Question about ASUS P4P800 SE (890552603657) Motherboard
PCI problems I just formated my PC and i don't have the Driver CD but i found most of the drivers on the internet but the PCI slot is not working i have two attached cards (Sound bluster and D-link controller).. Can somebody help me please!!!
    Master:
  • 441 Answers
The D-LInk controller might be a ethernet adapter, try to check the model number of the PCI device on the device itself then post it here, so we can find the drivers or you can search it.
Posted on May 09, 2008
I have recently replaced xp on my desktop pc for vista , and now the sound does not work, it keeps saying there is no audio output device installed or audio controller, i have been on device manager a
1. no audio device, if you sound card is integrated , first to CMOS inside look at sound card was disabled or not, then again consider driven of problem,
in device management Manager in look at is has yellow of question mark or is laments,, some words on double-click the device (into driven CD), click Update driven program, by prompted update can (don't said you does not yo).
also directly can be placed in the driver CD to install the driver, after installing your reboot should resolve the issue.
2, and if sound card is independent, first look card gold finger whether oxidation, as found gold finger gloss Dim found block rubber wipe to oxidation layer, again see PCI slot within whether has product dust, if has words with rubber blowing blowing clean dust, again with new of Yuan folding up to slot inside wipe about, then will sound card insert PCI slot within, must to plug tight, also no on for a slot try try. Determine Board connection when there is no problem, follow the steps to install drivers, in case of hardware damage alone will solve the problem.
Sep 04, 2012 | Microsoft Windows Vista Home Premium with...
I installed a new window in my computer but i lost the sound.it says that i lack an audio device
You need to install the audio driver for your computer mainboard. The audio driver can either be found on the CD disk that came with your computer mainboard or on the internet. To find it on the internet one would search the internet with the name and model number of your computer mainboard followed by the word Audio. The name and model number can be found written on the mainboard, between the PCI, VGA, PCI-Express slots.
You may want to post the make and model number below as a comment to this solution and I will find the audio drivers for you.
Hope this puts your mind at rest!
All the best!
damnor01
Dec 13, 2010 | Audio Players & Recorders
Soundcard problem
if onboard your suond card buy pci sound card w/ cd driver install it to pci slot in your pc turn on pc then install driver........done
Feb 23, 2010 | Gateway E-4100 Special PC Desktop
LAN is not recognizing Internet port
Then you have reinstall *********** boards drivers from its cd.
Oct 25, 2009 | Intel DG31PR Motherboard
Hardware not found?
please try to clean the mouth of the PCI slot by wiping with a white paper..... re fix it, power the machine and allow the hardware to be detected... you can now try installing the driver software ....
Aug 07, 2009 | Parallel PCTek High-Speed 2-Port PCI...
Please solve My problem-fujitsu V1020 Lifebook formated Vista then setup windows XP P2. sound detect but show message Error Code and PCI not detect.help me please.thanks
you cant able to the vista sound to xp the driver the company will give you only vista driver cd so get the sound drive for xp - download more than 3 diffrent sound driver for your pci slot realtec audio from internet and install it and it may works.
Jun 10, 2009 | Fujitsu LifeBook Notebook
Acer 5710g . no pci flash memory installation driver
Go to the acer drivers and download page via their website. Choose your make and model p.c with the OS thats installed (XP, Vista, etc). Download the cardbus driver. Unzip the file to a folder on your p.c. Choose the driver from that folder to update for each of the 3 PCI flash slots. This will fix your issue.
Jun 08, 2009 | Acer Aspire 5100 Notebook
PLEASE
it's the driver that the motherboard need to make use of the PCI slots, so as you can connect cards into the slot, otherwise the cartd would not work.
As E210822 is not a good intel number, go here and find your motherboard
Sep 10, 2008 | Computers & Internet
PC does not find modem
Remove the modem from the pci slot, uninstall the drivers you installed, shut down your system. now place the modem correctly in the pci slot( you can use the other pci slots also). strat the system with the driver cd in the cd drive. after logging in windows will display found new hardware screen, select yes this time only, on the next screen select automatically search for drivers, windows will search for the drivers automatically and install it if you are prompted to install a driver not signed by windows click continue installation. In case windows does not find the necessary driver, dont close the window or press the finish button, instead press the back button and come to the screen were you selected "automatically search for drivers, select manually search for drivers, and on the next screen click the browse button, navigate to the cd drive and select the correct driver inf file for the, you will have different inf's for different OS's, so select the correct os driver inf and proceed with installation, windows might say that the driver is not correct, you can still install it and give it a try.
good luck
Kindly POST back with your results
Jan 06, 2008 | Conexant Rockwell Modem
ASUS P4P800 SE (890552603657) Motherboard Logo
63 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
