get this retainer off. Any plumbing supply that carries Moen should have this tool.
After removing the retainer nut, the cartridge pulls right out. Good luck!
May 23, 2017 | Moen Kingsley Two Handle Bathroom Sink...
My classmate
Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
Apr 26, 2010 | Moen Monticello Single-Handle Kitchen...
Moen bathroom wash basin faucet leak, how to repair , we have a new house, 45 days old, bathroom faucet leaks, how do you replace the washer or whatever it takes to stop leak, there are no apparent ways to...
No warrantee on new home?
No instructions left for ALL fixtures,water heater,heating system etc that where installed???
Go to a plumbing supply store,and see if they can help. Not Home Depot
Mar 24, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Moen Villeta 2 handle bathroom faucet, need to disassemble
hold the handle and twist the piece below that doesnt turn, anti-clockwise, it should unsrew and the handle should pull off.
Feb 09, 2009 | Moen Plumbing
Mini wide spread vanity tap handles ( mostly left ) are loose.
if there is a cap on top, remove with a sharp object(razor knife) and tighten phillips head screw Just guessing but this is a common setup
Jan 14, 2009 | Moen T4945/9300 Castelby Two Handle Mini...
Moen & Villeta Two Handle Lavatory Faucet  Logo
477 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
