Question about Vulcan EF3 Deep Fryer
Burner will not light
It worked good before, now pilot lights but thats it! It has wires and micro switches but no power source,WHY?
  • burzerko
    burzerko May 11, 2010
    I would need the model and s/n number to research this I would be willing to bet it requires a thermopyle to send a signal to the gas valve that is why there is no power source. If this has been replaced with the wrong device this could be your problem.
    Champion:
  • 254 Answers
After esearching this problem you have a thermopile reading back through a pilot safty valve. It will be a valve which looks like a tee with a red button facing the operating side of the fryer. Take a reading where the two wires from the thermopile tie into the pilot safty valve the reading should be around 300mv to 500mv. Anything outside of this range would mean that your thermopile is defective. If your reading is in this range it would be the pilot safty valve that is defective.
Posted on Jun 04, 2008
I bought a Leviton 1201-PLC 15 Amp, 120 Volt, Toggle Pilot Light, Illuminated ON to replace a traditional 3 way switch (without a pilot). I replaced it by connecting the existing wires to the new switch in...
Your screw terminals are 2-brass and 1-dark.
Dark screw is considered 'common'
http://waterheatertimer.org/ST01C-program.html#3-way
Leviton shows a 3-way 1203-2, but not 1201
Wiring diagram indicates that pilot light is ON whenever switch has power.
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=2681§ion=10046&minisite=10026
Check your instruction sheet that pilot light is supposed to turn on-off with Load.
I don't think it is, without additional terminal on switch for neutral wire.
And then it would only work on switch located closest to light.
You can wire this type of thing separately.
Buy ordinary pilot light or indicator light from WW Grainger.
Look at diagram on following image:
http://waterheatertimer.org/images/3-way-circuit-with-pilot-indicator.jpg
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 08, 2011 | Leviton Snap On Mount Switch Pilot Light -...
I have a Leviton single pole rocker switch grnd, pilot light back and side wired #5628-2W i am trying to hook it up so light is on when switch is on i have 2 black wires 2 white wires and 1 ground wire how...
easy one first: ground wire to green screw. We have to assume the two black wires are the hot(coming from power source) and switch leg(going to light). Switch will have two brass colored screws. Looking at the switch with the off/on markings right side up. Put hot wire on upper screw and switch leg on other brass screw, With nothing hooked up, the hot wire will be the only wire with voltage on it. You can buy a non-contact voltage tester at Lowes or any place that sells electrical supplies. Now we must assume the two white wires are neutrals(one coming from power source and one going to light. The pilot light part of the switch will either have a silver colored screw or a white pigtail on it. all whites hook together. The pilot light is wired internally to the switch leg. Your switch should work properly now.
Jan 28, 2011 | Leviton COMBINATION SINGLE POLE TOGGLE...
Trying to hook up a pilot light switch to a gfi recp not having much luck with getting it to work properly i got 2 conductors from the panel and 2 conductors going to the gfi recp and on the switch i have...
It is unclear what pilot-light-switch is supposed to turn on-and-off.
Option A) pilot-light-switch is going to turn GFCI on-and-off
Option B) pilot-light-switch is getting power from existing GFCI circuit, and switch controls another Load (light, fan or motor) located elsewhere.
Add a comment at any point.
Bare copper wire always connects to green screw.
1) I have a Cooper pilot-light-switch in my office.
Black Hot wire from breaker always connects to dark-colored screw(s).
White Neutral wire from breaker box connects to silver-colored screw
Wire going to Load (light, fan, motor) connects to brass colored screw.
2) Two things happen when pilot-light-switch turns ON:
a) Pilot light turns on. This circuit is powered by black Hot wire, and circuit is complete with white Neutral.
b) Brass screw that had no power, is now powered.
The GFCI:
Hot from breaker always connects to brass-colored Line screw
Neutral from breaker connects to silver-colored screw that is opposite Line screw.
If other switches and plugs are going to be protected by GFCI, they connect to brass Load screw and to silver screw that is opposite Load screw
Option A) You want pilot-light-switch to turn on GFCI receptacle.
a) Wire pilot-light-switch as described above
b) Black wire from GFCI line-screw connects to brass screw on pilot-light-switch.
c) White wire from GFCI silver-screw-opposite-line-screw connects to any white Neutral.
Option B) Pilot-light-switch is getting power from GFCI receptacle AND you want pilot light switch protected by GFCI.
a) Black wire on pilot-light dark screw connects to Load screw on GFCI
b) White wire on pilot-light silver connects to silver screw on GFCI that is opposite Load screw
Option C) same as option B except pilot-light-switch is NOT protected by GFCI.
a) Black wire on pilot-light dark screw connects to Line screw on GFCI or any Hot wire
b) White wire on pilot-light silver connects to silver screw on GFCI that is opposite Load screw or to any Neutral wire
Nov 19, 2010 | Cooper Wiring Devices 277W-BOX SINGLE POLE...
Model LG Lite 2 pilot is lit but the burners will not light. pressure switch is working corectly, on off togle switch is working, all wires are good(tested with ohm meter) what could be wrong?
