My xbox 360 will work and everything but then there is no sound or picture coming up for it. My xbox 360 will work and everything but then there is no sound or picture coming up for it.
AnonymousAug 07, 2008
I have the same problem, does anyone know how to fix this?
when playing a dvd the screen goes to a blue screen everying few seconds. have switched dvd's and confirmed that the dvd not working on xbox360 is working on another player and that problem occurs with all dvd's. Games play OK.when playing a dvd the screen goes to a blue screen everying few seconds. have switched dvd's and confirmed that the dvd not working on xbox360 is working on another player and that problem occurs with all dvd's. Games play OK.
You can't post conmments that contain an email address.
Q502 must be top-shelf , first-quality only = no generic.
Use RCA 237470 or Sony 8-729-035-75 Both are first quality,
but RCA much less expensive..............................T.
Please rate this solution......................
Note:Blow-up caused by bad connects in horizontal driver
circuitry.Therefore,save your good,used flyback!
A refurbished set? If blue ray is not built into set the issue is with the set--maybe the reason set was refurbished.....If have not tried it unplug set for a while and reconnect with set turned off.
this is a problem wit your stk392-110 convergence IC's - One has gone bad and the both should be replaced. Also, check the large resistors near the convergence IC's - it sounds like one of them may have burned up..
it might be wires chek em all i had the same thing but i fixed it it was my wires if its not wires its your video chip melted and ur xbox360 needs repair
I have the same problem. I havce sound but no picture.
no picture but have sound
