Question about Mitsubishi VS-60603 60" Rear Projection Television
After a quick power outage, we lost everything, just snow on the screen. Was hooked up to Direct TV via the sat input before the outage. Now the TV is on the rooftop antenna input evidently because it keeps trying to download the TV Guide info, it keeps scanning all of the antenna channels. We do not have the remote anymore. Any thoughts? Thanks. Al
  • 51 Answers
On my Dir.TV box is a door in the lower right front. Behind this door is a red button. Press it and turn the box back on if it doesn't come back on by itself. It will go through a reboot cycle of 5 to 10 minutes. That should get the satellite going but I'm not sure about the TV input problem. Do you have a menu button on the TV? If so you should be able to find a way to change the input. If not, find your model number, then Google "TV remote" and you should find sites that will sell you an original remote. They will have a box that you can enter your model # into and tell you your remote number. Then Google that part number and shop for the best price. Good luck.
Posted on Sep 01, 2010
My digital tv is saying no singal whats the problem and how do I fix it? we have a huge antenna on our roof
1 – Is the NO SIGNAL issue happening on just one TV?
CORRECT INPUT or SOURCE
If it is just one TV that is showing the NO SIGNAL…
-Be sure your TV is on the correct source or input as your CABLE or SAT BOX.
-Press the TV button on TV remote control to turn your TV ON.
-Press the INPUT button on your TV remote control.
-Cycle through all the inputs on your TV.
-Do this until you are on the INPUT your CABLE or SAT BOX is plugged into.
-You should then see the CABLE or SAT programming show on your TV.
HINT: Your TV will most likely list the TV INPUTS as: HDMI 1, HDMI 2, HDMI 3, VGA, Component 1, Component 2, and so on.
If you still see NO SIGNAL on your TV screen, see the next step below…
2 – If you have your TV on the correct INPUT or SOURCE and you still see NO SIGNAL…
CABLE OR SAT BOX NEEDS RESET
-Remove or unplug the power cable from the Cable TV or SAT set top box.
-Keep it unplugged for 2 to 3 minutes.
-Plug the power cable back into your Cable or SAT set top box.
-Give it some time for the Cable or SAT box to power up, get the signal, and initialize.
3 – If you have reset the Cable or SAT box and still have the NO SIGNAL…
UNPLUG THE CABLE GOING FROM THE TV TO YOUR CABLE OR SAT BOX
-Remove the HDMI cable or other cables from your Cable TV or SAT set top box.
-Keep the cable unplugged for 2 to 3 minutes.
-Plug the HDMI cable or other cables back in.
-Give it some time for the Cable or SAT box to get the signal and initialize.
HINT: Make sure all the cables that are connected to your Cable or SAT box and your TV are tight, undamaged, and secured.
4 – If all of your TVs are affected with the NO SIGNAL screen…
BE SURE THE COAX CABLES OR ETHERNET CABLES ARE SECURE or CABLE OR SAT IS DOWN TEMPORARILY
-Be sure to check the ones where the CABLE or SAT come into your home.
-Be sure ALL Ethernet and Coax cables are secure.
-Call your CABLE or SAT provider to see if there is an outage.
-Realign your Dish if you have SATELLITE.
May 10, 2017 | Televison & Video
I have a Model D12-100 flat-screen TV, hooked up to DirecTV. I have lost my TV remote and have lost the signal for DirecTV. How do I get the signal to the HDM1 or HDM2 category without the TV remote?
First off, D12-100 is your direct TV Box, Not your TV. A D-12 -100 direct tv box is not an HD box and will only connect to your tv via a coaxial cable or av jacks (red, white, yellow).
If you have lost your remote for your tv and your direct tv remote does not operate it, then you should be able to find the manual buttons on your television somewhere along the edge of the screen.
Toggle inputs till your on "TV" then use the channel selection to toggle it up or down till it's on channel 3 or 4 for Direct tv, If that doesn't work toggle inputs again and try the AV inputs. And of course if you want to use another device toggle inputs to HDMI 1 or 2.
Jan 05, 2015 | Televison & Video
SNOW AND DON'T KNOW IF ITS ON RIGHT CHANNEL FOR DIRECT TV
If possible connect via one of the rear sets of audio and video inputs from the direct box--this is more common than using tuner in set.
Oct 22, 2012 | Toshiba Televison & Video
I came home to find NO VOLUME on the tv now. Everything else seems ok
I will presume a few things:
1. you have tried it via the coax or cable fittings and also rear audio and video inputs.
2. speakers (in the menu) are not turned off.
3. if you are using a cable or sat box you have hooked something direct to the set for sound.
If this is a 2001 or 2002 model there may be another issue.
confirm the date of production and I may be able to tell you exactly what is wrong (date is on back of set).
Steve------aka SD TECH
Sep 20, 2011 | Hitachi 53UDX10B 53" Rear Projection...
VL320m will not connect with my computer via HDMI after power outage?!?!? Can anyone help me please. Tryed unplugging for 5 min that didnt work. updated Bios that didnt work. What could have happened?
Well, it could be one of a few thing, first, maybe you have simply "Lost" your Video Drivers, install your Video and HDMI drivers again, ensure you set it all up correctly, and have the PC configured for Multiple desktop, and the screen resolution and Format are correct. Also the correct External input is selected (HDMI). Now On the TV, you should also unplug the set to "Rest" anything that may have gone awry, now re-set up the TV again, after you are sure all is working, then with everything OFF, plug it all up, and in. Turn ON the TV, and select the HDMI input, Now startup the PC, it should detect the TV and you should display a picture. If you don't get a picture power off tv and try again, check all once more,if you are still no go then I suspect the the TMDS transmitter has had an overcurrent situation,often caused by a power outage and or spike, surge, if left plugged in when power was reconnected. In this case, you will need to get it repaired, or get a service manual, and maybe have a go yourself, hopefully it will not come to that.
May 14, 2010 | Vizio VL320M 32 in. HDTV LCD TV
How do i connect my dvd player up to my tv and direct tv?
Hook your coax cable output from sat. to input on tv, then hook your rca cables from dvd output to input on sat. There are several way to hook one up depends on witch hook ups you have , If this don't work or you don't have theese hookups or wann use different hook ups email me at metallica@tds.net
Oct 06, 2009 | Televison & Video
My Panasonic DLP television suddenly lost picture, went to snow and lost audio. What is wrong?
If you have snow that means you've either lost the signal source (cable satelite antenna) or the TV tuner is bad or your not on a recievable channel. Try hooking a signal to one of the video inputs of the TV.
More info on what you have hooked to the TV would help.
Sep 27, 2009 | Panasonic Televison & Video
DVD Player Only Produces Snow After Power Outage. Halp!
Sounds like your TV has lost the DVD channel. Turn off TV and make sure the DVD player is connected to TV and is playing a DVD. Now put you TV on and press the SOURCE or AV button on your TV remote until you can see the DVD channel. In older TVs you may need select channel and tune it manually using the TV setup.
Jul 10, 2009 | Insignia Digital-to-Analog Converter for...
All of a sudden no picture just snow
Do you have a spare TV? Hook it up to the Sat. box. If you still have no picture, then the Sat. system has a problem. If the sub TV does have a picture, then the problem is on the ProScan end.
May 06, 2008 | Proscan PSVR83 VCR
Televison & Video Logo
114 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
