Question about GPS
I need a manual for my old repeller car alarm/central locking/immobilizer.
emissionwiz
  • 76649 Answers
SOURCE: key fob will not undo
If you don't have one that works for the vehicle now, you'll have to take it to your local dealer to have it programmed to the vehicle. Some will charge for this, some will do it at no charge.
If you do have a remote that is programmed and working for the vehicle, then the following steps will allow you to program another remote:
1. Enter vehicle and close all doors.
2. Put seatbelt on (or clip it into the buckle) to shut the warning buzzer off.
3. Put key in ignition, turn to run position but don't start it.
4. Press and hold the unlock button on the working key fob and hold for 4 seconds, then also press the panic button.
5. Release both buttons and you should hear a single chime to indicate it is in program mode. You have 30 seconds after the chime to program any additional remotes you want to program.
6. Press and release both the unlock and lock buttons simultaneously on the remote you are programming. You should hear another single chime.
7. Within 4 seconds after hearing the chime, press either lock or unlock button on remote that you are programming.
Posted on Oct 16, 2008
tommyboinow
  • 324 Answers
SOURCE: Audi A4 Y Reg 2001, Central locking
reset you computer, do this by removing the positive battery cable for 10 mins.
Posted on Nov 26, 2008
  • 275 Answers
SOURCE: alarm immobillizer
The alarm systems on land rovers are quite tempramental. They work on radio frequencies. If you park next to a radio antenna like they have at post/ telecommunications offices. Then the radio waves they send out can interfere with your cars system, making it think it has been attempted to be broken into, and so immobilises. You should have a 4 digit code called the EKA code. You must have this to knock off the immobilser to start the car. The car must be locked completely, all windows shut and then enter the EKA code using your key.
Hope this helps
Posted on Feb 13, 2009
alicantecoli
  • 22219 Answers
SOURCE: E36 BMW 318I CENTRAL LOCKING
try locking and unlocking the car with the key 3 times slowly ,other than that i have no idea ?? another trick is to disconnect battery and join the cables together for a few minutes to discharge any capacitors that may be holding a charge in the computer..Only other thing i can think of is the main dealers who have the right connectors and software to re set it all .sorry i havent been of any help
Posted on Aug 05, 2009
  • 7 Answers
SOURCE: program ignition key to central locking on porsche 996 1998
Well, you can sometime catch the code again. Pt the key in the ignition and turn till the dash light come on (dont Start) then press and the Lock button while keeping the Lock button Pressed and turn the dash light off and put the key with the lock button Press for 10 second afterwards. If not successful first time try again. This should do it.
Posted on Feb 22, 2010
1997 Daewoo Cielo, How do I reset immobilizer
perhaps if you had included the make and model but you did not so call the closest dealer and ask them .
Apr 22, 2015 | Daewoo Cars & Trucks
Tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 | Televison & Video
Tip
How to program Chrysler Remote Transmitter
A Chrysler Transponder Key once programmed into a one car cannot be programmed to work any other car.
The transponder code identification is learned by the Sentry Key Immobilizer Module during programming. The Sentry Key Immobilizer Module sends the "Secret Code" to the transponder key and is retained by the transponder key during programming. After programming of the transponder key identification to the Sentry Key Immobilizer Module and the Secret Code is exchanged, the Sentry Key Immobilizer Module will ask for the transponder identification and the Secret Code every time the key is turned to ON or START.
No Emergency "Start" procedures for Chrysler vehicles.
Chrysler Key Operation and Programming
Model: 300 Year: 2005 - 2008
Model: 300C Year: 2005 - 2007
Remote alarm / central locking
System Operation
  • Pressing key LOCK button activates alarm and central locking.
  • Pressing key UNLOCK button once deactivates alarm system and unlocks driver's door.
  • Pressing key UNLOCK button twice within 5 seconds deactivates alarm system and unlocks all doors and trunk.
  • Pressing trunk lid button twice opens trunk lid.
  • System will automatically lock all doors when vehicle is driven above 15 mph.
  • Additional functions can be set to respond to the transmitter.
Programming
When
  • Key transmitter added or replaced.
How
  • Key transmitter is programmed during immobilizer programming procedure.
Immobilizer
System Operation
  • Immobilizer warning lamp illuminates for approximately 3 seconds.
Programming
When
  • Keys added or replaced.
How:
NOTE: Two programmed key transmitters must be available for the following procedure to operate. If none available key transmitters can only be programmed using diagnostic equipment.
  • Insert first programmed key into ignition switch.
  • Switch ignition ON for at least 3 seconds but no longer than 15 seconds.
  • Turn ignition OFF and remove key.
  • Withing 15 seconds insert second programmed key into ignition switch and turn ignition ON.
  • After 10 seconds an acoustic signal will be heard and immobilizer warning lamp will flash.
  • Turn ignition OFF and remove second programmed key.
  • Within 60 seconds insert non programmed key into ignition switch and turn ignition ON.
  • After 10 seconds an acoustic signal will be heard and immobilizer warning lamp will illuminate for 3 seconds.
  • Remove Key.
Check operation of programmed key transmitter.
Repeat procedure for additional key transmitters if required.
Model: 300M Year: 1999 - 2003
Model: Concorde Year: 1998 - 2003
Model: LHS Year: 1998 - 2001
Model: PT Cruiser Year: 2000 - 2005
System Operation
  • Pressing remote transmitter UNLOCK button once deactivates alarm system and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds deactivates alarm system and unlocks all doors.
