Question about Brother MFC 6490CW InkJet Printer
Keeps on saying cannot detect ink - Brother MFC 6490CW InkJet Printer
  • 503 Answers
if your Brother's printer is anything like mine, it won't print in any color (or black/white) if any one ink cartridge is empty. I just put any color cartridge I had in the empty slot to force it to print black and white.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Sep 01, 2010
Pixma 2200 series all in one
Don't use refill kits, they are no good in quality printers. Also the cartridges in the newer models have a chip in them that knows when the cartridge is empty. When it becomes empty, the chip has to be reset, and this is what those mall cartridge fillers do.
E, 1, 3 The ink may have run out. The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected. If you want to continue printing without this function, press the machine's Stop (Reset) button for at least 5 seconds. Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities. Please be advised that Canon shall not be liable for any malfunction or trouble caused by continuation of printing under the ink out condition. Checking the Ink Status Checking the Ink Status with the Ink Lamps on the Operation Panel The ink level detector is mounted on the machine to detect the remaining ink level. The machine considers as ink is full when a new FINE cartridge is installed, and then starts to detect a remaining ink level. If you install a used FINE cartridge, the indicated ink level of it may not be correct. In such case, refer to the ink level information only as a guide. When remaining ink cautions or errors occur, the error code will be displayed on the LED (Light Emitting Diode) to inform you of the error. Check the error code and take appropriate action. -> [ An Error Code Is Displayed on the LED ] See[Checking the Ink Status ]
Oct 27, 2015 | Canon PIXMA Office Equipment & Supplies
MFC-210C, keeps saying " NO Cartridge" lift
This unit has issues with the ink detect sensors. Have you tried a brand new cartridge? Other wise you may need a technician to solve the issue directly.
Jun 26, 2011 | Brother MFC 210C All-In-One InkJet Printer
I refilled my Lexmark cartridge but it continues to say I need to install a new cartridge. The printer model is x2670.
Hello there,
The reason why your Lexmark printer keeps on telling you to install new cartridge because the printer have ink cartridge detection. Meaning it will detect whether that particular cartridge is an old one or not.
Each Ink Cartridges have its code and it will be registered to the printer once you have connected it. The printer will assume the ink level and once it is empty, that particular Lexmark Ink Cartridge will be registered to your printer as an empty ink cartridge and needed to be replace with a new one.
I would suggest getting a genuine new cartridge instead of refilling the ink cartridges.
Feb 17, 2011 | Lexmark X2670 All-In-One Printer
My printer keeps saying to install a ink cartiage but there is one already in there.
Solution 1. you need to remove and return tightly the ink cartridge.
Solution 2. maybe you purchase ink cartridge that are not compatible with the printer.
Solution 3. if you are only refilling the ink cartridge, maybe it is worn out and the printer is no longer detecting the cartridge due to wear and tear.
Nov 26, 2010 | Dell Office Equipment & Supplies
I have a new LC61 and just replaced the blk
Leave the machine on with ink installed, unplug power for a few seconds and then plug in while you hold the stop button for a few seconds. Should clear the error for you, if not you may need a new ink sensor board.
Jan 08, 2010 | Brother Multi-Function Center MFC-240C...
Yellow ink cannot be recognize by the printer
The problem is that the priter can't detect the ink, because the cartridge has low level ink. I put scotch tape and colored it yellow- on the part where the ink is detected - so the printer will detect the color I put on the tape. BUT as others said it can damage your printer if you will always do this.
Jun 24, 2009 | Brother DCP 130C All-In-One InkJet Printer
Ink Cartridge Error
on your cartridges there is a chip that detects if the ink is low. The chip on your yellow cartridge is bad. You should return the cartridge for a new one(if you still have your receipt) or visit a Cartridge World in your area and they can put a new chip on for you
Aug 12, 2008 | HP Photosmart C6180 All-In-One InkJet...
Brother MFC-3360C cyan ink cartridge replace ment
On the front of the cartridge there is a sight tube for the ink, the fax shines a light through this tube to detect the ink.
I wraped a piece of paper around the tube to block the light beam on all the cartridges.
I dont need a processer to tell me if the machine is out of ink, I can work thay out when it stops printing!!
Now tell me you are out of ink you peice of electronic ****.
Jun 27, 2008 | Brother Multi-Function Center MFC-3360c...
Brother MFC 6490CW InkJet Printer Logo
601 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
