Question about Lexmark Z611 InkJet Photo Printer
Page isnt prining out Have new ink in printer
  • 503 Answers
Before you can troubleshoot the problem, determine its cause. Do the following steps in order:
1. Print another PDF, such as the first page of Acrobat Help.
  • If a separate PDF file prints correctly, the PDF that doesn't print correctly could be damaged. See "Can't print a specific PDF file" later in this document.
  • If the separate file doesn't print correctly, go to step 2.
2. Print another type of file (for example, a plain text file) from another application (such as Microsoft Word or WordPad).
  • If that other type of file prints correctly, the problem isn't system-wide--it's specific to the Adobe Reader or Acrobat product. However, the problem could come from Reader or Acrobat interacts with the system. Go to step 3 to eliminate some system-related causes of the problem.
  • If that other type of file doesn't print correctly, the problem is system-wide--it isn't specific to Acrobat or PDFs. The problem could be low system resources, insufficient memory on your printer, or a poor connection between your computer and the printer. Go to step 3 to eliminate some likely causes of the problem.
3. Restart your computer, and then print a PDF.
  • If the file prints correctly, your system may have been out of memory or resources.
  • If the file doesn't print correctly, go to step 4.
4. Turn off your printer for at least 15 seconds to flush its memory. Then turn it back on and print a PDF.
  • If the file prints correctly, the printer's memory was too full or had become corrupt.
  • If the file still doesn't print correctly, go to step 5.
5. Print from another computer.
  • If the file prints correctly from another computer, the computer you first used may be unable to connect to the printer or the network correctly. Consult your network documentation or contact your network administrator.
  • If the file still doesn't print correctly, go to step 6.
6. Print a PDF to another printer.
  • If the file prints correctly to a different printer, the computer you first used may be unable to connect to the original printer. Communication, hardware, or memory problems can cause this kind of connection problem. Make sure that the printer is turned on and connected properly. Then run a self-test on the printer to make sure that it's working correctly. Consult your printer documentation for self-test instructions or contact your network administrator.
  • If the file doesn't print correctly, see "Can't print any file from any application" later in this document.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Sep 01, 2010
How do I fix Service Engine Error 181.514. INK Sense BPD Prine Error.
Have you removed the plastic covering the ink jets on a new cartridge?
Feb 21, 2015 | Lexmark OfficeEdge Pro 5500T Multifunction...
Can you add duplex double sided option to HP d1660
No duplex option is available. The only way to duplex is manual. Meaning you have to print the first side, then turn the page over and re-insert into the printer. Then print the 2nd page onto the back of the first page. The reason this is not an option and generally you do not want to duplex on these machines is that the ink will tend to bleed thru the paper when prining on both sides of a piece of paper. You may have to use a little thincker paper to prevent this.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 28, 2010 | HP D1660 InkJet Printer
Double image when printing picures
have u tryed new cardtriges, make sure there not interductury
Aug 03, 2010 | HP PhotoSmart Pro B9180gp - - colour -...
The ink lamp flashes even though it is a new cartridge and is prining fine how can i stop it flashing
the ink lamp flashes even though it is a new cartridge and is prining fine how can i stop it flashing
Feb 27, 2010 | Canon FAX-JX200
Some of the prined lines are being cut off at the bottom
Try to realign the printhead.
  1. Make sure the printer is loaded with unused white paper.
  2. Open the printer Toolbox , and select the Printer Services tab.
  3. Click Align Printheads . The Align Printheads window opens. Click Align .
  4. The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
If that does not work you can try changing the ink cartridges and repeat the align process
Jan 19, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Lexmark Z645 is not working. Not prineing.
maybe it needs new ink or check the conections
Jan 10, 2010 | Lexmark C533DN InkJet Printer
My kodak printer 5500 isnt prining as the minute what shall i do
printing blanks may be the same issue as not printing black or not printing color. There seems to be a print head issue w/ this model - call customer service and they can help. Best yet.....it is free of charge. They said immediately, w/o any info on my machine that if the problem was the print head they'd send it to me free of charge. I gave them one number off the printer, they set up a case, and bam....in 2-3 days I'll get my new print head for the black (mine wouldn't print anything black - but color worked fine)
Hope this helps!
P.S. they didn't ask me anything - not how long I've had it, how much I use it....so don't let that be a factor of why you don't call (I wouldn't have called, but someone else posted that they did, so I thought what do I have to loose!)
Nov 19, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Problems with color prining
hi!!!!
perform maintenance and
try to clean up nozzles may be the ink
clog
or removed the cartriged and clean with alcohol
use cotton buds then placed it back properly
Oct 31, 2008 | Canon BJC 2100 InkJet Printer
Lexmark Z611 InkJet Photo Printer Logo
172 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
