Question about ASUS Computers & Internet
Have an HP Pavilion a420n with Asus motherboard A7V5X-LA. Cannot get bios to recognize SATA drive or even find option to enable SATA,
Bubbabear64
  • 2794 Answers
SOURCE: sata unable to recognize my book 500gb
Well I went to ASUS website and I could find A7V8X-LA specifically. I was attempting to pull up A7V8X and ASUS informed me that the site was down for maintenance.
There are four A7V8X boards listed. None of them have an LA at the end of it. It's possible ASUS built the board for HP and you will have to get in touch with HP to get support for it.
Posted on Jun 22, 2008
colliewob
  • 778 Answers
SOURCE: PC won't boot if SATA drive connected, drive works fine if plugged afterward
Try Hirens Boot CD. It has a lot of programs on it to detect format etc.
I think your hard drive has a missing or corrupt MBR and it needs to be replaced.
When I have had a hard dive not recognized I hve used Super Fdisk to format and reset hard drive.
On the boot disk
Posted on Nov 04, 2008
gambit3rogue
  • 106 Answers
SOURCE: Cannot find usb port
Make sure you have the proper drivers installed for that usb devise. the easiest way to find out whats up, is to to to Add hardware on your control panel. If something is up a yellow question mark will be next to it. highlight it., click next and the pc will search for the appropriate drivers, if for some reason the drivers aren't found you will need to find the right drivers and Viola! good to go!
Good Luck =)
Posted on May 21, 2009
  • 425 Answers
SOURCE: Doesn't recognize SATA hard drives. BIOS option
Need to install latest bios update go to there website also if you are trying to boot up with usb installed take it out. BIOS ID:15
  1. Fixed the issue where SATA HDD boot up will fail if USB storage device is installed.
  2. Fixed the issue where SATA HDD boot up will fail if "USB keyboard/mouse" setting as "BIOS" section.
  3. Enhance the compatibility of SATA device on WIN98SE/ME.
  4. BIOS compile date: 06/07/2004
Posted on Nov 28, 2009
SOURCE: P4VMA-M motherboard won't recognize SATA hard drive
http://img.photobucket.com/albums/v242/Saphirex/wdsata2.jpg
http://img.photobucket.com/albums/v242/Saphirex/wdsata22.jpg
Posted on Jan 12, 2010
A8VE-SE won't recognize SATA HDD
If you are trying to install Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Jan 08, 2013 | VIA Asus A8v-e Se Socket 939 Pci-e K8t890...
Pegatron M2N78-la
Go here and select the operating system you are using and download the "Chipset Driver" and install it:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=4120567&
Also, recheck the connections to the drives, both power and ide or sata.
Jun 03, 2012 | HP Pavilion p6313w -24058
I would like to install a second HD on my HP Pabilion a1540n desktop. What are the specs so I can buy it.
HP Pavilion Media Center a1540n Desktop PC Product Specifications
Hardware Base processor Athlon 64 X2 (W) 4200+ 2.0 GHz
  • 2000 MT/s (mega transfers/second)
  • Socket AM2
Chipset GeForce 6150 LE Motherboard
  • Manufacturer: Asus
  • Motherboard Name: A8M2N-LA
  • HP/Compaq motherboard name: NodusM-GL8E
Memory Component Attributes Memory Installed 2 GB Maximum allowed 4 GB* (4 x 1 GB)
*Actual available memory may be less Speed supported PC2-4200 MB/sec Type 240 pin, DDR2 SDRAM Hard drive
  • 250 GB SATA
  • 7200 rpm
16X DVD(+/-)R/RW (+/-)R DL LightScribe drive
  • Must use Double-Layer media discs in order to take advantage of the DL technology
  • Must use LightScribe-enabled media discs and supporting software in order to take advantage of the LightScribe technology
Sep 04, 2011 | HP Pavilion a1540n PC Desktop
Want to take apart my hp a420n pavillion desktop
hi.. go to this link.. www.techpot.info.. the website will ask u for login user ID and password.. ID = mygoal Pass = 2help..
once in.. go to models on top.. and then enter the model number u provided on next page click option.. PRODUCT SPECIFICATIONS.. then go to the option that says CHASSIS.. click it.. and u will get a Detailed link on how u can take each and every part out of ur computer.. cheers and regards :-P..
May 05, 2010 | HP Pavilion a420n PC Desktop
Nov 28, 2009 | Abit KV7-V Motherboard
I have an HP Pavilion a656x computer with two SATA connections on the motherboard. BIOS doesn't give option to enable them. How do I??
BIOS doesn't give any option to enable those Sata headers, it's automatic. You just pick a Sata header, and plug into it.
Any one you want. BIOS will automatically recognize, that there's a device plugged in, and to THAT Sata header. That's what's nice about Sata.
Apr 16, 2009 | HP Pavilion a656x PC Desktop
I have a asus K8S-MX i want to connect SATA HDD
To enable sata port press Delete Key when computer Starts. U will get BIOS menu. On there the Main settings window the second last option is to enable sata option. If u want to install widows OS (XP,2000, Server edition) **** Driver CD and go to RAID folder there u get a driver ( shown as Floppy drive Image). Incerte Floppy in drive and click that icon. And click Extract. Then incert the OS CD. On starting of instalition u will get a option press F6 to install Raid Disk. Press F6. On Bitween instalition u will get a option to install this Raid. ( With out this RAID u cant install XP or Other vartions of windows in ur sata hard drive)
Mar 31, 2009 | ASUS K8S-MX Motherboard
On the boot disk
Nov 03, 2008 | ASUS K8N-E Deluxe nVidia nForce3 250...
Sata unable to recognize my book 500gb
The A7V8X-LA motherboard only supports SATA1. Your new hard drive is likely SATA2 (SATA-II). You'll likely need to change jumpers on the drive to make it compatible with SATA1.
It's a tiny bit slower than SATA2 (okay, twice as slow). But, it's still faster than PATA (IDE).
David L. Burkhart
Burkhart Technology Services
http://www.BurkhartTech.com
Jun 22, 2008 | ASUS A7V8X Motherboard
Sata/raid not working on ASUS M2N MB
You may need to set up the RAID array before it will be detected. Look in the BIOS and see if there is a way to set up the RAID array there. If there isn't, watch as the PC boots up and see if there is an option to go into the RAID settings before windows starts. You may need to actually create an array before it will be seen.
Nov 06, 2007 | ASUS M2N-MX Motherboard
Computers & Internet Logo
159 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
