Question about Estate Washing Machines
Fills up with water then nothing **** a humming noise
    Sergeant:
  • 239 Answers
Sounds like something stuck in pump or bad motor.
my bet would be something in pump,
Posted on Sep 01, 2010
Crosley washer fills with water than does nothing lid switch is good
Hi - Since you have already confirmed that the door lid strike is in good condition, does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Nov 19, 2012 | Washing Machines
MY GE front loader washer won't fill with water or spin. I hear a hum when I turn it on and it sounds as if it's about to start a cycle but nothing happens.
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem:
1) check to make sure the water is on
2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc.
3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
May 19, 2012 | GE Washing Machines
Just moved front load beaumark washer into a new house, and it won't fill with water. the display lights up and you can here washer trying to fill (humming noice). All display lights come on and it...
It sounds like your water inlet valve is either not getting a signal to let water in from your control board or the water inlet valve is defective. Since you are hearing a humming noise, I would say that the water inlet valve is defective or has been damaged in transit.
Jun 18, 2011 | Frigidaire ATF6000ES Front Load Washer
Dishwasher fills with hot water then does nothing
Do you get any humming noise when you turn it ON?
How long its been you used the dishwasher last time...?
If you are getting an humming noise then Sounds like the water circulator pump is stuck. The motor tries to turn it (humming noise), but cannot. So a breaker trips (self reset). Not claiming this is actually the problem, but this is what the motor turns.
Aug 30, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
WASHER WILL FILL WITH WATER, BUT WILL NOT DRAIN
the bearings are bad if it is an older unit you are better off buying a new one
Oct 04, 2009 | Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
My washer won't fill with cold water...only the hot works.
Cold water solenoid on the water mixer valve is likely shot.
Change the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Loud humming noise when dishwasher is filling with water
sounds like it could be furring in your water piping. may need a plumber to check it out.
Mar 16, 2009 | Dishwashers
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Help
The humming noise is the fill valve...this sounds usually is overpowered by the water fill, but if its faulty it wont let the water in....Replace the fill valve
Jan 20, 2008 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Washing Machines Logo
35 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
