I am having great difficulty finding parts for my HM30-150P-2. I recently had to replace the combustion air blower for 700.00. I know Lennox has quit making it and the price of parts is astronomical Do you know where I might find parts for a tad bit less?.
  • James Austin Sep 01, 2010
    Thank you, I have been checking the web but forgot about E-Bay.
    Genius:
  • 1,478 Answers
I will advice you check ereplacementparts.com or ebay.com to get the part of your device.
Take care.
Posted on Sep 01, 2010
I HAVE A HC3820 AND AM CURRENTLY LOOKING TO OBTAIN A BLOWER. THE PROBLEM IS THAT THE ONE NEEDED FOR THIS MODEL IS FAK-1500 AND I CANT FIND IT ANYWHERE! PLEASE HELP!
Honestly, go to www.grainger.com. Since Superior/Lennox Hearth/and FMi are all merging into one company you are going to have a very hard time finding replacement parts for older Superior units. Plus the new company, Astria Fireplaces, is going to be using FMI for their woodburning products so no more Superior products available.
If you bring the old blower to your local Grainger they can match it up. I hope this helps.
Jan 24, 2014 | Superior FBK-200 Fireplace Blower Kit for...
Furnace computer won't let furnace light
What is the model number? I have an SLP98 (installed on 11/29/2011).... and if I take the cover off the front of the furnace the panel that has the fancy "Lennox" badge on it) you will see two clear round windows about the size of a half dollar (one high on the furnace box and one lower on the blower box.) If you look downward into the window on the blower box you can see a red LED display that will sometimes flash error codes like E228 (one character at a time). If your model has something like this, let me know. I've done some DIY fixes recently out of necessity....and their easy.....and several technicians confessed they didn't know much, if anything, about the newer high effieciency Lennox gas furnaces.
Mar 01, 2013 | Lennox Heating & Cooling
Lennox pulse 21 startup issues .does not engage fan and complete heat cycle every time .
Have seen a rash of faulty blower time delays in lennox equipment. Lennox has a recall on one currently, not sure if your system is effected but it can be bypassed if in fact the problem.
Aug 23, 2017 | Heating & Cooling
I've got a Air condition unit model BV124 30-10L16, which is the part of Lennox furnace unit. The indoor fan stops working now. The outside fan works fine. I checked the capacitor, fine too. Cooling...
Hello, a blower motor will not run for one of theese three reasons 1) No power to motor 2) bad capacitor 3) the motor itself is bad. One test you could do is take the wire of the L1 terminal on the control board and use a jumper wire and connect it to the wire on the high speed motor tap , if this gets the unit running then the control board must be replaced if it does not work then the motor is shot......make suremwhen disconnevting wires the power is off.
Sep 04, 2011 | Heating & Cooling
Looking for sequence of operation for a lennox mid efficient furnace
When there is a Call for heat, the control delays ignition until combustion air
Blower operation has been proved and pre-purge period
Has elapsed. It then opens the gas valve and generates a
Spark to ignite the burners. Trial for ignition lasts for 7 seconds.
At the same time, the control begins monitoring the
Flame sensor. If the flame current is too weak (less than 1
Micro amp) or if the burners do not ignite (within the 7 second
Ignition trial), the control will shut off spark and the combustion
Air blower and de-energize the gas valve. Flame
Current should be between 1 and 5 micro amps to keep the
Gas valve open.
The control will attempt to ignite the burners up to two more
Times. Each time the control restarts the ignition sequence,
It begins with a 45 second pre-purge. If flame is not sensed
After the third trial, the control locks out. Lockout means that
The control shuts off the gas valve, spark and combustion air
Blower for 60 minutes. At the end of 60 minutes the control
Completely resets and will attempt ignition up to three times.
The control can be manually reset before the end of 60 minutes
By momentarily turning off power to the unit.
here is a link to an operations manual
http://0190acd.netsolhost.com/manuals/80MGF_Series.pdf
Nov 25, 2010 | Heating & Cooling
Need Remote Control for Lennox A/C
Try Heatcraft as they deal with lennox a/c units. Go to their web site is www.heatcraft.com.au and you will be able to find your nearest store.
Jun 11, 2009 | Danby DPAC8399 Air Conditioner
Lennox furnace not heating up
sounds like the ignitor is bad. there shoule be a 2 wire plug going to it. after the inducer motor starts, you can check the voltage at the 2 wire plug located under the burners. you can unpug it to check voltage or you can probe the back side of the plug with a volt meter. if you are getting 120v but it is not glowing, it is bad. you can also ohm it out while it is off.
Feb 02, 2009 | Heating & Cooling
Lennox air conditioner is blowing hot air
Check your coils for ice, check your breaker and fuses for condensing unit, and is your condensing fan running? If not, you either have a bad fan motor or capicitor. After you hit the button, and wait for it to time out, (you should hear a click) take a butter knife, and spin the fan if it is not moving. If the fan start spinning by itself after your assistance, you have a bad capacitor
Jan 29, 2009 | Heating & Cooling
Replace blower motor in Lennox gas heater
It is a fairly simple operation. The hardest part may be seperating the blower wheel from the motor shaft. I recommend first sanding then applying a little oil to the old shaft. Prop the blower housing aprox. a foot off the floor with the motor facing down then using a wrench (NOT pliers as you may scar the shaft) hold the wheel with one hand and work the wrench on the shaft work it back and forth to loosen. DO NOT hammer on the end of the shaft as you will mushroom it ever so slightly. The weight of the motor should cause the shaft to slide down. Good luck and don't forget to answer back if this works or not.
Jan 18, 2009 | Heating & Cooling
Gas does not stay on.
get a volt meter and check and see if you loose 24 volt power to the gas valve then make sure your grounds are goodif thoose are ok check for a 24 volt drop on transformer
Nov 16, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
