Question about Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D
The open door alarm goes off when the door is closed
    Problem Solver:
  • 6 Answers
THE CONTACT INSIDE THE FRIDGE THAT THE DOOR MAKES CONTACT WITH MAY HAVE DIRT OR SOMETHING ON IT,IF IT DONT MAKE GOOD CONECTION WHEN CLOSED THE LIGHT WILL STAY ON AND THE ALARM STILL CARRY ON GOING OFF.ALSO CHECK THAT THE LEVER INSIDE PUSHIES IN AND OUT AND NOTHINGS BLOCKING IT.ROB
Posted on Sep 05, 2010
How can i stop the door ajar alarm when door closed and 0 f
Hey friend, thank you for your post!
In order to stop the door ajar alarm from beeping when the door is closed you would need to reset the alarm. If you have done that and it continues to beep it could be an issue within the switch or panel of your Frigidaire freezer. I would recommend having a professional come out to properly diagnose your appliance. -Matt
Sep 19, 2014 | Frigidaire Freezers
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Factory reset for electrolux appliance
in order to solve a problem you need to understand how the device works. ideal for sensing the status of appliance doors
whether in the open or closed state (or for internal light). in the door under insulation (not visible) is a permanent magnet which switch on or off reed switch (usually on electronic). when the door is closed, the permanent magnet close or open the reed switch, depending what kind of switch is, normally open or normally closed. electronic received that information and because that (open door) stop the cooling fan. so, in your situation i would like to check that door is not hung up for some reason or try use an external permanent magnet. of course, reed switch should be checked also, because sometimes contacts may remain closed.
see the pictures below,
factory-reset-electrolux-appliance-tfdolxcnkaipunda4diszd1y-5-5.jpg factory-reset-electrolux-appliance-tfdolxcnkaipunda4diszd1y-5-9.jpg dado
Jul 28, 2014 | Electrolux ICON Professional E24RD75HPS...
The temp alarm keeps beeping, although the temperature seems fine
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 04, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Weird (Pressure Release) Noise After The Door Has Been Closed
The freezer being closed up tight and so cold can create a negative pressure inside. This negative pressure will cause the door to be very hard to open and could pull the door closed too quickly. Most manufactures today use small air valves the open and release as the door is being opened and closed. They are most often found on the bottom of the door itself or sometimes in the cabinet behind the back wall.
The noise is perfectly normal, my wife says it is there to alarm her when I am eating too many ice cream bars.....
May 03, 2010 | Frigidaire 14.1 cu. ft. / 399 liter...
Can't get alarm to turn off while temperature stabilizes
My wife solved it for me :-) You turn the alarm off with a switch at the bottom. The alarm turns off, but the light stays red for another 4 hours. After that the red light goes off too, and you can turn the switch back on without the alarm going off, if the freezer is back to operating temp.
Aug 06, 2009 | Frigidaire Upright Freezer FFU12F2H
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
171 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
