Question about DISH Network Televison & Video
The unit says it is aquiting satalits and stays setting at 0 of 5, tryed pulling and reinstalling the card ect. still same thing, Dish is not covered as our other unit is working. checked all wire connections also... what next?
    Problem Solver:
  • 9 Answers
Look through these suggestions and if it seems a little complicated when it come to the receiver wiring and such send me a few pics of the wiring inside and outside so i can look. Do what they call a check switch which is, hit menu button, then number 6, number 1 , then either number one or 3 whichever is check signal, then scroll to the checkswitch button on the t.v. wait for that it will reload everything. If you still get the same error message try another outlet using an extension chord. If the second t.v. does not have a picture then something is probably hooked up backwards. You can look at the back of the other unit and see the hook up of a little metal box that looks like a splitter BUT IS NOT, make sure those match up, if they do than there is a set where they hooked up at coming off the sattelite wires to the grounding block. This gets a little technical to do. If there is a splitter or barell or splice in the line that is your problem because the receivers have a very precise voltage system. You can check this if you have something to check voltage with, make sure you take the line from the wall to the receiver where it has a pic of a bow and says 1. take the line from the receiver to the wall and check the voltage it should be 12 to 18 volts.
Posted on Sep 05, 2010
Need code to work my satalite dish remote to work on the tv volumes and stuff
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Aug 24, 2014 | Televison & Video
Why will my canon pixma mp250 not reset a refilled color cartridge
i dont think you where trying the right solutions. the mp250 catridge 511 can not be reset as far as i know. what you can do to get it to print is to long press the reset button. this disables the ink level check function and you can work. the procedure you stated is usually for resetting the ink absorber, not catridges.
Good Luck!
Jan 16, 2013 | Canon Pixma MP250 All-in-One Color InkJet...
No sound on my toshiba satalite pro 150a
Please reinstall the audio drivers and restart your satalite pro and check. It should work.
Jan 18, 2012 | Toshiba (P000218460) Sound Card
My dish 811 receiver won't download guide info. Do I need to reset and how?
Pull the smart card out of the unit and turn the unit off. then turn it back on and replace the card. this should reset the unit. It will take a minut or so for the unit to read the card and aquire a sat signal. If this does not work, simply call Dish network and they can walk you through any other options.
Nov 25, 2010 | DISH Network 811 HD DTV Receiver
HOW DO YOU REPLACE A START RELAY SWITCH ON A FRIGIDAIRE SIDE BY SIDE MODLE FRU26SA
Power off i.e unplugged
Open the back
Remove retaining clip on wiring side of compressor plastic cover.
NOTE wiring connections to terminals on the OLD relay. 1, 2 4 4 ect... make a simple wite color to terminal number sketch.
PULL off PTC relay WITH terminals by pulling HORIZONTALLY (Usually to the left / 9 O'clock position)
NOTE the thermal overload comes off WITH the PTC relay.
Remove wire from Thermal overload terminal and transfer the thermal overload to the new PTC relay.
Slide NEW PTC relay onto compressor terminals
Transfer remaining wires from OLD PTC to the correct terminal on the new PTC relay.
TEST compressor start before installing cover... PLUG in unit
After the test unplug the unit... reinstall the plastic cover and wire clip.
Reinstall back panel
Return unit to service.
Thanks for choosing FixYa
Kelly
NOTE the thermal overload will s akl
Sep 19, 2010 | Frigidaire Side by Side 26.0 Cubic Foot...
Trackfish 6600 will not receive satalite and
moisture and oxidation, neither work well with any electronic devices . many can never be repaired to work due to this .
Sep 14, 2017 | Navman Trackfish 6600 GPS Receiver
Error code 20000
...Actually it probably says error code 020000...flash test.
Other error codes: 6 digits in codes:
left to right digits;
1- Battery Test 0= Pass; 1= Fail ( batteries have to be good and in place even if using power supply (100000)
2=Flash Test/ Flash Charging 0=Pass; 1= Fail (020000)
3= IR Sensor Test 0= Pass; 3= Fail (003000)
4= Camera Mod Test 0= Pass; 4= Fail (000400)
5= Memory Test 0= Memory o.k. or no sd card; (000000) 5= Memory Full (000050) 6= SD card locked (000060) 7= SD card damaged (000070) 8= Comms Error (000080)
6= Clock Test 0= Pass; 9= Fail (000009)
ALL SYSTEMS OK= 000000, GOOD
WHEN PERFORMING THESE TESTS, FOR THE FLASH TO TEST OK YOU HAVE TO COVER LIGHT SENSORS small glass items each side of lens.If you still have error, install good batteries, power on, drop batteries out, turn unit off, reinstall batteries and turn on again....if all this, you still have error, you probably have bad flash unit.
Feb 03, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Not tracking satalite.
If you can hear the dish actually serching when it says "searching", there is a good possibility that you have a bad LNB on the dish. Unfortunately, this is not the only thing that can cause the problem. Your best bet is to call KVH @ 4018473327. Make sure you are on the boat when you call and they will run you through all of the programming checks to narrow down your issue. Good luck.
Sep 01, 2009 | KVH Tracvision M3 Satellite Tv System
I'm having trouble with the Javelin J330i printer. When trying to print cards it doesn't pull them through correctly and then gives an error that the ribbon is broken. I have tried resetting the printer,...
check the feed tires ,the ones that feed the paper/cards into the printer. they maybe slick with paper dust. I recommend taking a cotton dish cloth or rag with some 409 cleaner on it the the feed tires clean all the paper dust off the tires let dry then try to feed card again. sound like the sensor is covered with paper dust, and is giving a false error.
Jul 09, 2009 | Javelin Systems Inc Javelin Viper PC...
301 Power Problem
you might have a grounding issue or electrical power. dish receivers need a specific amount of volts, what you can do is take an extension cord n connect it to the rcvr and take the other end of the extension cord n plug it in on another outlet in another ROOM, then see if it powers on , if it does something is wrong w/ the outlet even if u have A tv or other appliace plugged in, if it doesnt turn on then call dish network n get replacement receiver
May 13, 2008 | DISH Network 301 DTV Receiver
Televison & Video Logo
52 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
