Question about LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer - White
Adding clothes after wash started
I had started a load full of clothes and i had forgot to put in one of my towels so i stopped the wash and then tried to add the towel but the washer was still locked. So i was wondering if their was anyway to add things to the load after its already locked down or if there is a way to empty the water.
  • 1,294 Answers
It is best to finalise what clothes you want to wash, regarding front loaders. Or if you stop the machine, you have to wait for a couple of minutes for the door mechanism to release the lock, before u try the door. At times the door won't open for there is water in there; & if you force the door you'll damage the door assembly. So a lot of caution here!
Posted on May 09, 2008
My washer puts a lot of lint on the clothes after having been washed. How can this be stopped. no lint on my clothes.
Do not wash items like towels rags dish cloths etcetera or other lint producing clothes in the same load. This is not a washer issue.
Jan 17, 2017 | Washing Machines
My lg have a mold build up in the seal
One cup of bleach run on high temp with no clothes, leave the door open between loads
Jul 19, 2016 | LG Washing Machines
One piece agitator wraps cloths
When loading the machine, load towels, sheets or jeans with an accordion fold instead of putting the laundry in a circle around the agitator. It helps to put the clothes in at the twelve o'clock position, then six o'clock, then nine o'clock and then three o'clock. Repeat this sequence until the washer is full.
The laundry can circulate much better and get cleaner too.
Feb 08, 2014 | Washing Machines
I have aa frigidaire front load washer model LTF2940FE1. We put a pretty big load of towels in this morning. halfway through the cycle the machune made a couple of loud noises, like it was shaking, and...
Never put a large load of anything in, they're quite frankly not designed to work like that for a number of reasons. If the drum is full then water can't circulate properly and your clothes won't get washed as well as they could do.
The machine shut down to prevent damage to itself, try turning it off at the mains for 30 mins, turning it back on and then putting half the load in. This should reset it and stop the shaking.
Jun 24, 2012 | Frigidaire ATF6000ES Front Load Washer
Is there a way of adding more water to every wash as all my clothes especially my towels are very stiff when they dry. I am now adding by hand another 8-10 ltrs to every cycle and the problem is solved,...
ok first things first do not add water to the machine this will screw up its timing and pressure switch settings, there is only one reason your clothes are hard and its because you are using to much detergent, do not listen to the directions on the back of the packet its a load of **** its nothing but a marketing ploy to make u use more therefor buy more, with modern front load washers they make them extremely water efficent meaning less water which in turn means you need less detergent, all you need in a front load washer is about 15mg so a small heap roughly the size of a 20 cent piece NO MORE, i am a qualified appliance repairer and the amount of issues caused by the amount of detergant is ridiculous. If you dont believe me (most people dont until shown) try this experiment get your hard dry towels and put them in the washer with no detergent and watch the amount of foam and bubbles you get, ive actually been able to get 3 loads of washing done using one hard dry towel in with it cos the customer put so much detergent in with the towels, hope this helps
Feb 14, 2011 | Whirlpool AWM6100 Front Load Washer
Bath towels smell sour
I started adding 1 cap of bleach with 1 cup of water to all my loads in the bleach dispenser and this stopped the smell problem with my sweaty clothes.Sour towels i fixed with using Win high performance sports detergent plus my usual dose of he detergent along with a 2nd rinse.Keep the lid open when not in use always.
Dec 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Forgot to remove shippping bolts before using machine.
I would take out the shipping bolts and then run a prgram such as Spin.with no clothes in
If that sounds ok, wet a few towels and spin them dry
If that works put a full load in and go for it
Unless your machine was way out of balance you should not really have damaged anything.
The transit bolts are there to stop the drum from banging around during transit and unless they have torn free or have bent you should be ok
Jul 11, 2009 | Amana Washing Machines
Beach towels sopping wet after machine done spinning
The washer will not proceed into high speed spin with just two large beach towels in the basket. The washer is detecting a out of balance condition, and remains in low speed spin. Solution? Try adding more items into the basket. With only two towels, there is not enough mass to balance the washer. With more clothing or towels, there is more items for the machine to balance, and reach full speed spin.
The only other thing that could cause this, would be if the water in the tub is not completely draining in the time allowed. This washe does not have a cleanout, and checking for an obtruction in the pump is difficult. I would go with the more clothes first, then see.
Sep 25, 2008 | GE WSXH208A Front Load Washer
Whirlpool Calypso
This could be an out of balance condition. When its happened to my washer, I rearrange the load if its large enough, and if its not, I find other items of like weight and add them to the load and start over. Calypso's are sensitive to fabric weight, so If you're washing towels, wash only towels and wash cloths. Make sure you put small items, like bras, panties, nighties, etc., in mesh bags and combine them with other light weight fabrics.
Aug 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Nexxt 100 Series Washer
seperate sizes of clothes towels with towels shirts with shirts. if the washer gets unbalanced and cant balance itself it will shut down after ex amount of trys. your owners manual does discuss this in the trouble shooting section
Nov 08, 2007 | Washing Machines
LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer - White Logo
141 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
