Question about Samsung Washing Machines
My Samsung washing machine having a problem of water outlet system. Water still running out from the outlet pipe through the whole process.
  • Samsung Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The hoses are not hooked up right ...
Here is a tip that tells you how to fix that problem...
Water will not stay in Washing Machine
heatman101
Posted on Sep 01, 2010
Hi, I have the WA13V5 toploader. The machine is 7 months old. Yesterday the machine still worked 100%. This morning the water does not want to flow into the machine. I have checked the water flow and the...
Hi
There is a filter located in the pipe between the connector to the water outlet and the machine, This sometimes gets clogged. If this dos not solve the issue then time to call a tech. Anyway your machine is just 7 months old and it should still be in the warranty period and the service should be free.
Regards.
PLZ. don't forget to rate my suggestion.
Jul 19, 2011 | Samsung Washing Machines
Water flowing through outlet pipe before washing. does not seem to fill tub properly
Make sure that the outlet pipe is higher than the top of the desired water level, preverably level with the top of the machine. Otherwise it will run out to the level of the pipe.
Jan 28, 2011 | Speed Queen AWS44NW Top Load Washer
Water doesnt stop fillinG in panasonic NA F60A6 WASHING MACHINE
Fyi. All new washing maching already tested on their functionality and features but not test run with water intake and drain function. I would like to share My experience last time with this model. The water outlet valve will release by motor when you set to drain mode.it suppose manage to retract back by spring when drain process finish or afte small you change to wash mode.
Take a look on the spring movement.normally it not properly hold valve switch hence the retracted spring not block the valve to stop water drain. Just rectify the alignment of the valve swich which directly connected to the retractable spring.
Dec 26, 2010 | Washing Machines
Water supply running extremly slow almost drop for drop what can the problem be. All connections are correct water outlet fine.
The pipe connecting the water supply from outlet to the machine could be blocked. Please remove the pipe and check it with another source. If choked with replace it.
Jun 16, 2010 | Washing Machines
My hoover 540 washing machine started making funny noises a couple of loads ago (loud banging noise during spin cycle). Now it goes through whole cycle but when it gets to 'drain' part of the cycle,...
Sounds like a blockage in the outlet pipes or filter. It may be possible to drain it if you can get the outlet pipe (one from back of machine) outside, lay it flat on the ground as this will take it below the water level in the machine and may slowly drain. Once it drains out enough the machine should disengage the door lock to allow you to open it. Then check your filter and pipes for blockage. If no blockage is found then suspect faulty pump.
Jan 25, 2010 | Washing Machines
Hot water will not run properly into machine, have
fit new hot water valve but check the flow from your fill pipe first both easy jobs
Dec 15, 2009 | Washing Machines
SAMSUNG FRONT LOAD WASHER
samsung machines have a common fault i have a j1253 and this problem has come up also another problem is that the drum over fills with water this fault is caused by a vacumn pipe which has either a blockage for less water or a hole in it when the drum overfills this vacum pipe is located in my washing machine at the front under the top itis a small pipe which is whitish in colour running from the back of the machine at the bottom along the right side of the machine and travel upwards to a round vacum valve this pipe either gets squashed by the movement of the drum and the concrete balance or in the case of over filling rubs and creates a whole check this pipe as this is usually the cause
Jul 31, 2008 | Samsung WF337AA Front Load Washer
Roper washer
I have the same damn issue with my Samsung washing machine(Top Loader) Not quite sure why it does it.Help please really annoying.
Jun 05, 2008 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
56 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
easy alberta
easy alberta
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
