Question about Samsung AS18A6RB Air Conditioner
Humidity I have a split system that was installed to help control the humidity in my partially below grade piano studio.  I have had the service people come out on numerous occasions because there is no humidity being pulled from the air.  In fact, the air conditioner makes it far worse.  I have to run two dehumidifiers to bring down the humidity and then have to turn on the a/c because of the heat they produce.  Not a drop of moisture is flowing from the outside tube.  (It did pull humidity to some extent the first year, but not since) The company who installed the unit says that is how it is supposed to work.  Can anyone solve this problem?  I won't install in the rest of my house as I don't need to aggravation.  Diane Cooke
  • ikouf Nov 09, 2008
    I have an LG 18000btu split type wall mounted airconditioner. The problem is that suddenly it stopped dehumidifying. For the first 8 months it would drop humidity steadily to below 25-30% and a lot of water (several lt) would flow from the external drain daily. This happened with internal temperature ranging from +17C to +29C in heat/cool/dehumidify settings. Now with internal temperature between +19 and +24 it does nothing and not a single drop flows from the drain. Humidity is stuck at 75-85% and the ac has no effect no matter what the settings. LG and certified technician (after 2 visits) claim the AC is working as supposed and that if I want dehumidifying I should buy a separate appliance (!). The covered area (ac centrally located) is between 20 and 100 sq meters, and it does not make any difference whether I try to operate it in small or large room area. Any suggestions?
  • 828 Answers
Square footage of the studio should give the size of the air conditioner necessary to remove the moisture from the air. In order to remove the moisture the unit a/c has to operate with the coil temperature below the dew point of the air. If the air conditioner is to large for the job it will not run in the cooling mode long enough to remove moisture.
Posted on May 09, 2008
G# and A# Ghost Notes!
First try looking in your transpose settings. Refer to your manual to see if any arpeggiation/unnatural chord settings were inadvertently created by you or made by another user. If you believe it is a software problem you can not solve, back up your memory bank, remove your memory card, and hard reset your keyboard. Insert your memory card and check to see if your problem still exists.
If it is a technical problem, it sounds like you may need to get it checked out by an engineer/repairman. Sometimes when a digital keboard's keys collect too much dust/debris they can trigger multiple keys that aren't being pressed. Think about it like a key getting caught on an upright piano and pulling back the hammer next to the one that was played. A digital piano works off of one or several printed circuit boards or PCBs. The printed circuits usually can not short circuit because the wires and circuits sit in fixed positions. If an alien conductive fiber or series of conductive fibers connects a conducter to another, or if there is any humidity inside your piano it may cause circuits to misfire when a circuit is connected in the area. This could explain why notes you are not playing are being activated in the area in which you are playing.
If you are in a humid area and you suspect that this may be the cause you can attempt to draw out the humidity before getting a an expensive diagnostic done. Find a box large enough to house your keyboard. [If it is on a stand take it off and] place it inside the box. Cover the keyboard with plastic wrap (so as to prevent any foreign objects from getting into the instrument) and very carefully surround the piano with white rice. Remove the plastic wrap, close the box and leave it alone for a few days. The rice draws out any moisture from the electronic components. Very carefully (again so as to avoid getting any rice inside it) remove the keyboard from the box; remove any dust from the body, face, keys, and other components. Try your keyboard now. If humidity/moisture on the PCBs was the problem it should be solved. If not it is time to take your piano for a tune-up.
Hope this helps!
Jul 12, 2013 | Yamaha Music
I have a casio privia px-130, and I'm trying to use it as a MIDI on FL Studio, but it won't show up in FL Studio. Is there a driver that I have to download?
Make sure you follow the steps of the procedure below exactly. Connecting incorrectly can make data
send and receive impossible.
1.
Turn off the digital piano and then start up
your computer.
• Do not start up the music software on your computer
yet
3.
Turn on the digital piano.
• If this is the first time yo
u are connecting the digital
piano to your computer, the driver software required
to send and receive data will be installed on your
computer automatically.
4.
