Question about NEC DTU 8D-2 Corded Phone
Answer button on cannot received calls, how do we fix it. thanks.
  • 149 Answers
Press feature than answer. ldtsnj.com
Posted on Jan 02, 2009
How can i accept the incoming call for myphoneTW1, it gets hard to accept such call, its ringing what button should i use to receive it.
When answering the call scroll down the screen and you will see the button "answer" and "cancel" on the upper screen.
I hope this information will be helpful. Thank you for using FixYa!
Please vote if it helped you.
Jun 27, 2011 | Cell Phones
My Lexmark X5650 (Model number: 4437-001) will not auto answer faxes. It can be manually be answered, and the settings are for auto answer. I can also send faxes too with no hassle at all.
bbargains,
Here is the correct procedure to receive a fax automatically;
Make sure the printer is on and is connected to a working phone line.
Make sure that Auto Answer is on.
To check if Auto Answer is on:
From the printer control panel press the wrench sign.
Press the arrow buttons until Fax Setup appears, .
Press the arrow buttons until Ringing and Answering appears, and then press
OK to save the setting.
Press OK again.
Check to see if Auto Answer is set to On.
If Auto Answer is not set to on, press the arrow buttons until On appears, and then
press to save the setting.
Set the number of times the telephone rings before the printer automatically
receives faxes:
Press the arrow buttons until Pick-up On appears, and then press OK .
Press the arrow buttons until the setting that you want appears, and then press to
save the setting.
When the number of rings you set is detected, the printer automatically receives
the incoming fax.
This should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
May 23, 2011 | Lexmark X5650 All-in-One InkJet Printer
How do I set the date and time and my hp passed all the fax tests but I do not receive faxes.
Follow the instructions below to set date and time on printer
Setting the date and time on an HP All-in-One Follow these steps to set the date and time from the control panel.
  1. Press Setup .
  2. Use the right arrow button (c00377082.gif ) to highlight Tools , and then press the OK button.
  3. Select Date and Time from the Tools menu and then press the OK button.
  4. Enter the month, day, and year by pressing the appropriate numbers on the keypad. After the date is entered, the Enter Time screen displays.
  5. Enter the hours and minutes by pressing the appropriate numbers on the keypad. After the time is entered, the Tools menu displays.
  6. Press the Back button to return to the main menu.
Follow the steps to solve "Unable to Recieve Fax" Issue
Basic requirement are..
1. Rings to answer should be 2 rings greater than your Answering machine rings or Voice mail ( set it to 6 instead )
2. Auto Answer should be on
3. Turn off ECM ( Error Correction Mode )
Use these steps to change the Rings to Answer setting.
  1. On the product control panel, press the setup button (c01661990.gif ).
  2. Use the right arrow key (c01661991.jpg ) to select Basic Fax Setup and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select Rings to Answer and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select the desired number of rings and then press the OK button (c01335940.jpg ).
Make sure that the Auto Answer feature is turned on When the Auto Answer feature is on, the HP fax product automatically answers incoming fax calls. When off, the HP fax product does not answer any incoming fax calls. To turn on the Auto Answer feature, follow these steps.
  1. Press Auto Answer on the product control panel. When the Auto Answer button is lit, the feature is turned on.
  2. Try to receive a fax.
Make sure that ECM is Turned Off ( Error Correction Mode )
  2. Use the right arrow key (c01661991.jpg ) to select Advanced Fax Setup , and then press the OK button (c01335940.jpg ).
  3. Use the right arrow key (c01661991.jpg ) to select ECM , and then press the OK button (c01335940.jpg ).
  4. Use the right arrow key (c01661991.jpg ) to select Off , and then press the OK button (c01335940.jpg ).
Try to Receive Fax Now.
These steps should resolve the issue and you should be able to receive fax
Thank you for contacting FixYa Team
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 13, 2010 | HEWLETT-PACKARD HP 6500 All In One Printer...
HOW DO I GET MY FAXES OUT OF THE MEMORY?
