Question about Vacuums
Onix 2400w dual bagless vacuum cleaner - Vacuums
  • 22 Answers
SOURCE: how to put on a belt on eureka uno bagless vacuum cleaner
Unplug the vacuum.
Turn it over so you have access to the bottom of the unit (you should see the brushroll)
At the base where the "head" attaches to the body there is a small silver button that you must depress to remove it from the body. Press the button in with a screwdriver or unsharpened pencil while pulling the "head" away from the body.
Use a #2 Philips screwdriver to remove all the large screws from the bottom. They are all the same size and type so you can collect them for safekeeping without worrying about which one goes where. There are 2 smaller screws (if I remember correctly) that are for the upright lock that you do not need to remove. They will be on the small plastic piece near where the bottom brush "head" attaches to the vacuum.
Remove the clear plastic clog cover.
Gently pry the gray cover off. This shouldn't be too difficult as the cover goes loose when you remove the screws.
Flip the gray side over and you should see the innards including the brushroll, the motor, wiring, etc. Facing the assembly like you were looking head-on at the vacuum the belt should be on the right.
Pull up the far end (non-belted end) of the brushroll and then the belted end.
The brushroll should now be free and you should check the teeth on the belted end of the brushroll to ensure none are broken.
Remove the old belt from the motor (also toothed) and replace with new belt (a second spare would be handy to keep around and this is a good opportunity to clean up the air path).
Put toothed end of belt into the belt loop and stretch it a bit to get the toothed end back into place. The belt should auto adjust but just in case you may want to manually rotate the brushroll a few times after replacing the far end (non-toothed end)
Repeat the rest of it in reverse order to put it back.
Posted on Feb 03, 2009
EwingElect
  • 276 Answers
SOURCE: vacuum cleaner won't go - missing a step
In between the filters there's an access panel that can be removed - there may be a blockage there. You should also check your hose for a blockage.
Otherwise you may need to take it to your local Electrolux Service Center. There may be a problem with the pressure board. The machines have a 2 year warranty, not sure what it'd be in your neck of the woods.
Posted on Apr 03, 2009
  • 33 Answers
SOURCE: download parts and operators manual
This owner's manual is available on the Eureka website. www.eureka.com Type in your model # down in the right corner, search & buy accessories.Click go, then choose either the 402A or 402A-1. It is the same owner manual for either one.
Posted on May 19, 2009
  • 21 Answers
SOURCE: Looking for the instruction manual for the Eureka
Go to http://www.eureka.com/service/manuals/80244.pdf this is a direct link to the owners guide for your model or you can call customer service at 800-282-2886 and request a hard copy
Posted on Jul 19, 2009
  • 16 Answers
SOURCE: My vacuum cleaner belt keeps burning up as soon as
CHECK ROLLER BRUSH PROBALLY HAS STRING WRAP UP AROUND THE ROLLER OR THE END BEARINGS ARE FROZEN IF SO SRAY WD40 IN BEARINGS TILL THEY FREE UP OR REPLACE ROLLER BRUSH
Posted on Nov 03, 2009
How do i stop the dust/dirt from coming out of the hose tube when i remove the hose to use attachments?
It sounds like your hose is stopped up. This is a common problem with bagless machines. It's a good idea to buy a bag type vacuum cleaner when this one quits. Most of these chinese made , bagless cleaners only last one year and don't perform very well either. They stop up easily because of poor suction and poor design.
May 08, 2014 | Hoover UH70120 WindTunnel TSeries Rewind...
Bush roller squelling on dirt devil 130005 upright bagless cyclonic vacum
My dirt devil has 3 screws underneath- these are the same ones you use to change the belt--sounds like something is caught in roller-- mone was full of hair!
Jan 02, 2014 | Dirt Devil M130000 ''i'' Dual Cyclonic...
Oreck Dual Power Electric Floor Sweeper Bagless Upright Vacuum replacement for filter over the plastic
Dear Sir:
Please follow the instruction from your section troubleshooting from user manual. or go www. fitness.manualsonline.com or www.retrevo.com
or go to directly to the company from the Vacuum. and follow steps.
God bless you
May 26, 2012 | Oreck Dual Power Electric Floor Sweeper...
I have a bissell powerforce bagless vacum cleaner model # 6579-3. Its not suctioning up anything. What should I do?
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
heatman101
Aug 29, 2010 | Bissell 8975 CleanView Bagless Upright...
How to replace belt on Hoover U6626-900 Wind Tunnel bagless.
Click this to go to a site that will show you (complete with illustrations) how to change belt.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
I hope this helps.
Jan 19, 2010 | Hoover U6630-900 WindTunnel Bagless...
Hoover Bagless WindTunnel vacuum cleaner.
very easy. you have clog. take the brush off look where the hole is thats where the clog is. it might be in there you might have to take the housing off of the motor
May 08, 2009 | Hoover U5753-900 WindTunnel Bagless...
Pulse Bagless dust press system vacuum cleaner I need to download the instruction manual
Dear Customer
please check the following link for
Sanyo Instruction Manual Upright Bagless Vacuum Cleaner SC-150, SC-180
http://homeappliance.manualsonline.com/manuals/mfg/sanyo/sanyo_upright_bagless_vacuum_cleaner_product_list.html
please rate this,Thank u
Dec 16, 2008 | Sanyo Vacuums
Vacuums Logo
171 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