Start up your computer's music software.
5.
Configure the music software settings to
select one of the following as the MIDI device.
CASIO USB-MIDI
Apr 19, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
Noisey initial installation
I would suggest this is just the HDD chugging over and the fans going while the processor works its brains off nothing to worry about. Dell are known for noisy HDD
Jan 01, 2013 | Dell Piano Black Studio XPS 8100 Desktop...
I have an older, much older!, Midisoft Play Piano 2.0 software CD. It says it is for Windows 95 or Windows 3.1. I would very much like to get back to learning the piano, but now have Windows 7. Will it...
Hey there,
I don't know if there's an upgrade available, but I really doubt you'll be able to run the program under Win7. The easiest way (and it's still not easy) to run older (win 95/98) programs under XP or windows 7, is to install microsoft virtual pc:
http://www.microsoft.com/windows/virtual-pc/
This will let you install an older version of windows under your current operating system. Its the easiest way i've found of being able to play older games/run older programs.
If this seems like too much of a chore, look for freeware versions of similar programs that will run under Win7. Here's just a few:
http://download.cnet.com/Piano-FX-Studio/3000-2133_4-10394113.html
http://mustech.net/2007/06/12/midipiano-freeware-midi-piano-player-synth-and-more
http://www.pianoeletronico.com.br/index-en.html
Good Hunting
Mar 16, 2011 | Computers & Internet
The keys in the middle range of my Yamaha electronic piano P-200 seem to be stuck and are very difficult to play - takes a lot of strength to get any sound. Could humidity be a problem? Could piano...
Although the keys have a weighted feel, this is not because of a system involving connection t hammers as in an acoustic piano. This is done mechanically, however, which would indicate a need for cleaning. If you have an authorized Yamaha service center in you area they would need to do the cleaning.
Oct 30, 2010 | Yamaha Music
Toshiba e-studio 600 error ce50
Your copier has detected a temperature/humidity sensor abnormality. This sensor is located on the underside of your control panel. To reach it you will have to remove the entire control panel. Check if the connectors are connected firmly on both ends. If they are you might have to replace the temperature/humidity sensor.
Aug 21, 2010 | Toshiba E-STUDIO 850 Copier
Our Sanyo split air system does not take out the humidity. What is wrong?
Is it blowing cold air.? Depending on your temp. settings will really control the humidity also . try setting it for 64 and see if that helps
Aug 10, 2010 | Sanyo Split System Air Conditioner
I'm in the studio using LogicPro with my MO8 -
In General MIDI, the grand piano is defaulted to MIDI channel 1.
IF you have a device that responds to "General MIDI" format, just send the MIDI data to channel one and you should be fine. Remember that pianos are VELOCITY controlled and usually don't use after touch so you have to generate appropriate velocity for EACH note if you are using an editor.
Jan 07, 2010 | Yamaha Music
I up-graded to a Dell Studio Mini-Tower, Intel
This software has some compatibility issues with your operating system. win2000 is the recommended one...
Aug 06, 2009 | Adobe PageMaker Plus 6.5 for PC
Hhow to save a pattern in fl studio and reuse the same in another
Open up the piano roll window for the sample you have selected. Use the highlight tool, which looks of a dashed square, to select the entire pattern by dragging your cursor from the top right corner of the piano roll diagonally to the left bottom corner of the piano roll. If you can't see all of the bars used, then try sizing the track in the piano roll closer together by placing your cursor on the square directly to the right of the horizontol scroll bar. Hold down the left click and move your mouse down to track the piano roll closer or move the mouse upwards to span it more. Select all of the bars used in the piano roll and click the down arrow in the very upright corner. Select Edit > Copy. This will copy all of the bars in the current piano roll. To paste the pattern simply click the down arrow again in the upright corner and select Edit > Paste in any piano roll.
Jan 20, 2009 | Image Line FL Studio 5 Producer Edition
Samsung AS18A6RB Air Conditioner Logo
64 people viewed this question
Top Samsung Heating & Cooling Experts
Nyte_Ryder
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
