I have a wiremold plugmold V20GB306+ multi-outlet assembly. It has bare wires (3) on both ends. How do I wire it if one end needs terminated. I have the pieces but no instructions.
SOURCE: ducane grill ignitor replacement
buy a new grill?
Posted on Aug 06, 2008
  • 172 Answers
SOURCE: 3 wire cook top to a 4 wire outlet
Older 3 wire connectors where Wht=Neutral Ground Return, Red=One Phase Hot, Blk=Second Phase Hot, of 220VAC stove connections.
Newer Electrical code standard has a forth wire that is bare copper for a separate safety ground return.
I suggest you but a 4 wire pig tail cable for your stove top, available at Depot or Lowes, and connect 3 wires of this 4 wire cable just like the 3 wires are now connected. The 4th bare copper safety is attached to any metal part of the stove. Find a screw you can loosen to wrap it around and tighten.
Posted on Mar 02, 2009
SOURCE: Leviton Single Pole Switch with Pilot Light Model 277W Box
Depends on whether you want the pilot to glow when the circuit is live (the main light is on) or to glow when the circuit is off. (The switch can be used either way, and I have used this switch in both configurations at different places.)
The wiring diagram is on the inside of the box.
In indicates that if you want the pilot light to glow when the circuit is off, then you only need two wires (the live and the return, usually colored black and white, respectively). However, you also need a ground. The instructions say that you need the ground for safety (and probably legal code) reasons, but I suspect that, without the ground, the pilot light won't work in this configuration.
However, if you want the pilot light to glow when the circuit is on, you probably need a three wire configuration (plus the ground).
Hope this helps.
Posted on May 05, 2009
  • 106 Answers
SOURCE: garage kit (heater)to install on kenmore ref. #106
The kit should just be a heater that piggy backs off the 2 wires going to your cold controle or thermostat. orange and black go back on the cold control with the heater piggy backed. The kit heats the cold control to make it think its warmer in the room or box than it is so it will run long enough to keep frezer frozen.
Posted on Oct 31, 2009
  • 10865 Answers
SOURCE: I'm replacing a non-hydronic electric baseboard
Hello. The red and the black are the hot wires. Therefore, connect one of your conductors to the red and the other conductor to the black. Use wirenuts. The bare ground wire should be solidly attached to the new unit's green wire using a wire nut.
Regards, Joe
PS: please rate my answer. Thank you.
Posted on Jan 06, 2010
Testimonial: "Excellent Reponse"
I lost the key to unlock the treadmill
Step 1
Unplug the power cord from the electrical outlet
Step 2
Use an Allen wrench to remove the bolts on the console cover. Lift the cover and locate the safety switch. It will be in proximity to the key slot. Depending on the particular treadmill, the switch may or may not be attached to the console cover.
Step 3
Locate the wire leads on either side of the safety switch. Most often, the switch is enclosed in a housing and a pair of leads may attach to terminal posts on the housing. Remove the leads from the terminal posts by turning the brass screws counterclockwise with a small screwdriver. If the leads do not terminate outside the switch housing, use wire strippers to cut the leads close to the housing.
Step 4
Strip the ends of the switch leads 1/4 inch to expose bare wire. Twist the ends of the stranded wire tight with your fingers. This is necessary for a good contact. Cut a piece of insulated wire as a jumper bypass that attaches between the ends of the switch leads. Strip the ends of the jumper wire 1/4 inch and twist the stranded wire ends.
Step 5
Insert each end of the switch leads into an insulated crimp connector. Crimp the connectors with the wire strippers to secure the wires. Insert the ends of the jumper into the open ends of each crimp connector. Crimp the connectors with wire strippers.
Step 6
Wrap the jumper wire and crimp connectors with electrical tape. Continue the wraps onto each of the switch leads. Replace the console cover and reinstall the bolts that hold it in place. Plug in the treadmill power cord and press the "Start" button on the console to turn the treadmill on.
Things You'll Need
Allen wrench
Small screwdriver
Wire stripper
Insulated electrical wire
Crimp connectors
Electrical tape
Tips
Soldered connections can be used in place of crimp connectors. Refer to the owner's manual or solicit the manufacturer for a wiring schematic, if necessary. Use a similar gauge and type wire as the jumper bypass.
Jan 15, 2018 | Exercise & Fitness
Wiring a Westinghouse 3way speed switch.
Three way Switch installation; One cable has two wires plus a bare copper grounding wire, The other cable has three wires plus a ground.
