Question about Sylvania SF150 15" Flat Panel LCD Monitor
Hi - i had some pins break on my sylvania sf150. i am now trying to spice another cable to it but the colors do not match. where can i get a wire color printout ?
  • 82 Answers
It's not worth splicing, you can only screw it up even more. just get a replacement
Posted on Sep 01, 2010
I have a Sylvania 6842PE 42 in. HD-Ready Plasma Television the screen is a fuzzy pastel color you can see a picture behind that... Is it fixable since I don't have the money to buy another?
This sounds like problems with VGA cables when a pin is not making good contact. Have to tried replacing the cable that connects the t.v. to the device giving the image?
Dec 02, 2014 | Sylvania Televison & Video
How do I rewire my 6pin s-video cord to my GPX tvs200 ( there is green/red/black/yellow/white and blue
I think I know what you want. Now, if GPX tvs200 doesn't have S-Video plug hook up for the S-video cables. Then your out of luck. What type of input does the GPX tvs200 have?
There possibly you could is USB port if it has one. Now about the wire colors in S-Video cable. These color wire are used for reference for one of the cable plug (6 pin) to the other end plug which also has S-Video plug (6 pin) Just like Pin one on S-Video plug will go to pin one (1) on the other end of the S-Video cable the color the wire could be any color as long as the wire corresponds to pin 1 of input and to pin 1 of the output of S-video cable match. stewbison
May 27, 2011 | Optics
When online, my older SF150 monitor requires me to use the vertical & horizontal sliders to see all the text/photos. In the 'control panel', 'display' then 'monitor': 'properties' button is not active...
I found Sylvania video drivers at this link:
http://www.xpdrivers.com/monitor-display/sylvania/_3_3785.cfm
That may help, since you mention it is only a problem when you are "online", what is the Screen Resolution set at? The native resolution for this panel is 1024 x 768, this should be your starting point. If that is correct then the problem is in the browser, press and the "minus" (-) key to shrink the view of the browser window, the "plus" (+) key will enlarge it as well.
Feb 14, 2011 | Sylvania SF150 15" Flat Panel LCD Monitor
Missing power supply. First, thanks to fredtmccoyjr for the boot fix. the BIOS update from A06 to A09 actually allows me to enable boot from harddisk in the settings, instead of settign a useless tick on...
It was the 1996 to 2000 time frame, that Dell was proprietary with the 20-pin ATX main power cable, and the matching connector on the mobo. (MOtherBOard).
Standard 20-pin ATX main power cable, and it's corresponding connector should work, then add the 4 power wires that are missing, in a separate connector.
To expound:
View this standard 20-pin ATX main power cable, and it's respective connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
The power wires should be in the same place as your P3 units.
(Match the color codes.
Use the lock tab on the 20-pin ATX main power cable connector, to base where the pins are.
Pins 1 though 20. Match the color code of the wires to the pins, and use the chart to compare)
Here is a view of a standard 24-pin ATX main power cable, and it's respective connector, so you can see what power wires are missing, from the 20-pin ATX main power cable connector, that are present in the 24-pin ATX main power cable connector.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Note the missing power wires, and what pins they line up with.
The P4, or also stated as the 4-pin ATX +12 Volt power cable, uses two Yellow (12 Volt) wires, and two Black wires, (Ground)
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Since you don't have the male connector, be sure to orient in your mind where the Yellow (12 Volt) wires go, and the Black (Ground) wires go, by looking at the lock tab on the side of the female connector, on the motherboard, and comparing it to the photo.
Transfer this info, to the P4 connector you are going to make.
Where to get the power wires you need? Connect to any extra 4-pin Peripheral power cable wires, or splice off of ones that are in use, is one suggestion.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
The links given are near the middle of the page. Scroll back to the top. Left-click on any power cable connector, that you wish more information on.
More info,
http://en.wikipedia.org/wiki/Computer_power_supply
Scroll to the bottom of the page, and look at the chart under the heading -
24-pin ATX12V 2.x power supply connector
(20-pin omits the last four: 11, 12, 23, and 24)
One more link,
http://www.smpspowersupply.com/connectors-pinouts.html
Lastly Dell Support > Optiplex GX260 > Service Manual,
http://support.dell.com/support/edocs/systems/opgx260/en/sm/index.htm
Just in case it's of any use.
Have questions regarding what I have stated, or need more clarification of anything I have stated, simply post in a Comment.
Jul 06, 2010 | Dell OptiPlex GX260 PC Desktop
How do I hook up dvd player
It should hook up like a regular VCR does. A short cable from the OUT on the back of the dvd player to the cable hookup on the back of the tv.
You can also use audio/video wires (3 wire cable). Somewhat same method...connect 3 wires to audio/video OUT of the dvd player to COMPONENT section on the back of the tv. Should be color coded to match colors on the 3 wires.
Hope this helps some. It is difficult to explain. Good luck!
Jul 31, 2009 | Sansui DTV3200 32" TV
How do I find and replace the vga cable? (It is hardwired to the back of the monitor.)
I got hold of an old vga cable (15 pin), cut off the male end. I then cut the existing cable comming out of the monitor. After soldering the wires together and lots of electrical tape wala - it works.
Now the problems I incured - Don't solder wires together based on color, they probably will not match. Peel back the ends of the cut off connectors and find each pin with a Multimeter. Once you find each wires match solder them carefully and tape. When done test and if good place a short splint on the spliced area and tape. This will keep the wires from breaking from movement. Good luck.
May 24, 2009 | Sylvania SF150 15" Flat Panel LCD Monitor
Standard cat5 wiring doesn't match philips rj45 flush mount
Are you looking for cat5 straight through cable or crossover??
option 1 (straight through)
each pin correspond to the other end in the same spot.
If all the cables are colored the same then you need an ohm meter to identify them.
Option 2: (crossover)
Pin 1 correspond to pin 3
Pin 2 correpond to pin 6
Pin 3 to Pin 1
Pin 6 to Pin 2
or you can go to (for schematics):
http://www.duxcw.com/digest/Howto/network/cable/cable5.htm
Nov 21, 2008 | Computers & Internet
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
Sylvania SF150 15" Flat Panel LCD Monitor Logo
35 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
