Question about GE 30 in. Profile JGP989 Gas Cooktop
I have a GE Profile 30" Ceran Schot cooktop mottle black glass.One of the burners has burnt in partial ring that will not come off with the recommended cleaners. Is it possible that it has literally burnt into the glass? Can the glass be replaced . GE says it is not available from them any more. What else is doable short of replacing the entire unit?
  • 4,924 Answers
I don't think that it is burned into the glass ..cause it is made specially for high temperatures..I would remove the glass ..and place it in a large pot ..with caustic soda ..there is available on the detergents department....but pay attention on hands cause ..this stuff burns the flash into soap ..its like the sulfuric acid....
and some detergent too..and boil it at a low flame ..for about half an hour..and it will clean up nicely ..
Posted on Sep 01, 2010
GE Profile Gas cooktop burners blow out
This sounds as though the pressure is too high.
Feb 11, 2015 | General Electric PGP953DETBB GE Profile...
Whirlpool schott ceran induction plate doesn't get hot
magnetic gradeI have a SCHOTT Ceran glass ceramic cooktop as well, and soon realized that induction cooktops like this require that your metal cookware be in contact with the surface for them to heat up. Best cookware:
  • Cast iron pans
  • Any black metal pans
  • Stainless steel pans, if base is magnetic grade (magnet sticks to bottom)
Read more: http://www.us.schott.com/hometech/english/products/ceran/dailyuse/index.html
Jul 15, 2012 | Whirlpool 30-inch Electric Ceramic Glass...
I have a glass 4 gas burner stove top and cracked the glass, can I replace it? Its a GE Profile with a stainless steel front lip
Yes the glass is replaceable, you will have to order a new one, and you could do so through an appliance parts store. They can even put it in for you.
Mar 22, 2011 | GE 30 in. Profile JGP932 Gas Cooktop
I have a GE Profile 30" Ceran Schot cooktop mottle black glass.One of the burners has burnt in partial ring that will not come off with the recommended cleaners. Is it possible that it has literally...
If there was sugar in the item that boiled over, it will not come off it etches the glass. If it was with out sugar you might try a razer blade to scrape it off it will not hurt the glass if you use it flat
Sep 27, 2017 | GE 30 in. Profile JGP989 Gas Cooktop
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Dual Surface Selector Switch
more common is the dual switch to be bad, but it is possible that the elemnt itself has burnt out, usually a 5 yr warr on the elemnts under glass
Nov 08, 2008 | GE Profile JP930 Electric Cooktop
GE 30 in profile jp350kccc for sale
I have this cooktop with a bad burner. What are you asking for it?
T
Oct 23, 2008 | GE 30 in. Profile JP350 Electric Cooktop
GE Cooktop JP930 surface element not working
It sounds like the burner needs to be replaced. When they burn out sometimes they short out to ground. The cooktop will have to be removed from the counter and the glass top opened. You will probably be able to see where the element is burned out. Replace it and you should be fine. If it is too expensive to fix just disconnect the wires to the burner where they attach to the control . Then you can use the remaining burners. I really don't know what a replacement burner costs. An open coil is around $30.
Jul 13, 2008 | GE Profile JP930 Electric Cooktop
Glass top
The cooktop will need to be removed from the counter. Turn it upside down and remove the screws. The biggest problem will be removing the cooktop from the counter. Sometimes it is not worth fixing as the part could cost around $400. NEVER use a cracked top as it could suddenly explode. This is tempered glass and very unstable if cracked or chipped.
Jul 10, 2008 | GE 30 in. Profile JP350 Electric Cooktop
Ceran stock top chipped and cracked
most of thoose ceran tops have a five year parts only warrenty read your owners under 2-5 years warrenty if it does call ge cust assistance to see what you can do
Jan 20, 2008 | GE 30 in. JGP328 Gas Cooktop
GE 30 in. Profile JGP989 Gas Cooktop Logo
110 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