1. Connect the black wire from the two-wire cable to the dark common screw terminal. 2. Connect the red and black wires from the three-wire cable to the traveler screw terminals. 3. Join the white neutral wires together with a wire connector and pigtail the grounding wires to the grounded metal box. 4. When the switch lies at the end of the circuit one cable enters the box. 5. The cable has a black wire, red wire, and white wire, plus a bare copper grounding wire. 6. Connect the black wire to the dark common screw terminal. 7. Connect the white and red wires to the two traveler screw terminals and the bare copper grounding wire to the grounded metal box.
I hope this help.
Mar 29, 2013 | Electrical Supplies
Where do i plug in the power adaptor, so I dont have to worry about using the choke when the bike gets cold?
Instructions
    • 1 Fotolia.com"> install-motorcycle-cigarette-lighter-1.1-800x800.jpg If the battery is installed under the seat, loosen and remove the hex bolts holding the seat in place, and remove the seat from the motorcycle. If the battery is mounted under a side battery cover, pry the battery cover from the motorcycle to expose the battery.
    • 2 Strip one-half inch of insulation from one end of the black wire and one end of the red wire. Place a ring terminal over the stripped ends of the black and red wires, and crimp the terminals to the respective wires.
    • 3 Place the positive wire from the weatherproof socket into one of the holes in the first splice connector. Place the free end of the red wire into the splice connector, and crimp the connector to make the electrical connection.
    • 4 Place the negative wire from the weatherproof socket into one of the holes in the second splice connector. Place the free end of the black wire into the splice connector, and crimp the connector to make the electrical connection.
    • 5 Loosen and remove the retaining nut on the positive battery terminal. Place the ring terminal attached to the red wire over the terminal screw, and replace and tighten the positive battery terminal retaining nut. Loosen and remove the retaining nut on the negative battery terminal. Place the ring terminal attached to the black wire over the terminal screw, and replace and tighten the negative battery terminal retaining nut.
    • 6 Route the power outlet to a point on the frame below the rider, and attach the outlet to the motorcycle frame using a cable tie. Use the remaining cable ties to attach the excess wire length to the frame of the motorcycle. Reinstall the battery cover or the seat when finished.
Instructions
Instructions
rate these after reading
Jan 16, 2013 | Motorcycles
Need to replace the cord
If you feel the need to not part with your beloved fan, but instead fix it the solution is simply.
First make sure the cord is unplugged from the wall, electric shocks are painful, trust me.
Then get a pair of wire strippers, NOT wire cutters. If you don't have the right tools, you can strip the wires with a kitchen knife, but this is not recommended as you risk harming yourself.
If the cord is damaged along it's length, you will need to cut out the section that is damaged. Cut the wires wherever you like, cutting to either side of the damaged section.
Bare about 2 to 3 inches (5 to 7 cm) of wire on the two parts of the cord that are undamaged.
Take the positive wires from the fan side and the positive wires from the wall end and wind them together, like you are closing a twist tie.
Wrap thoroughly with black electrical tape. No wire should be visible and it must be electrical tape, as it will not catch fire.
Repeat with the other wires.
If the wires need to be replaced starting at the fan terminal, open the fan casing (having already unplugged it from the wall) and remove the wires from where they are attahed to the fan casing. Please note which is the + and - end. Cut out the damaged section of cord, bare 2 to 3 inches of cord.
wrap the end of the cord around the terminal in the fan.
and do the same with the negative end.
They should be firmly wrapped, so they will not slip off.
You shouldn't need to pthem in place, but you may if it becomes necessary.
Aug 24, 2011 | Emerson Dryers
Can't get my switch to operate the outlet just bought a 5625 switch i have two wires coming out of the wall i want to plug a light in the outlet and have the switch control the power to the outlet.
  • Turn off the power to the receptacle that will be replaced by switching off the circuit breaker in the fuse box. Check that the battery is good in a circuit tester. If not, replace the battery. Place the tester's two ends in one set of the receptacle's slots, then the other set. The light on the tester should not come on. If it does, the correct circuit breaker has not been switched off.
  • 2
    Take off the receptacle's face plate by first removing its screw. Detach the two screw securing the receptacle to the box and pull out the receptacle. Loosen the receptacle's terminal screws and pull away all wires from the back of the receptacle. Take out the receptacle (if working properly, it can be reused). If the ends of the wires are chewed up after removing them from the existing receptacle, cut them off with wire cutters. Strip off 1/2 an inch of insulation from the ends, using wire strippers. Bend them into loops with the pliers.
  • 3
    Bend the copper ends of all wires into a loop, using a pliers. Connect the white wires to the silver terminal and tighten the screw to the wires. Connect the black wires to the gold terminal and tighten the screw to the wires. Connect the bare ground wires to the ground terminal and tighten the screw to the wires.