  • Alarm / Central locking functions can be altered using remote transmitter.
Programming
When
  • Remote transmitter added or replaced.
How:
NOTE: One programmed Remote transmitters must be available for the following procedure to operate.
NOTE: Any existing remote transmitters not used during programming will become inoperative.
Using a programmed remote transmitter proceed as follows.
  • Press and hold remote transmitter UNLOCK button.
  • After holding the UNLOCK button for at least 4 seconds but no longer than 10 seconds, press remote transmitterPANIC button for at least 1 second and release both buttons.
  • Ensure acoustic signal is emitted indicating programming mode active.
  • Within 30 seconds carry out the following procedure for each remote transmitter (including previously programmed remote remote transmitter)
  • Press any button of each remote transmitter to be programmed.
  • Ensure acoustic signal is emitted after each remote transmitter operation.
  • Programming must be completed within 30 seconds.
  • Switch ignition OFF or wait 32 seconds to exit programming mode.
Ensure final acoustic signal is emitted.
Replacement remote transmitters can also be programmed using diagnostic equipment.
Immobilizer
System Operation
  • System arms after switching ignition OFF.
Programming
When
How
NOTE:Two programmed key transmitters must be available for the following procedure to operate.
  • Obtain all keys.
  • Using first programmed key turn ignition switch ON and wait 3 seconds, return to OFF position and remove key.
NOTE: First and second programmed key operations MUST be performed within 15 seconds.
  • Insert second programmed key and switch ignition ON.
  • Wait approximately 10 seconds.
  • Ensure immobilizer warning lamp begins to flash and an acoustic signal is emitted.
  • Switch ignition OFF and remove key.
  • Within 50 seconds, insert new key and switch ignition ON.
  • Ensure acoustic signal is emitted and immobilizer warning lamp remains illuminated for 3 secondsindicating programming completed.
For each additional key repeat procedure starting from the beginning.
Replacement keys can also be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Chrysler Remote Control Programming...
Malfunction of immobilizer Toyota Hilux,3.0 KZTE
computerised alarm malefunction the resever inside the car isnt working replace resever and remote
Dec 17, 2013 | Cars & Trucks
Alarm fob stopped working on rover sterling how do i bypass the immobilizer to start the car
inside your key fop were the battery fits there is three soldered points
just check they are connected properly if not just re-solder the connection i had the same fault on my rover 400 and that sorted it. if you are not sure about the connections being soldered correctly fold a small amount of paper and put it on top of your battery holder and refit your fop and then try it that should work just as well.
Sep 03, 2012 | Cars & Trucks
Alarm Problems
press the key twice to activate the alarm
Nov 13, 2009 | 2002 Volvo S40
Bmw e36 immobilised, iginition lights come on, but the starter wont turn over. how do i start the car to get it to a garage, i dont wont to pay the £70 for recovery truck
BMW E36 immobilizer Hope the following will help. Had similar problems. The transmitter buttons on keys is for central locking and alarm. Inside the key at the front there is a small electronic/magnetic chip that looks like a block. About 8mm long, 2mm deep and 4mm wide, not connected to any pc board. This is the immobilizer. It must match the receiver that is located behind the ignition switch. If it is loose and too far away from the receiver it won?t deactivate it. If you made a spare key it will switch on electrics but won?t start the car. If you don?t have an immobilizer chip any alarm shop will be able to program a new chip or install a new pair for your keys. There is a way to disable the immobilizer but rather have it fix and protect your car. I read an article somewhere (perhaps bmw e36 blog) of people removing this immobilizer. Good luck
Jul 06, 2009 | 1997 BMW 328
1996 excel immobiliser
To my understanding, a 96 Hyundai Excel Sprint has a factory installed remote central locking with alarm and immobilizer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 24, 2008 | 1996 Hyundai Accent
I have a bmw 316ti compact on a 52 reg. The central locking gave up working 3mths ago and we was useing the key to lock and unlock the car,then all ov a sudden we couldnt start the car.when you put the...
with any BMW they have their problems, one is the central locking/immobilizer, the central locking is linked into the immobilizer and vice versa, the immobilizer takes it signal to disarm from the central locking and the ignition key ring. (chip in the key) if one of these starts to play up it has loads of consequences this being one of them. they all need to work together for the system to work properly. you would need to read the alarm and immobiliser codes using an ob2 tool that can detect them, and find the fault some problems it can be the drivers door sensor in the lock this is the main door as its drivers side and it controls all other doors on the central locking. if the switch is worn in any of it movements the system will not know the door has been opened, this does not work on the interior light as that is a switch in the door frame. the door lock is lock unlock and deadlock with key with remote fob its also arm disarm alarm and immobiliser. i have seen in some models there is a sensor auto lock so when you walk away with the key the doors lock automatically all lease parts work together. any one having a problem can cause no signal to be sent to the others in the system to start engine .
Jun 22, 2017 | BMW 318 Cars & Trucks
Alarm keeps going at random
HI I HAD THIS PROBLEM BUT WITH MY CAR THE PROBLEM WAS EITHER A WINDOW WAS OPEN MAYBE ONLY 2 CMS, OR THAT A DOOR WASNT SHUT PROPERLY, HOPE THIS HELPS, IF NOT TRY TURNING YOUR KEY OTHER WAY AND HOLD IT FOR ABOUT 5 SECONDS TRY ONE OF THEM, GOOD LUCK.
Jul 05, 2008 | 1996 Audi A4
GPS Logo
183 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