Receiving a fax
Receiving a fax automatically
1 Make sure the printer is on and is connected to a working phone line.
2 Make sure that Auto Answer is on.
a From the printer control panel, press (tool icon).
b Press the arrow buttons until Fax Setup appears, and then press ok.
c Press the arrow buttons until Ringing and Answering appears, and then press ok.
d Press again.
e If Auto Answer is not set to on, press the arrow buttons until On appears, and then press to save the setting.
3 Set the number of times the telephone rings before the printer automatically receives faxes:
a Press the arrow buttons until Pick-up On appears, and then press ok.
b Press the arrow buttons until the setting that you want appears, and then press to save the setting.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
Receiving a fax manually
1 Make sure the printer is on and is connected to a working telephone line.
2 Make sure that Auto Answer is off.
3 To receive the fax, press (green botton) or press * 9 * on the telephone after you answer it and hear fax tones.
4 Hang up the telephone.
The printer receives the fax.
Receiving a fax with an answering machine
1 Make sure that Auto Answer is on.
2 Make sure you have set the number of times the telephone rings before receiving a fax automatically.
When a telephone ring is detected, the answering machine picks up the call.
• If the printer detects a fax, it receives the fax and disconnects the answering machine.
• If the printer does not detect a fax, the answering machine receives the call.
3 Set the answering machine to answer incoming calls before the printer does.
For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls
after five rings.
Forwarding faxes
Use the fax-forwarding feature if you are going to be away, but still want to receive your faxes. There are three
fax-forwarding values or settings:
• Off—(Default)
• Forward—The printer sends the fax to the designated fax number.
• Print & Forward—The printer prints the fax and then sends it to the designated fax number.
2 Press the arrow buttons until Fax Setup appears, and then press ok.
3 Press the arrow buttons until Ringing and Answering appears, and then press ok.
4 Press the arrow buttons until Fax Forward appears, and then press ok.
5 Press the arrow buttons until Forward or Print & Forward appears, and then press ok.
6 Enter the number to which you want to forward the fax, and then press ok.
Aug 12, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
Buttons not working.
try this strip ur phone complety and clean it with a old toothbrush, leave it for 15 mins and put it back 2 gether again
Jan 26, 2009 | Motorola Mobility V551
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Receiver dosen't pick up line that is ringing
go to programming section 5
You want Automatic Line Selection
Press feature00
left intercom button press twice (system program)
press right intercom once (central tel program)
enter # of extension to be programmed (intercom #)
press **
press line buttons in desired order line1 line 2 etc and
end with left intercom then press**
enter feature 00 to exit programming
Dave
Aug 26, 2008 | Avaya Corded Phone avaparp18d
Receiving a fax
The answer mode determines whether your HP All-in-One answers incoming calls or not.
If you set the HP All-in-One to answer faxes automatically, the HP All-in-One will answer all incoming calls and receive faxes. Set the Auto Answer setting to On.If you set the HP All-in-One to answer faxes manually, you must be available to respond in person to the incoming fax call or your HP All-in-One will not receive faxes. Set the Auto Answer setting to Off. For more information on receiving faxes manually, see Receive a fax manually. If you do not know which answer mode to use, see Choose the recommended answer mode for your setup.
To set the answer mode 1 Press Setup. 2 Press 4, and then press 2. This selects Basic Fax Setup and then selects Auto Answer.
3 Press right arrow to select On or Off. 4 Press OK to accept the setting.
Mar 14, 2008 | HP Officejet 5610 All-In-One InkJet...
Tapping the answer button does not answer the phone
I had the same issue until I realized that I was touching the button twice,- first answering the incoming call, then immediately hanging up!
When you first tap the button there is a slight delay and the incoming call seems to be still ringing but you've really already "answered" it. Just tap once, be patient a couple of seconds and say"Hello". Your caller will be there!
Dec 12, 2007 | Motorola Mobility H500 Wireless Headset
Pionee DEH-P7900Bt
This may be a long shot but who knows... I am one of those that reads the manual after I have figured most things out. I had the same problem but it was due to the above :) When a call was coming in I was pushing the phone button on the receiver. After reading the manual I discovered that is the "ignore" button for incoming calls. To answer the call you simply push the multifunction knob.
Sep 15, 2007 | Pioneer DEH-P7900BT CD Player
NEC DTU 8D-2 Corded Phone Logo
83 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