If this is a standing pilot you will want to check your voltage out put from the pilot. For this you will need a milivolt meter. The pilot should supply 500-700mv (1/2-3/4v) It only takes 200mv to open the pilot valve but needs another 300+ to open the main half of the gas valve. This would be the first thing I would check. If this is the problem you will need to replace the pilot assembly. If your getting the power you need from the pilot then it is probally your gas valve itself. Good luck.
Apr 25, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
I have the switch wired for operation of a circ. pump -with the pump located between the switch and source.The pilot light is on when switch is on. I am uncertain about correct wiring terminals to use. I...
I can't tell exactly which switch you have, but from your statement that the pump is between switch and the source, you may be out of luck unless you can run another wire from the switch to the pump.
If you have only one set of wires in the switch box (one black, one white, one ground) then I don't think you will be able to get the pilot light to work. The pilot needs a hot wire and a neutral. If you have only one set of wires, you don't have a neutral.
But if you have two sets wires in the switch box, do this--- Connect the two black wires to the terminals you are already using. Connect the two white wires together (not to the switch) This is the usual way to wire a switch. Power it up. The switch should operate the pump, but the pilot will not work. Turn off the breaker. Now connect the two white wires to the screws that are linked together. Power it back up. The pilot should now work.
Mar 29, 2010 | Cooper Industries Cooper Wiring 277V...
I have just installed 2 Leviton decora switch with pilot light Leviton 5637-i. The pilot light on both switches are not lighting, the switches operate the light and fan fine. It is wired as shown in the...
This is a single pole light switch and should be wired as any other SP switch. The only difference is that is has a pilot light. All the white neutral wires are tied together and then pushed back in the box with none connected to the switch. The grounds are tied together with a jumper wire connected to the green screw on the switch. That will leave you with 2 or more black wires. If you have just two normally you can connect them to the two screws on the switch and it does not matter which screws. However it may be that with the pilot light you need to connect the wire going to the light to the top screw and the power wire to the bottom or vice versa. Try both ways. If you have more than 2 black wires you need to connect the incoming power black wire and outgoing power black wires together and then jump to one of the screws on the switch. The black wire left over is the black wire going to the light itself. If none of this works then it is obvious the pilot light in the switch is burnt out.
Jan 06, 2010 | Leviton Ivory Decora Switch & Pilot Light...
Pilot will light but main burner will not light
if burner lights after jumping valve you have something wrong in thermostat loop. disconnect the 2 thermostat wires on gas valve and use multimeter on continuity setting. if all wires ,connectors and components are good,you will get a tone.since you have jumped out each component in thermostat loop with no success ,i would suspect a bad wire or oxidation on a terminal .
Sep 24, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Need to find out how to wire a pilot switch to outlet
From what you say sounds like you just want to know you have 120v to the plug. In that case wire 1 end to dark and other to lighter color.
If it is a switch its a little differant. You have to know which terminal is HOT when the switch is on and wire ons side of lite to this term and the other side to nutural.
Usually pilot lights are not polarity sensitive so either wire to either line on teh pilot is ok UNLESS THE WIRES ARE MARKED. And you dont indicate that they are marked. IF THIS HELPDS PLEASE RATE ME & GRADE ME ACCORDINGLY. GOOD LUCK
Mar 03, 2009 | Honeywell Electrical Supplies
Pilot light on pool heater
One possible problem to that is a bad pilot generator, not a real common problem but often happens. To test the pilot generator, unhook the to wires that comes from the pilot assembly and hook to the gas valve. Wedge a screwdriver or something in the knob that you push down when regularly lighting the pilot so that gas will continue to flow to the pilot, if you dont hold it down it wont stay lit. Use a multimeter set on DC voltage and put prongs on the ends of the wires. If it is above 600 then it is good, a little bit below will still allow it to work, the pilot only needs like 100 millivolts to stay lit. If it is somewhere down around 500 or lower, then it should be replaced. Another cause, if the pilot generator is not bad, is that a switch in the circuit could be acting up and drawing all of the millivolts from the source before it gets back to the gas valve, in turn the pilot is not supplied with proper millivoltage to stay lit. This usually is the case if you use your heater and it works for a while but then shuts off, and the pilot goes off with it. You can test each switch without removing wires. Each switch should use 5-10 millivolts max. Put one prong on a ground, or just stick it in the ground, the guys i work with dont believe me that it works. And test one side of the switch with the other prong and then the other side to measure the millivolt drop across the switch. If all switches are good. Bad news, probably a gas valve issue. Although take the time to inspect the connections made at the gas valve and all other switches for that matter. A little rust, a little corrosion, can eat up millivoltage very quickly and this can be fix by using some sand paper or emory cloth to clean the terminals. Also check for loose connections, if you can wiggle the wire where it is connecting to the terminal, take it off and crimp it down a little tighter with some channel locks or something. Millivolt heaters are a pain in the but, that is why everybody makes and sells electronic ignition ones now.
Aug 10, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Vulcan EF3 Deep Fryer Logo
128 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Treefrog15
Treefrog15
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
