Question about Electrolux ER7626B Bottom Freezer Refrigerator
Dear Sir, I purchased Electrolux Fridge Model ER37FF on 15.8.08. During the warranty period i.e. by Mar 09, its trays developed cracks. I took up the matter with the local Vediocon Service Center at Jalandhar Punjab, but failed to get the trays replaced despite a number of reminders & personal follow up. Now in Aug 2010, the fridge has failed to cool in the lower cabin. I lodged a complaint at the local complaint Centre & at the call Center (Complaint No. JAL 2708100229), with lot of follow up their mechanic came at home & replaced the Bi-metallic Switch, Thermal Fuse & Timer at a cost of Rs. 1500. But problem is the same. What should do? Please help. Thanks Gurbir Singh Kothi No.1, BBMB Colony Jalandhar Punjab Tel: -0181 2412048 & M: -09815967369
SOURCE: fridge freezer
there is a fan inside freezer behind back panel. if pipework behind panel is covered with ice, it will prevent air circulation and the fridge is affected first
take back panel off and check for ice build-up and that the fan is working
Posted on Jun 23, 2008
SOURCE: we have caravan electrolux rm
Problem is either thermostat or heating element...not sure which yet..but found website supplying most usable parts for RM series fridges. Hope this link is of use.
http://www.leisureshopdirect.com
http://www.leisureshopdirect.com/caravan/ventilation/Dometic-Electrolux_Spares$$6.aspx
Posted on Jul 08, 2008
SOURCE: Our caravan fridge electrolux rm4206
remove the fridge from caravan, now turn upside down and leave for as long as possible. what this does is get rid of any air locks in the gas. once left for a month or too turn back and leave for a day to setal and refit to caravan.this should solve your problem, it has been tried and tested on our caravan and worked. (This will not work on a domestic house fridge because they work on a different system)
Posted on Feb 07, 2009
Sea Breeze
  • 4654 Answers
SOURCE: My Electrolux Refrigerator / Freezer 340l Model
http://www.clickindia.com/detail.php?id=1184932 _________________________________________________ Kalinga Sales Refrigerators, Electrolux, Whirlpool Products LCD, Plasma, Air Conditioners Do not offer service, but may direct your call. Phone: 0674-254447, 254448 or 2742260 Have a hard time finding the information also but maybe this will help you, Thank You, Sea Breeze
Posted on Jun 10, 2009
  • 37 Answers
SOURCE: electrolux fridge freezer.FRIDGE NOT COOLING?
i checked out a different website and got my solution straight away.
Posted on Jan 09, 2010
Frigidaire ice maker
My Samsung would freeze up periodically especially when I didn't change the filter. Contaminants will cause frost or freezing in the line. The result was a tiny frozen blockage near the solenoid.
UNPLUG the fridge and run a hair dryer directed at the ice maker. Being careful to not allow plastic parts to overheat.
Sometimes you may even hear the tiniest crack when it lets loose. probably only take 20 minutes or so. depending how much of line is frozen.
Oct 28, 2017 | Refrigerators
Vegetable tray in my samsung fridge broken
Have you tried other places on the net by searching by part number in a web search engine? There may be some private vendors that sell these parts.
I found some companies are not very good for spare parts. This is especially with older units. The life expectancy for most appliances in these times is about 5 to 7 years. In most countries the manufactures are not obliged to supply parts past about 7 years past the last devices of the model in question were manufactured. Your fridge is more than that age!
Apr 02, 2017 | Samsung Refrigerators
Hi, I have an Electrolux French door fridge. the freezer keeps developing ice over the back panel and then the freezer shuts down. I have turned the whole unit off for 36 hrs to defrost and then turn it...
You have a defrost issue causing frost/ice accumulation on the back panel of the freezer and stopping air flow across the low side.
When this happens the air flow is stopped to the fresh food and its gets warmer by the day until it is finally defrosted. What is your model #???
Oct 17, 2013 | Electrolux Refrigerators
Emc38905x Does not start. Select microwave, then power then time press start & nothing happens. Need to toggle the power to reset & ok for afew days then fails again
I have an ELECTROLUX MICROWAVE (Model : EK23CBS4) purchased in January-12 from Pune. During usage glass plate got automatically cracked. when i called up service centre they said glass plate is not covered under warranty. When I verified the warranty book there is no as such things are mentioned. Most of the customer having the same problem glass plate getting cracked automatically. So I will suggest do not purchase any of the product Microwave Oven of ELECTROLUX. This is our responsibility avoid any product to purchase of ELECTROLUX.
Thanks, Mritunjay Kumar Cell# - 9922385632
Nov 06, 2011 | Electrolux E30MO65GSS Convection Microwave...
Hello, We just purchased the Electrolux side by side counter depth fridge (E23CS78HSS) a week ago. This past weekend the power failure light can on and the temperatures began to rise in the fridge and...
A week ago sounds like it is still under warranty. Check the manual for a troubleshooting chart and see if there is anything power failure. If you find nothing, return the fridge for another one.
Dec 20, 2010 | Electrolux E23CS78HSS Side by Side...
Trendnet 633-GR won't connect to the internet
Well I think that the internet is down from your ISP side
Did you try to call the internet service provider ? Your ISP must be DSL .
with the message " ue Mar 09 13:06:51 2004 PPP network down [INFO] Tue Mar 09 13:06:51 2004 WAN interface is down [INFO] "
It seems that the internet is down on the modem.
Click Here for more info about networking
Oct 07, 2009 | Trendware Computers & Internet
New nozzle, plenty of water, but no pressure.
It is warrantied for 1 or 2 years. Low pressure could be due to the un-loader valve needing grease. If it is leaking it will not work properly. If it is stored somewhere cold during winter months the small parts inside will crack.
Sep 18, 2009 | Karcher 2500 PSI Pressure Washer
Compact electrolux fridge has developed a noise
That little white box is a relay called a PTC relay. Depending on the warranty if you have it or the previous owner and didn't transfer then it needs to be replaced.
The part is about 25 dollars and pretty straight forward to replace. Just remove and take to appliance parts house they should be able to find one for that unit. If you go to a RV dealer I am afraid they will charge you some high dollar amount blaming it on the type of fridge you are dealing with. But this is just a apartment size type so nothing unique about it. let me know how it goes ken
Jan 24, 2009 | Frigidaire Refrigerators
Bunn (Pour Omatic) coffee maker has been leaking water - what would couse it to leak? Thank you
When a machine leaks, it is generally an indication of a bad seal or gasket. If you will call Customer Service at 800-352-2866 with the model and date code we will be happy to help you resolve your issue.
Oct 28, 2008 | Bunn NHB Coffee Maker
Electrolux ER7626B Bottom Freezer Refrigerator Logo
44 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