  • 4
    Push all cables into the back of the box, followed by the receptacle. Attach the receptacle to the box with the two screws. Hold the new faceplate in position and install the screw. Turn on the power at the circuit breaker.
  • HOPE THIS HELPS YOU...Jim...Please leave a comment
    Feb 13, 2011 | Leviton Electrical Supplies
    Im install a newer 220 dryer.why the different plug/outlet configuration how do i wire this
    I'm assuming you mean why does it have 4 prongs instead of 3. Well the new code requires dryers to have a separate means of grounding (have its own ground wire) where as before there was not a separate ground wire, the frame of the dryer was simply jumpered to the neutral wire. The problem in doing that is if there was ever a ground fault it would not go through a separate wire to trip the breaker but the neutral wire which is already carrying current ending in a dangerous short circuit. That being said, your cable going into your outlet should have 4 wires, red black white and bare copper, your new outlet has to have the bare copper connected to the lower prong. And your dryer needs to have the jumper from the frame to neutral removed and you need to connect the green wire from your plug wire assembly to the frame of your dryer. Should your wire not have the correct number of wires your local home depot or lowes will sell a electrical wiring book that can show you exactly how to run the new wire.
    Feb 25, 2010 | GE WBSR3140DW Top Load Washer
    I have a small length of surface raceway (wiremold by LeGrand) which has one finished receptacle, about four feet from that, at the opposite end of the raceway, is another power outlet box with no...
    Yes , that seems high to me also .. when adding receptacles to an existing circuit, you simply connect them color to color, all the blacks together and so forth .. the black wires should be connected to the brass screw on the receptacles , and the white wire to the silver screws. please do not use the stab in connections in the receptacle, you will have a longer lasting job using the screw terminals
    Feb 11, 2010 | Wiremold Switch And Receptacle Box
    I have a 12/2 w ground source. I want to use a Leviton 5224 combination switch to control a double plug. The top swithch for the top plug and the bottom switch for the bottom plug. I will use 12/3 with...
    from power source black/hot wire to switch, white and bare/ground wires wire nut white to white bare to bare. run then to outlet white wire to silver screw bare to green screw. black wires to outlet from top switch to top of outlet bottom switch to bottom outlet break off fin on hot side of outlet should be brass screws dont' forget to turn off power before you start.
    Nov 04, 2009 | Electrical Supplies
    I want to install a GFI outlet in a bathroom that only has a outlet in the light fixture? How do I run a wire from the switch which has 2 switches, one for the fan and one for the light above the med...
    Make sure you turn off the power at the power panel.
    If you are lucky you will find the following in the electrical box behind the light:
    1. A black wire that brings power from the fuse/breaker panel--connected directly to one or two other (black) wires (not to the light).
    2. A white wire from the panel--connected to one or more white wires including one to the light.
    3. A black or white (maybe taped black) wire that comes from the switch and is connected to the light.
    4. A green or bare wire connected to the box and maybe also to the light.
    If this is the case then you can run a new cable to a new electrical box in the wall for the GFI. Connect the new black wire to the Line In terminal/black wire of the GFI outlet and to the group of black wires in (1) above. Connect the new white wire to the Neutral terminal/white wire of the GFI outlet and to the group of white wires in (2) above. Connect the new green/bare wire to the Ground terminal/green wire of the GFI outlet and to the original box or ground wire. If there is a Load/Feed through wire on the GFI outlet, tape the end of it and do not use.
    If the black and white wires described in (1) and (2) above do not appear in the electrical box at the light then they are probably in the switch box and there will be only one black wire and one white wire that connect to the light on the wall. In that case you will need to run a new cable from the switch box to the new outlet. You will not be able to wire the new outlet from the existing electrical box at the light unless you do it through the switch and it will not be on unless the switch is on.
    Aug 28, 2009 | 3M GFI Software GFI MailEssentials For...
    Trying to connect dryer cord to a neptune, old dryer had place for four connections, this one has two connections and and one off to th side with a white wire and a green wire the cord is three prong...
    Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
    I don't quite understand what was wired how but the wiring should be as follows:
    For a 4 prong plug and matching outlet
    1. Black wire on one end terminal of choice.
    2. Red wire on remaining end terminal.
    3. White wire only, on the center terminal
    4. Green wire on the the dryer frame or chassis terminal.
    For a 3 prong cord and matching outlet:
    1. Black wire on one terminal end of your choice.
    2. Red wire on the remaining end terminal.
    3. White wire on the center terminal.
    Always be certain that the wire in the breaker or fusebox match the wiring of your outlet.
    If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
    Thank you,
    Dave E. (Illeagle)
    "Your satisfaction is my personal reward"
    Jul 02, 2008 | Dryers
    35 people viewed this question
    k24674
    jasbo
    jasbo
