Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Our freezer is blowing cold air, but not making ice and items are thawing out??
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 01, 2010
I have a stainless steel top freezer ice make. the freezer seems t somewhat works but my refrigerator stopped getting cold. what should i do?
Check the fan in the refrigerator section, see if it's blowing air.
Next is the thermostat which you've probably already tried changing. Either one of these could have ice buildup making them not work correctly, so take everything out of the unit and use a house fan blowing into the refrigerator section to melt things out for a couple days. A hair dryer used on the areas will speed things up, but there's a risk of shock. Also the fan or thermostat may need to be replaced. (put your food items in another freezer/refrigerator as they will thaw and warm up within the time it will take for you to try to melt the ice out.)
The fact that the freezer is still working means that your compressor is working and the system isn't out of Freon.
Sep 07, 2016 | Stainless Refrigerators
Why are frozen bread items and small cups of ice cream thawing in freezer and not other things?
Ice cream requires a min. temp of 28 deg. you're most likely at about 30 or 31.
  1. make sure your air flow vents are free of ice in the freezer.
  2. turn up your temp control
  3. pull out fridge and clean and vac the rear coils and the motor area. make sure to clean the fan blades
this should do it mike
Mar 25, 2016 | Maytag Refrigerators
Does it make sense that a frigidaire plhs67egsb3 refrigerator freezer could stop working simply from overloading? The compressor is running, the condenser coil was clean but the evaporator coil was frozen...
the defrost heater or thermostat circuitry is bad,you need to test both components,also the defrost timer control if the other parts test o.k..,the defrost tstat has to be below 32 degrees or it will test bad/open,when the evaporator coil gets iced up you cannot blow cold air through a solid block of ice,(NO air flow)means no cold air throughout the unit even with the evaporator fan running
Apr 12, 2011 | Frigidaire Freezer FFU1212D
Maytag Bottom Freezer not working
Maybe fan in freezer not running to circulate air.
Aug 28, 2017 | Maytag MBF2556HEW / MBF2556HEB /...
My side by side kenmore refrigerator, freezer isnt freezing
the fan in the freezer is not working to blow the cold air in the freezer you need a new fan you need a repair man it will cost you $300 good luck i have the same problem don't buy samsung they are useless that why home depot don't sale samsung
Nov 12, 2009 | Samsung RS265LABP Side by Side...
I have a 19-year-old Kenmore top freezer refrigerator (model #1069610513). The freezer seems fine, but the fridge is warm. It was fine last night but when I opened it this morning the milk felt like room...
You might be developing an ice dam in the bottom tray of thr freezer that is obstucting the flow of cold air to the refigerater part of the unit. remove frozen items so you can see the bottom tray and see if you notice an exccesive amount of frosting on said floor tray, if so you are probably experiancing a defrosting problem.Check to see if you can feel cold air coming in from the top back section of the refrigerator. There is a fan that blows across the coils in the freezer section under the floor tray, if you cant feel the air either your fan has quit or you are froze shut.You can try a temp fix by removing food items to a cooler with ice or another unit and unplugging this one and letting it thaw out, be sure and put down a towl or two on the floor the tawing ice will go to the evaporater tray underneath and overflow once its thawed plug it back in and let it cool down. Check again to see if you can feel air in the frig. if you cant your fan has quit, you need to seek local appliance tech help they should be able to get you going for a fairly inexpencive amount.
Jul 12, 2009 | Kenmore Refrigerators
Freezer not freezing
you may have defrost problem or check fan by compressor
Apr 04, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Our freezer is not making Ice and the refrigerator is not cold
have oiyu ried to thaw it out then plus it back in? also is there anything that could be blocking the air at all? The easiest way to thaw a freezer is to take a shop vac and turn the air around and blow it on the coils to thaw out the ice. go ahead and make sure t=hat its cpompletely thawed out them turn back on and check the air flow afrom the fan after its ran a little bit. Don't rae until your problem has been resolved then rate the best solutions please. Thanks for using FixYa.
Dec 31, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
Refrigerator not cooling--has thawed/ but top freezer is cooling
Their is a fan that blows the cold air from the freezer to the refrigerator section, on some models. If thsi fan is  frozen or bad what you havwe discribed wil bew the result.
Nov 26, 2008 | Whirlpool Refrigerators
Frigidaire Side-By-Side Top Not Cooling
the unit is loosing the freon supply to the evaporator.you either have a leakage,a blockage or the compressor is not pumping to full capacity.
Nov 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
32 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
